medo
RouterBoard's IPSec performance
Mon Sep 15, 2008 3:24 pm
I noticed that 433AH is actualy slower than RB532A when doing AES encrypted IPSec VPN tunnel. I also noticed that (discontinued) RB333 is 2-3 times faster with AES than RB532A.
I would like to know about IPSec performance of other RouterBoards especily RB600. Are there ANY official documents about IPSec performance benchmarks for different RouterBoards?
sergejs
Re: RouterBoard's IPSec performance
Mon Sep 15, 2008 3:30 pm
How did you tested IPSec on all boards ?
Do you use the same configurution ?
Is it possible to get configuration from your routers ?
medo
Mon Sep 15, 2008 3:41 pm
All RBs were netinstalled from the scratch. AES-256 encryption was used for encryption and SHA auth for both phases with modp1024 PFS and DH groups.
laptop1--(eth1)--RB532--(eth2)---crossover_UTP---(eth2)--RB532--(eth1)--laptop2
I ran iperf, chariot and Bandwidth test within both RB and got similar results.
sigbjornl
Mon Jan 18, 2010 9:33 am
Any update to this? I am also very interested in IPSEC performance...
sigbjornl
Mon Jan 18, 2010 9:34 am
Any updates with regards to IPSec performance on the various Routerboard models?
sergejs
Mon Jan 18, 2010 11:44 am
What is your configuration for IPSec?
What are the results you got?
sigbjornl
Mon May 03, 2010 11:21 pm
I had no Routerboard at that time, but I do now.
I have a Watchguard Firebox II in the other end and I get about 5mbit trough. The link is fiber to fiber full duplex at 10/10mbit.
Is this the IPsec speed I can expect from the RouterBoard 450G ?
I use 3des and sha1.
Regards,
Siggi
hedele
Tue May 04, 2010 4:36 pm
You probably won't get a whole lot more out of it...
Try switching to AES-128 - this should be a lot faster.
sigbjornl
Sun Apr 03, 2011 3:35 pm
The Watchguard has been replaced by a RB 750G, and I'm now running aes-128. I get the full 10mbits with a CPU usage of approx 45% on the RB750G.
Users browsing this forum: No registered users and 50 guests
