HaQs
Interface profile
Mon Sep 15, 2008 11:19 pm
Wireless interface profile
In ROS 2/3... when I change wireless card then lose all configuration
The fine function is wireless profile list, table with exist profile where I can apply old configuration to new card.
Chupaka
Re: Interface profile
Tue Sep 16, 2008 1:52 pm
export/import...
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
HaQs
Wed Sep 17, 2008 12:29 am
hmmm export import with list old card profile ?
export import support winbox window without terminal?
Chupaka
Thu Sep 18, 2008 11:42 pm
sorry, I do not understand your... english?.. :(
why don't you export your card config and then import it after card replacement?
HaQs
Sat Sep 20, 2008 11:45 am
This is polish english :D
Where in winbox is button to export and save in RB card config, and later import it to another card ?
Chupaka
Sat Sep 20, 2008 12:02 pm
use 'New Terminal' button, then type something like '/interface wireless export' (or maybe '... export file=cfg.rsc'). then you just open terminal and paste your exported commands (having changed interface name to correct)
HaQs
Wed Sep 24, 2008 12:29 pm
OK,
1) how export/import "'/interface wireless " without terminal :P ?
2) Where is list of available card profiles (exist and not actual exist card)
3) how export to file configuration from actual not exist card
mrz
Wed Sep 24, 2008 1:06 pm
export import works only from terminal. Adding export/import buttons in winbox would be absolutely useless anyway.
HaQs
Thu Sep 25, 2008 2:40 pm
I know, but another option not avalibe in ROS 3 -WINBOX (wireles interface profile with exist and not exist card)
Chupaka
Thu Sep 25, 2008 4:13 pm
we all say you that you do not need any 'profiles'
HaQs
Fri Sep 26, 2008 12:14 pm
hmmm ,
how in ROS terminal or winbox export configuration from not existing card (dramaged or take out) ?
normis
Fri Sep 26, 2008 12:15 pm
not possible AFAIK
HaQs
Mon Sep 29, 2008 5:01 pm
Exactly.
When this option will be available.
Chupaka
Mon Sep 29, 2008 5:43 pm
I don't think it's necessary here - no reason to clutter up router's memory =)
HaQs
Mon Sep 29, 2008 8:18 pm
But there is useful option for me.
This option not use a lot memory.
Equis
Forum Veteran
Forum Veteran
Tue Sep 30, 2008 1:40 am
How does it tell what card is what?
If you put a new card in with the old max address does that work?
HaQs
Wed Jul 28, 2010 12:16 am
Is there any opportunity for such functionality?
1) Upload config to ROS.
2) After rebooting. ROS inform that we have the unconfigured wlan and card configurations are available and displays the following example, ssid, name of the card, the card mode and scope of work.
3) choose which profile we are interested in and we have configured WLAN.
In the Ubiquiti, simple copy the config from one device to another and it works without setting the radio from scratch, just several clicks.
I understand that in ROS can we do now by making edit a few lines of export file etc but why did not it would be easy and enjoyable ?
patt
Wed Jul 28, 2010 12:50 am
I agree.
This is wery imporant future for us.
Belong UBNT, is we have a backup of device, we may do replace device wery quicly, simpy upload a backup file and restore.
This is wery, wery good future of this device.
I now, that in Mikrotik is not so simply, because we may rename of a interface.
So profile will be a simpe solution of this unsuported backup restore.
regards
patt
ravael
Wed Jul 28, 2010 2:12 am
Yeah that would be a beautiful feature!
Users browsing this forum: anon31337, Baidu [Spider], Google [Bot], magistryoda and 110 guests
