Wynand
Passthrough in mangle
Sat Sep 20, 2008 3:53 am
Hi, I've been trying to set up some basic QOS rules for our wireless network, and have stumbled apon a few questions.
If I do packet marks in mangle, and unselect passthrough, would it bypass queues, firewall filter, or both?
Equis
Forum Veteran
Forum Veteran
Re: Passthrough in mangle
Sun Sep 21, 2008 12:20 am
no it will just not go to the next mangle rule.
Wynand
Sun Sep 21, 2008 2:04 am
I thought unselecting passthrough skipped the rest of the mangle rules.
Equis
Forum Veteran
Forum Veteran
Sun Sep 21, 2008 5:16 am
Yes, That's what I meant :-)
dcrystalj
Wed Feb 29, 2012 10:59 pm
can you tell me what is better?
use on all mangle rules for prioritizing packets passthrough or not, or only on some of them (which)?
regards
mrz
Thu Mar 01, 2012 10:30 am
For all "mark-packet" mangle rules it doesn't make sense to set passthrough=yes.
If packet is already marked then simply do not send to next mangle rules, to save CPU resources.
dcrystalj
Thu Mar 08, 2012 1:20 pm
i'm just asking coz my cpu doesn't get more then 30% and mangle doesn't work very well. now i have all set to passtrough="no"
jackman
Tue Mar 13, 2012 8:57 am
As a suggestion, you could use the counter to find out, do your mangle work or not. Basicly the passthrough will be usefull for example
you would like to mark connection and base on the marked connection you would like to mark routing or packet. Or you would like to remark the already marked entity (conn/packet/route). And this passthrough=no is only effected on the same chain.
May this could help
May this could help
Tenny Bagindo
dcrystalj
Tue Mar 13, 2012 9:12 am
do you have any examples?
any link?
tnx
jackman
Tue Mar 13, 2012 10:30 am
any link?
tnx
on mikrotik wiki you will find alot of example but i will give you a simple trial :
just set following mangle on your router :
1) mark connection on chain prerouting with your pc ip address as src-address and action mark-new-connection with new connection mark = pc set the passthrough =yes
2) mark packet on chain prerouting with connection mark = pc, action = mark-packet with new-packet mark=packet1 passthrough=yes
3) mark packet on chain prerouting with connection mark = pc, action = mark-packet with new-packet mark=packet2 passthrough=no
4) mark packet on chain prerouting with connection mark = pc, action = mark-packet with new-packet mark=packet3 passthrough=yes
And try to make any communcation from your pc to internet for example. You will see on firewall mangle list the counter 2,3 will growth and 4 will stay 0.
if you set your traffic shapper (queue) based on packet 2 or 4 the shapper will not work. It will work on packet3.
Let me know your result
May this could help
Tenny Bagindo
Users browsing this forum: barmalei, Google [Bot] and 30 guests
