Eggplant
/tool e-mail
Mon Sep 22, 2008 11:56 pm
Are there plans to support secure e-mail? My server requires SSL for email. I have no desire to have a open relay or unencrypted email credentials.
normis
Re: /tool e-mail
Tue Sep 23, 2008 10:50 am
not really, router os is not a mailclient :P
Eggplant
Re: /tool e-mail
Tue Sep 23, 2008 6:42 pm
Ahh my misunderstanding of the documentation where it says
"Summary
E-Mail client tool is used for sending e-mail messages from the router."
I will gladly write a ssl capable email client for MT. I have wrote a few already for quick secure emails, I am sure I could port one to MT. Is there a devel kit or such that needs to be purchased or licensed in order to produce packages for MT?
normis
Re: /tool e-mail
Wed Sep 24, 2008 8:44 am
no, there isn't. the email tool is meant for really simple tasks, like sending you the backup file. therefore, you should make a tunnel to a simple mailserver, or open up your SMTP's firewall just for the ROS.
Cobusbu
Re: /tool e-mail
Wed Nov 26, 2008 7:45 pm
Hi
You can resolve the problem by using a smtp proxy to act as a relay, e.g. Sambar Server.
I had the same problem I resolved it with Sambar Server.
