MUM Europe 2020
EngAMoktar
How to force clients to use DHCP server
Sat Oct 04, 2008 7:04 am
I wanna force clients to use the DHCP server , by checking "Obtain an IP adress Automatically"
cause noticed that in the hotspot user Hosts the Mikrotik recognize them by the way they loged in by the letters "AH" means "authorized DHCP"
so is it possible to force them to use the DHCP server ??
i'm using hotspot ..
thanx
Chupaka
Re: How to force clients to use DHCP server
Sat Oct 04, 2008 1:47 pm
you can use arp=reply-only on your hotspot interface, and then check 'add arp for leases' in dhcp server - after that, only dhcp-assigned addresses will have access to the router
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
netrat
Sat Oct 04, 2008 1:52 pm
Set the interface to reply-only arp and enable add-arp on the dhcp server.
Pepo
Sat Oct 04, 2008 6:07 pm
thanks for you, but i want to say that in some cases some of my clients their pc don't get the IP from server so i add its my ip manually.
if that happens what can i do ???
:lol:
Chupaka
Sat Oct 04, 2008 7:57 pm
then you should add static ARP entries manually =)
EngAMoktar
Sat Oct 04, 2008 10:00 pm
Chupaka , netrat you are the best . thanx for the help , i'm very thankful
Pepo
Mon Oct 06, 2008 6:22 pm
thanks for you, but i want a quick example for what you say please
Users browsing this forum: akarpas, Chupaka, crosswind, dad2312, EdPa, eworm, klaus007, mscarpitti, MSN [Bot], Znevna and 173 guests
