MUM Europe 2020
sergejs
Nstreme test package
Fri Oct 17, 2008 3:58 pm
We have optimized the Nstreme code, that performs much better for point to multipoint environment. It is necessary to use new Nstreme package on Access Point router, client routers can use old version, but we recommend to install new package for clients too.
Packages for download:
mipsbe package;
mipsle package;
ppc package;
x86 package.
For more information and any problems with test package, please contact MikroTik support (support@mikrotik.com).
nz_monkey
Re: Nstreme test package
Fri Oct 17, 2008 11:40 pm
Hi sergejs
Can you explain what has changed in Nstreme ?
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
edward08
Sat Oct 18, 2008 12:19 am
Should I install this upgrade in a point-to-point scenario?
uldis
Mon Oct 20, 2008 11:08 am
We have improved the polling mechanism for nstreme.
Please let us know if that solves the problem with the lot of wireless nstreme clients (more than 30).
About point-to-point, you can also install it on the point-to-point links, but the most benefits are for point-to-multipoint.
shoffmann
Mon Oct 20, 2008 10:41 pm
I have put this package on ~20 various AP's and it has tremendously improved AP's and customer performace on mipsbe and mipsle chipsets only. On PowerPC units with Nstreme on it has absolutely destroyed the throughput, latency and jitter.
Has anyone else seen this?
Steve
Pocketinet Communications
uldis
Tue Oct 21, 2008 11:00 am
Steve
Please make the support output file from your PowerPC AP when you see worse throughput with the new test package. Send it to support@mikrotik.com
uldis
Wed Oct 22, 2008 12:20 pm
we have updated these test packages, please download them again. There was a bug (kernel panic) when creating support output file with regular wireless mode (not nstreme).
infowest
Thu Oct 23, 2008 9:24 pm
Any clues on what has changed? Fragmentation? Any config changes we need to plan on to optimize this, or is it all automagic?
thanks!
Randy
tjohnson
Thu Oct 23, 2008 10:59 pm
Also, you "recommend" upgrading the clients, but it was not necessary. Is there a benefit to upgrading the clients? Some more info about the changes would be very helpful.
Travis
believewireless
Thu Oct 23, 2008 11:36 pm
When trying this on an RB532 we get the printout at the end of the message. If we can log in fast enough and disable the test package, everything is fine. This happens on two different mipsle boards.
MikroTik RouterOS 3.15 (c) 1999-2008 http://www.mikrotik.com/
dec/31/2001 20:00:05 system,error,critical System rebooted because of kernel
fai
l
ure
dec/31/2001 20:00:05 system,error,critical router was rebooted without proper
sh
u
tdown (cause 1)
dec/31/2001 20:00:08 system,error,critical System rebooted because of kernel
fai
l
ure
dec/31/2001 20:00:08 system,error,critical router was rebooted without proper
sh
u
tjohnson
Thu Oct 23, 2008 11:39 pm
I have installed on several RB532 boards with no problems.
Travis
Mplsguy
Thu Oct 23, 2008 11:58 pm
Polling algorithm has been adjusted to be more suitable for large numbers of clients and for most common traffic patterns (bursty traffic with rather low average rate). As polling is controlled entirely by AP and protocols are backwards compatible, only AP is required to be upgraded.
There are two reasons why it is recommended to upgrade clients as well - first, there are some improvements for clients to increase efficency (but that should not produce notable improvement, therefore it is not required), second, all development happens with new test package on both AP and clients, therefore only this combination can be considered best optimized. Although reports on test results when using older clients are welcome as of now, you can expect that support will ask you to upgrade some time later, when that will matter.
As of now, test package does not require any configuration changes/adjustments - consider it all "automagic". New wireless configuration settings that have been added to wireless-test are not pertinent in this case as they do not affect nstreme operations.
Fragmentation of packets has been available for nstreme before (controlled with framer-* settings). These improvements do not change or affect that.
There are some other improvements in development that should further help jitter issues over PtMP nstreme links, so you can expect new test packages soon. Feedback in form of supout files and detailed problem descriptions are welcome.
rpingar
Long time Member
Long time Member
Fri Oct 24, 2008 1:13 am
we tested the new package on two misple 532 and it is fine.
One AP have 44 clients and another 30.
In both cases the new package performed better them the regualr one. The latency when down from 40-60ms in the first cast o 6-10ms.
BUT
but the jitter is still here, in fact it does several ping to 6-10ms and then goes to 120ms for some seconds then it is back to normale, or on packet at 6ms and the following at 120ms....
So i think the poll mechanisme has provided a very good performance but MT should still work on jitter.
Then letting us to use queue in the way to reporduce WMM should close the gap to a professional system.
Regards
Ros
uldis
Fri Oct 24, 2008 12:29 pm
We have updated the wireless-test package. Please download them again, upgrade your routers and report back how it is working.
rpingar
Long time Member
Long time Member
Fri Oct 24, 2008 2:08 pm
Tested release of today 24/10
very very promising.
Tested only on mipsle.
Higher CPU usage and this is a nice thing for wireless customers.....
very few spike in latency, and bettere average performance on latency.
Good work.
Ros
Alessio Garavano
Sat Oct 25, 2008 2:09 am
When was the rebuild of the wireless-test package? i downloaded theses in 10/20/2008...
Alessio Garavano
http://www.isparg.com.ar
rpingar
Long time Member
Long time Member
Sat Oct 25, 2008 9:45 am
they were updateted yesterday.
We tested them on three wireless router and only on one we had a little isse about changing on the fly the Hardware Retries, it crashed the router.
Disabling the interface changing the parameter and then re enabling the wireless worked around the problem.
The performance of last build is fantastic.
GREAT WORK MT.
Regards
Ros
shoffmann
Sat Oct 25, 2008 8:19 pm
I'm testing this now on a ppc board with 25 clients. It is working quite well.
Previous version did not work well at all on the ppc boards.
Thanks for the great work.
Steve
Pocketinet
uldis
Mon Oct 27, 2008 10:01 am
GREAT WORK MT.
Regards
Ros
did it create an autosupout.rif file? if yes then please email it to support@mikrotik.com
BrianHiggins
Long time Member
Long time Member
Mon Oct 27, 2008 10:49 pm
Put simply, AMAZING IMPROVMENTS!!
we've tested on 3 of our heaviest loaded / worst performing PtMP APs, 2 of them are using SR9 radio's and the other has a XR5. the SR9 APs (one 532 and one 333) have shown improvments from average latency of 100-140ms (jitter ranging from 20ms to 300ms) down to now 15-20ms average latency and jitter ranging from 7 to 40ms
Additionally radio uptimes on the SR9 links seem to be noticably better with much less bouncing (momentary disconnect / near instant reconnect) of the connections.
the 5.8ghz AP showd even less jitter, and average latency of about 8ms to most clients! (improved from 30 to 40ms previously)
will be testing on a few more APs over the next few days assuming these 3 don't show any problems.
all around this seems to be a wonderfull update, and I strongly encourage people to test this out in the field and report back their experiences.
Muqatil
Trainer
Trainer
Tue Oct 28, 2008 11:21 am
I've done some field test:
On RB532 with 2 wlan:
CPU 100% all the time
Good ping and jittering on all 30 users on each wlan
On RB411 with 1 wlan used as PtP
CPU 100% when there's a lot of traffic
Kernel failure and resets.
On RB333 with 3 wlan
CPU always 100%
every wlan couldn't support more than around 15 users (they usually had 25 users each). Users keep disconnecting
Except for the RB532, i had to remove the wireless-test package from the machines to prevent crashes.
I am sorry i totally forgot to create supout from those.
Renato Bernardi
skype: medtech5
shoffmann
Tue Oct 28, 2008 5:34 pm
I will have to back up a bit from my previous post. I tested this firmware on several of my AP's for two days. It seemed to work quite well. I have now rolled 10 more AP's to it and have a mess. Customers flooding my support lines with close to no bandwidth. Continuous re registering of SU's (some every 15 sec.). Even the ones that were working fine have seemed to crash.
I will send a support.rif
Steve
Pocketinet
uldis
Wed Oct 29, 2008 4:09 pm
please download the new packages - we have updated them.
New packages should contain fix for crash and optimize the disconnection problem.
Report back with the results.
Muqatil
Trainer
Trainer
Wed Oct 29, 2008 6:14 pm
now mipsle crashes and ppc doesn't...
sent supout btw
Renato Bernardi
skype: medtech5
BrianHiggins
Long time Member
Long time Member
Thu Oct 30, 2008 6:23 am
I have seen few oddities with the new package (but still overall love the improvments!)
we have a tower that has two 900mhz 120 deg h-pol sectors, one is powerd by a SR9, the other by a XR9, both are in 5mhz channels, on opposite ends of the 900mhz band.
If we install the new test package on either of the APs, all radio links on the other AP not running the test package immeaditly become unstable and have trouble even connecting. removing the test package from the SR9 AP on 907 mhz fixes the connection problems on the XR9 AP on 922 mhz (both are in 5mhz channel mode).
Haven't been able to get it to work stabily on a 333 yet, haven't tried the new new package, will give that a try tomorrow.
EDIT (forgot to include the 2nd odd issue):
When a SR9 CPE is idle, it (or all CPEs on the AP) will momentarily disconnect / reconnect after a few hours, but if you launch a ping test to a CPE (even if it was previously only staying connected for a few minutes at a time), it will not disconnect at all for at least 24+ hours (have tested 2 seperate CPEs over a 24 hour period each).
It seems there may be some minor bug in the new package that causes radio's with little or no traffic across them to drop, and it seems that it happens to nearly all of the CPEs at the same exact time, except the one with a constant ping test running against
0ldman
Thu Oct 30, 2008 8:52 am
So far, so good. 5GHz backbone, 2.4GHz and 900MHz AP, all's well. Jitter is almost gone, ping has improved greatly all the way across the board, just like before I enabled Nstreme.
I can ping google at 11ms (was 35 on average) and my farthest CPE, two hops, 14 miles at < 5ms.
postmanerk
Thu Oct 30, 2008 11:45 pm
First, GREAT improvements on the NStreme package. Lower ping times (100ms to 20ms or so with 50 clients). Major improvements. Jitter is still not totally consistent, but better.
I am seeing low up times (connectivity from clients). I have been on 3.10 and uptimes of days (30-80 days continuous). Now on 3.15 with the test package, I see maybe an hr then they all re-connect. Only a few stay connected at 1 hr or more.
Anyone else see low client connection times? Should I sent a support file?
Eric
Alessio Garavano
Fri Oct 31, 2008 1:26 am
With wireless-test package the remote nodes of my mesh network are disconnecting continuosly....
I have an RB600 with 3 5Ghz cards(2xR52H-1xXR5) like the backbone of the net, the disconnect problem is continuosly with the older test-package and with the new builded 29/10.
Disabling the wireless-test and enabling the normal 3.15 wireless package all is stable and running perfectly
Alessio Garavano
0ldman
Fri Oct 31, 2008 2:39 am
My system is more stable. 5MHz channels, if it makes a difference.
uldis
Fri Oct 31, 2008 11:03 am
Eric
Yes, send the support output file to support@mikrotik.com when you see this problem with the wireless-test package. Make sure that you use the latest wireless-test package that is posted here in the forum.
chvdr
Fri Oct 31, 2008 11:29 am
what about polling interval at 5GHz-turbo. what should it be.
Best regards,
C. G.
If nothing to say, do not say anything...
All thoughts that have huge effect actually are simple...
mietus
Fri Oct 31, 2008 2:52 pm
quick question..
where is package for x86? :>
BrianHiggins
Long time Member
Long time Member
Fri Oct 31, 2008 4:24 pm
Eric - Check out my post here...
http://forum.mikrotik.com/viewtopic.php?f=7&t=27708
While testing the new package I came across something else, It was more a general NStream topic so I didn't think it should go in this thread, but it is definitly worth noting. Pay specific attention to the section about the SR9 CPE that wouldn't stay connected for more then 5-10 seconds while running the new test package...
Uldis: Can you confirm anything in regards to the Max Station Count and the new test package? It looks to me like the old package determines part of the polling algorithm on whatever this value is set to as it seems to have a dramatic effect on latency, does the new test package dynamically alter this portion of the algorithm to always match the number of CPE's connected or somthing similar?
peavys
Sat Nov 01, 2008 5:56 pm
On a troublesome 900mhz sector in a noisy environment with 12 clients it made a big difference. With or w/o nstreme in the past I had very bad latency. I don't see any other improvements, but the ping times quieted dramatically.
I've never considered nstreme a realistic option for pToMpt links in the past but I'll have to re-consider that. Unfortunately I've started deploying nano stations though, so it still won't be an option on most APs.
Clients still drop off/on just like they did before, and speeds are still the same. CPU consumption runs around 25%, but I did not note what it was before. I tried it with max station count set to 20 and 2000, and that part did not seem to make any difference.
Corky
uldis
Mon Nov 03, 2008 12:04 pm
please send the support output files from your routers where you have installed the wireless-test package to support@mikrotik.com so we could check how well it is working.
BrianHiggins
Long time Member
Long time Member
Mon Nov 03, 2008 6:42 pm
do you mean everyone who has it installed, or are you just referring to peavys?
tomswenson
Mon Nov 03, 2008 7:26 pm
I installed this package and turned on nstreme (I'm pretty new to mikrotik wireless, but not mikrotiks) for the first time and had nothing but trouble with disconnections, so I had to go off of nstreme. I didn't get any support files as I was in a panic to fix things. I used it on two ap's with about a half dozen users each.
Tom
0ldman
Tue Nov 04, 2008 3:38 am
Stability was down. One CPE that stays connected with a weak signal was virtually unusable with the test package.
uldis
Tue Nov 04, 2008 1:54 pm
I ment everyone :)
Alessio Garavano
Tue Nov 04, 2008 7:09 pm
With 3.15 and Wireless-Test my 25 remote nodes in 5Ghz are disconnecting continuosly. Each node is serving at 40-50 CPEs
Uninstalling wireless-test and with the 3.15 regular wireless package, the disconnection problem was solved, but the performance of the net is very poor at moments, i have 5 or 6 times on the day when the network is very slow 3000-4000ms pings to each remote node by about 10 or 15 minutes. Then all work great, but is a big problem.
Now i downgrade all my RBs to 3.13 and the network is again running excellent...
I think the problem is not only the wireless-test, the problem is the 3.15
Regards,
Alessio Garavano
uldis
Wed Nov 05, 2008 3:44 pm
If you upgrade to v3.16, then for the nstreme improvements you should enable the wireless-test package.
shoffmann
Wed Nov 05, 2008 5:21 pm
Just upgraded one of my sectors to the above package. I don't see any change from the 3.15 test package yet. While the upload and download are consistent on some others continue to associate and disassociate with virtually non-existent upload. Latency remains < 100ms on most during heavy traffic…that is except for the ones that are rolling.
support file sent
Steve
shoffmann
Wed Nov 05, 2008 5:59 pm
Further data on 3.16 wireless test package installed this morning
I find that the cpe's that are disassociating are fine and stay associated with download but have virtually no upload and associate/disassociate continually with upload. this problem is on a sector with 17 cpe's with the mipsbe board. Another sector with the same number of cpe's and the powerpc bd. works Great.
Steve
ropebih
Thu Nov 06, 2008 6:45 pm
Hi every1,
I have installed wireless-test package on my 3 Point to Point links and with that I solved problem with unstable ping (1 - 30ms). Ping is now max 3ms and I'm thrill but now I have new problem. Link is broken every 1 or 2 hours.
03:47:11 wireless,info 00:0B:6B:86:xx:xx@GLOBAL STOZER 2 - Bugojno: disconnected, extensive data loss
03:47:16 wireless,info 00:0B:6B:86:xx:xx@GLOBAL STOZER 2 - Bugojno: connected, wants WDS
05:00:16 wireless,info 00:0B:6B:86:xx:xx@GLOBAL STOZER 2 - Bugojno: disconnected, extensive data loss
05:00:21 wireless,info 00:0B:6B:86:xx:xx@GLOBAL STOZER 2 - Bugojno: connected, wants WDS
05:59:45 wireless,info 00:0B:6B:86:xx:xx@GLOBAL STOZER 2 - Bugojno: disconnected, extensive data loss
05:59:50 wireless,info 00:0B:6B:86:xx:xx@GLOBAL STOZER 2 - Bugojno: connected, wants WDS
06:07:13 wireless,info 00:0B:6B:86:xx:xx@GLOBAL STOZER 2 - Bugojno: disconnected, extensive data loss
06:07:19 wireless,info 00:0B:6B:86:xx:xx@GLOBAL STOZER 2 - Bugojno: connected, wants WDS
07:01:51 wireless,info 00:0B:6B:86:xx:xx@GLOBAL STOZER 2 - Bugojno: disconnected, extensive data loss
07:01:56 wireless,info 00:0B:6B:86:xx:xx@GLOBAL STOZER 2 - Bugojno: connected, wants WDS
08:44:13 wireless,info 00:0B:6B:86:xx:xx@GLOBAL STOZER 2 - Bugojno: disconnected, extensive data loss
08:44:18 wireless,info 00:0B:6B:86:xx:xx@GLOBAL STOZER 2 - Bugojno: connected, wants WDS
08:57:41 wireless,info 00:0B:6B:86:xx:xx@GLOBAL STOZER 2 - Bugojno: disconnected, extensive data loss
08:57:46 wireless,info 00:0B:6B:86:xx:xx@GLOBAL STOZER 2 - Bugojno: connected, wants WDS
11:02:59 wireless,info 00:0B:6B:86:xx:xx@GLOBAL STOZER 2 - Bugojno: disconnected, extensive data loss
11:03:04 wireless,info 00:0B:6B:86:xx:xx@GLOBAL STOZER 2 - Bugojno: connected, wants WDS
0ldman
Thu Nov 06, 2008 6:54 pm
I'm having the same upload problem with an RB600 with Crossroads clients.
ropebih
Sat Nov 08, 2008 10:37 am
on x86 with wireless-test:
10.10.60.9 64 byte ping: ttl=64 time=30 ms
10.10.60.9 64 byte ping: ttl=64 time=40 ms
10.10.60.9 64 byte ping: ttl=64 time=50 ms
with standard wireless package:
10.10.60.9 64 byte ping: ttl=64 time=1 ms
10.10.60.9 64 byte ping: ttl=64 time<1 ms
10.10.60.9 64 byte ping: ttl=64 time=10 ms
uldis
Mon Nov 10, 2008 12:37 pm
ropebih, please make support output file when you use regular wireless package and the also one when you use wireless-test package.
ste
Mon Nov 10, 2008 3:41 pm
Uldis,
will there be the possibility to do a mixed Nstream/Non Nstream Segment.
At the moment we use Nstream only for Backhaul links.
So when this new version is leaving test-state we want to switch to Nstream.
But we cannot migrate all clients at once so for a limited time we need to
run both modes at once.
Another (better) solution would be when clients (all MT) have a autodetection
and switch Nstream on/off as needed to connect to the ap. In this scenario
we would update all clients and then turn Nstream on at the AP.
Regards,
Stefan
uldis
Mon Nov 10, 2008 4:42 pm
currently it isn't possible.You should have nstreme or regular wireless link.
ropebih
Tue Nov 11, 2008 2:48 am
Done, I sent both supout files. I allso noticed that on wireless-test package clock is very fast. He's showing 10-15 secs in 1 "real" second
Muqatil
Trainer
Trainer
Tue Nov 11, 2008 1:33 pm
RB532 with 3.16 wireless-test:
Impressive improvement on connection... It's stable and excellent ping.. 100%CPU though...
RB333 with 3.16 wireless-test:
Good improvement on connections.. but it's too much instable... Clients keep disconnecting "Extensive data loss". When i rollback on wireless normal package, those Clients are stable. CPU 100%
RB532 got 2x AR5006X 802.11abg NIC (rev: 1)
RB333 got 3x AR5212 802.11abg NIC (rev: 1)
Renato Bernardi
skype: medtech5
uldis
Tue Nov 11, 2008 2:22 pm
Please provide us with the support output files from your RB333 where you see instability. We need one support output file with wireles-test where you see those disconnects and one with the regular wireless package that is running fine.
Also did you see this issue with v3.15 wireless-test package?
Muqatil
Trainer
Trainer
Tue Nov 11, 2008 5:10 pm
Sent.
If I recall correctly, there was a 3.15 package that worked pretty fine on RB333 but i updated it (and cancelt previous) that was similar to 3.16 one.
Renato Bernardi
skype: medtech5
tjohnson
Wed Nov 19, 2008 4:36 pm
Any more status on this? Any new updates?
Travis
Wavelan
Wed Nov 19, 2008 7:13 pm
Bug in 3.16 with wireless.test (X86)
bug in P4 hw :
1. system clock is 10 times faster than normal
Bug in wireless (XR5 & XR5)
1. Compression doesn't work, cannot connect in station-wds and bridge mode
if compression is enabled.
2. Erratic troughput. Goes from 33 Mbps, to 8 mbps, back to 30 mbps.
If we're change back to 3.14, troughput is stable around 33 mbps.
Thank's
//Robert
acim
Thu Nov 27, 2008 11:51 am
Same in my case, x86 Core2 Duo. Clock is much faster, although ping seems to be smaller and performances better. Can you resolve this with clock, please? I will let you know is something else goes bad.
acim
Thu Nov 27, 2008 12:29 pm
Because of broken clock, other time related matters are also broken, for example bandwidth test, interface traffic meter and so. Please fix this ASAP, otherwise new package seems to work really better, specially pings.
normis
Thu Nov 27, 2008 12:31 pm
new build seems to have fixed the clock, everyone with clock problems, please report to support, you will get the new version
acim
Thu Nov 27, 2008 12:42 pm
normis, how to get the new build? I've already reported to support, maybe I should just wait a little bit :)
normis
Thu Nov 27, 2008 12:47 pm
ask about new build that fixes clock issue :)
ejansson
Thu Nov 27, 2008 5:17 pm
I have seen the massive and fast disconnects too. I have rolled back to the regular 3.16 package and things were much better, I can send the .rif of both, but I need to flip it back to the test package. How much time do I need to let it run to capture enough data, I would like to minimize the customer impact.
Erik
uldis
Mon Dec 01, 2008 1:58 pm
We need support output file from regular v3.16 package and v3.16 wireless-test package.
Few minutes would be fine - so we could see in the logs what mac address disconnect.
cybernet
Wed Dec 03, 2008 12:51 pm
Hi All, How many clients can connect to AP-Bridge with NSTREME test package? I use ROS 3.16 and wireless test package.
Muqatil
Trainer
Trainer
Fri Dec 05, 2008 4:54 pm
Did you change something in wireless-test-3.17-ppc.npk from 3.16?
Renato Bernardi
skype: medtech5
0ldman
Sun Dec 07, 2008 9:31 pm
3.17 test seems more stable and ping times have dropped.
Several customers on my 2.4GHz AP have 1 day + uptime, which I've only seen on rare occasion. Looks good so far.
acim
Sun Dec 07, 2008 10:51 pm
I would say that wireless-test 3.17 suffers from the same clock problems as previous versions. Otherwise, it might be better, but it should not be installed on SMP routers. Mikrotik, please fix this ASAP, we want to test wireless-test :D
uldis
Mon Dec 08, 2008 4:43 pm
in v3.17 the wireless-test package you can use the hw-retries setting for the nstreme also. This setting will work just like in the regular mode. For bad links - the bigger the hw-retries the higher possibility to get bigger latency, the smaller the hw-retries the bigger possibility to get disconnects with "extensive data loss". You can tune this setting to get optimal results in each case.
About x86 clock problem, we hope we will be able to fix it in v3.18.
tomswenson
Mon Dec 08, 2008 6:27 pm
I have a location with 3 3650 sectors. I have been watching this thread and testing the nstreme as I would like to use it if possible. Today, I took the 3.17 and wireless test and put it on one of the sectors with about 8 cpes. It all seemed to be fine. No one was reconnecting over and over like before. However, I found out that one of the other sectors at this location was now dropping and reconnecting some clients. I tried turning on the CSMA, but it didn't help. So, I switched off the nstreme for the sector I was testing it on and the other ap stabilized and is just fine now. The other two sectors are running 3.13.
Is the Nstreme not going to work in a multiple sector location or do I have to have it turned on in all ap's?
Tom
digicomtech
Tue Dec 16, 2008 11:39 pm
Uldis,
Regards,
Stefan
use a script to automagically switch on the client side:
/system script
add name="ChangeBand" \
    source=":local delais 5s\r\n:local liste 2.4ghz-b/g,2ghz-5mhz,2ghz-10mhz;\r\n \
    \r\n:foreach band in=\$liste \
    do={\r\n:if (![/interface wireless get wlan1 running]) do={\r\n/interface \
    wireless set wlan1 band=\$band\r\n:delay \$delais\r\n}\r\n}\r\n\r\n:if \
    (![/interface wireless get wlan1 running]) \\\r\ndo={\r\n    :if \
    [/interface wireless nstreme get wlan1 enable-nstreme] \\\r\n    do={\r\n  \
          /interface wireless nstreme set wlan1 enable-nstreme=no\r\n    } \
    else={\r\n        /interface wireless nstreme set wlan1 \
    enable-nstreme=yes\r\n    }\r\n}"
/system scheduler
add comment="" disabled=no interval=20s name="schedcheckWifi" \
    on-event=ChangeBand start-time=startup
Uldis, i got a many disconnect on x86 with wireless-test-3.17 package with this log message:
disconnected, too many poll timeouts
What does it mean ?
0ldman
Wed Dec 17, 2008 7:45 am
I'm picking up pieces of your script here and there, but the short of it, what does it do?
Checks for 20/10/5, nstreme on or off, etc, and I assume it stops once its connected?
Muqatil
Trainer
Trainer
Wed Dec 17, 2008 5:27 pm
I think i found a pattern of my issues with wireless-test
in Radios with a 10° Antennas, i have no problems at all.. and it makes an HUGE improvement onf stability and throughput. No matter which type of radios of RBs i use..
in Radios with 30° or 60° or 90° antennas, i'm experiencing disconnections of users with good signal and good ccq, and troublesome users are unable to connect at all (CPEs that already have a poor signal but stay connected with not big issues without wireless-test)
I sent a lot of Supout but they couldn't find the problem. (I didn't tell them which type of antenna i used)
Can anyone confirm this?
Renato Bernardi
skype: medtech5
acim
Fri Dec 19, 2008 3:29 pm
wireless-test 3.18 is working fine on Core 2 Duo for the time being.
acim
Mon Dec 22, 2008 8:34 pm
I still haven't noticed any discrepancy, everything is working fine, great pings 8)
Thank you MT :D
exe
Wed Dec 24, 2008 2:40 am
Did you include this improvements in:
http://www.mikrotik.com/download/wirele ... mipsbe.npk ?
Serbian Mikrotik Distributor - exeshop.rs
acim
Wed Dec 24, 2008 8:29 am
No, I am talking about wireless-test 3.18 which is not public available yet. It is working fine with multicore routers, no clock problems described in this thread.
Hansanet
Fri Dec 26, 2008 12:19 pm
Hi ,
Where can I get v3.18 packages , I woud like to test it.
exe
Sat Dec 27, 2008 4:02 am
My Analyze of 3.17 wireless package
I tested 3.17 wireless test package. It seems that there are problems: with clock, bandwith is very unstable, maximum 4M upload at Dual Nstreme Links, download is okay. It also has bad influence to other parts of network which is mikrotik based, so it become erratic.
Then, I tested 3.17 regular wireless package. I do not know if you implement here latest improvements, but news is very good! Great Work Guys!
Good:
1. Lower Ping: maximum 25ms on single Nstreme PTP, and most time it is 1ms...
2. No "eratic" influence to other parts on network, like before, especially those which have dual nstreme. Now you can use station wds in combination with single nstreme without a problem.
3. More stable bandwith on dual nstreme links.
4. Achieved 50Mbit/sec max at single nstreme ptp at low ping, which is very good.
5. No "sent deauth" problem as you can use station wds without risking to damage network.
Very Good Work!!!!!
Bad:
I will send this opinion to support.
CarulloS
Mon Jan 05, 2009 3:42 am
I posted this already in the wireless parent of this thread before I saw this... Just wanted to put it here too seemed like the right place...
Either my understanding needs adjustment or the option doesn't work as expected...
Using wireless test 3.17 on ap and clients i check and uncheck the default forward option on the ap and it makes no difference. Either way broadcast and normal ip traffic pass to all clients of the ap. From my understanding unchecking the DEFAULT FORWARD option would prevent traffic from passing from one client to another.
The AP is normal AP mode with default set to add all clients to wds bridge1 as well as the ethernet and wlan1 interfaces added... Make the ap act like any other trango etc ap just passing traffic from wireless to ethernet interface.
The clients are all station wds setup same as ap - one bridge eith ap added ad wds dynamically and eth1 and wlan1 added as well... again just passing traffic though to router behind the radio.
Thanks,
Scott
InoX
Mon Jan 05, 2009 4:22 am
Thanks,
Scott
I think the client will not see each other in Network Neighbour...but at IP level data will pass, ofcourse.
CarulloS
Tue Jan 06, 2009 12:07 am
They see each other with ip traffic and broadcasts (ie neighborhood list)
Gerard
Trainer
Trainer
Tue Jan 06, 2009 2:31 am
Did you see my reply in the other thread?
http://forum.mikrotik.com/viewtopic.php?f=7&t=28857
-Gerard
ropebih
Sun Jan 11, 2009 2:41 am
Wireless test package 3.18 have same clock problems as previous versions!!!
uldis
Mon Jan 12, 2009 3:00 pm
Please make the support output file and send it to support@mikrotik.com
Ayone else still have this problem or it is gone in v3.18?
Muqatil
Trainer
Trainer
Mon Jan 12, 2009 4:19 pm
Is it possible to have a pseudo-changelog of wireless test package? :o
Renato Bernardi
skype: medtech5
CarulloS
Wed Jan 14, 2009 5:47 am
In 3-18-test mipsbe hit reset configuration on wireless and winbox closes and it does not reset. Confirmed multiple instances of this behavior.
Scott
uldis
Wed Jan 14, 2009 11:35 am
Scott
I could not reproduce this problem.
Did the router create a autosupout.rif file, if yes then send it to support@mikrotik.com
ste
Thu Jan 15, 2009 12:43 pm
anyone using 3.18 wireless-test with nstream in production?
I do some tests in lab at the moment. Looks promising but I see strange
effects so I do not dare to use it in production.
I'm testing RB500 - (Ethernet) - RB411 -(WLAN)- RB600 -(WLAN)- RB433 - (Ethernet) - RB500.
Btest UDP from RB500 to RB500 gives 60MBit using 5GHz Turbo. Replacing the RB600 by a RB500 (399MHz)
gives 40MBit. RB600/500 is in AP/Bridgemode on both links.
Then I tried to use 5GHz without Turbo and I see strange effects. First I changed one of the links to
non turbo mode on both sides of the link. The connection do not establish again. I have to disable/enable
the wlan at the RB600 (Master). Then it ran for a while. I tried to limit data rate at the RB600. Same
thing. I've to disable/enable at the Master side. The client has 2 errors: "can not connect unspecified(1)"
and "lost connection not polled for too long". Also I see changing speeds of the bandwith test. Sometimes
one of the 2 links goes down and reestablishes.
Wireless conditions are ideal. I use Omnis (MARS) at the RB600 and change antenna gain until all signals are
between 40 and 60.
So if I would have a production system with this version I would not dare to change anything as the link
might not come up again.
Any other experiences to share?
Stefan
zaltec
Sun Jan 18, 2009 3:12 pm
I have "lost connection not polled for too long" error too when using 3.18 wireless-test if there are interferences, using regular package is working quite well, even multiple links on the same frequency. So it seems wireless-test is not very good if you don't have a clean spectrum, which in our area is impossible (usually we see at least 15-25 radios active on 5.5-5.7 ghz band).
Regards,
Giorgio
ste
Sun Jan 18, 2009 6:02 pm
Regards,
Giorgio
I've used it in house. Frequency usage shows no other equipment. If interference it's self-interference.
I used 5,5 and 5,7 for the 2 connections. All cards are R52.
Regards,
Stefan
ilius168
Tue Feb 03, 2009 3:29 am
Are these updates included in the latest ROS Version (3.20) ? Or do we still need to update the wireless-test package?
uldis
Tue Feb 03, 2009 4:23 pm
you still need to use wireless-test package if you want those new features.
ropebih
Sat Feb 07, 2009 1:10 pm
I still have a problem with clock issue. ROS 3.20 x86 celeron 1,7 GHz.
ilius168
Sun Feb 08, 2009 3:19 am
Just want to report failure to run nstreme using wireless test package on RB 600.
Works fine and great on RB 411A, RB 411AH, RB 433, RB 433AH and RB 333.
Supout.rif file sent to support.
Thanks and great job guys!
samcarney
Wed Feb 11, 2009 9:03 pm
how can I roll back to my 3.10 package? 3.20 isnt working welll for me. I downloaded 3.13 and would like to try that one.
uldis
Fri Feb 13, 2009 5:38 pm
Try to enable the multi-cpu option to yes.
uldis
Fri Feb 13, 2009 5:39 pm
what exactly isn't working?
upload the packages to FTP and exacure the downgrade command in the system packages menu.
infowest
Thu Mar 05, 2009 1:08 am
I've got this working on a point to point link, nice and solid, no problems (433ah's). Getting ready to roll another pair with 411ah's and R5H's. Not the best test bed, but glad it is stable.
Any updates on what's new in this, what we can expect performance wise, etc? Especially interested in how many nstreme clients we can expect to connect before running into polling overload.
thanks!
Randy
proggams2
Thu Mar 26, 2009 8:48 am
do we still need the wireless test package for 3.22 ?? or we use the normal wireless package (in 3.22) ?? what i mean is the new nstream technology.
uldis
Thu Mar 26, 2009 12:55 pm
You still need to use wireless-test package if you want to get those benefits that are discussed in theis topic.
Only if you install v4.0beta2, the wireless-test package is now regular wireless package.
angboontiong
Fri Mar 27, 2009 4:14 pm
Actually which version of the test package is reliable now???
And, how i going to have the test package? just a concern is, our link is in live network and easily running about 40Mbps, will it take risk if i load the say firmware??
iam8up
Wed Jun 03, 2009 10:30 pm
What is the minimum ROS version you need to apply the wireless-test package to see the ptmp improvements?
InoX
Thu Jun 04, 2009 3:30 am
Why do you think it's called a "test package"? Because it's a test package.
Stupid questions, get stupid answers.
infowest
Thu Jun 04, 2009 7:47 pm
I may be wrong, but I don't think there has been much change if any after 3.16.
We're using it everywhere now on 3.20-3.24 without problems, ptp and ptmp.
rpingar
Long time Member
Long time Member
Thu Jun 04, 2009 7:58 pm
i agree,
wireless-test should go to wireless legacy!
regards
ros
titius
Tue Jun 23, 2009 10:33 am
where can I get this wireless test packege?
chapex
Wed Jul 01, 2009 4:48 pm
Ubnet datacenter: bandwith transport
kabelfrei
Wed Aug 05, 2009 10:34 am
Regards,
Giorgio
Regards,
Stefan
I have installed ROS V3.27 on a PtMP Installation (411A as AP; 1xRB532 Client; 1x RB333 Client; 1x RB433 Client) with wireless test package and got the same problems. Without nstreme enabled it worked. Also with nstreme enabled BUT Polling disabeld it worked. When nstreme with Polling is enabled, the 3 clients disconnects all the time (every ~10-30sec) with
AP-Log:
wireless,info 00:0B:XX:XX:XX:XX@wlan_xr5_ptp_sektor: disconnected, extensive data loss
Client-Log:
wireless,info 00:XX:XX:XX:XX:XX@wlan_r52_wka: lost connection, not polled for too long
We have also more then one Link on this location, but the next Links are on 5600 MHz and 5810 MHz.
Are there some additional config parameters needed on the AP side (perodic calibratio is on default (=disabeld), ANI is off)
thanks,
kabelfrei
kabelfrei
Wed Aug 12, 2009 9:18 pm
Nobody has an idea? I look at http://wiki.mikrotik.com/wiki/Wireless_Debug_Logs but i can´t find any entry for my Problem
thanks,
kabelfrei
acim
Wed Sep 23, 2009 2:26 am
There is still the same problem with wireless-test package from version 3.30 on some single CPU platforms.
Older Compaq desktop with 730MHz Intel III CPU runs clock 10 times faster.
Newer machine with Core2 Duo CPU runs clock normally.
Is it possible to fix this for all platforms, please?
proggams2
Wed Sep 23, 2009 7:25 pm
Does nstreme work with the XR2 in routeros ?? OR any wireless brand other than mikrotik ??
CarulloS
Wed Sep 23, 2009 8:17 pm
Yes but your post has nothing to do with this thread.
xezen
Long time Member
Long time Member
Fri Mar 05, 2010 4:49 pm
have problem in version 4.6
error comes up
lost connection,not polled for to long
using xr5 nstream and and rb433ah
If i dont No Ask someone That Does!
0ldman
Sat Mar 06, 2010 8:51 am
3.30 is still *slightly* more reliable on noisy or weak links than the test. Most of my network runs wireless-test. I have 4 customers that are stable but low signal strength, with test they are not stable anymore. With 4.x, I can barely get into the equipment to change them back to 3.30.
rmichael
Forum Veteran
Forum Veteran
Mon Apr 12, 2010 11:48 am
[quote="0ldman"]3.30 is still *slightly* more reliable on noisy or weak links than the test. quote]
Is that with Nstreme and pooling ON?
0ldman
Mon Apr 12, 2010 8:20 pm
With or without nstreme, polling, etc.
rmichael
Forum Veteran
Forum Veteran
Mon Apr 12, 2010 10:20 pm
For comletness: Point to Point or Multipoint? I'm asking as v4.5 nstreme does not work for me (WDS/PtM; XR9) and I'm looking for best alternative. At the moment I'm considering v4.5 at end points and v3.3 at the base...
thanks,
rmichael
Muqatil
Trainer
Trainer
Tue Apr 13, 2010 1:09 am
I'm deploying wireless-test since the first release and i love it,
it tolerates less the bad links (that's why you say the normal package is more reliable), but those links are working bad anyway. If you raise the hw-retries, you get the same result as the normal package.
About 4.x, i had some problems at the beginning. i found out that a reset-configuration of the wireless interface fixes all the troubles. Of course the link must be good! Otherwise raise the hw-retries once again and it becomes magically more stable, but with a awful jitter.
My links are all deployed with hw-retries=4 and if it doesn't work i go to fix it and replace with a better link.
Renato Bernardi
skype: medtech5
rmichael
Forum Veteran
Forum Veteran
Tue Apr 13, 2010 1:48 am
Thanks for the info. I did not think wireless config reset would work sice I upgraded boards to v4.x before configuring any wireless on them but I'll try it. I get unusable link ~500kbps with nstreme v4.5 on. Wereas I get ~12-20Mbps, >90 CCQ with nstreme turned off (not bad for 900MHz) I don't really need nstreme at this time (noise floor @89dB) however, we got MT product because of nstreme and frame protection so it better deliver.
Btw, my links work best with hardcoded ack timeout and I suspect auto ack feature of nstreme makes it unstable.
0ldman
Tue Apr 13, 2010 11:30 pm
4.x didn't make unstable links worse. -77 @ 24mb 90% CCQ dropped to 11mb with 20% CCQ. I wouldn't call -77 an unstable link. This is after the interface reset and reconfigure.
Also, hw retries made no difference on 3.30 vs 3.30 test for me. I set them to 15. Got a few customers I need to swap to 900MHz.
I've got a few customers on 4.x that work fine, most do not. I am running 4.3 on two different AP's. Both seem to work fine. It seems the difference is in the client side and I don't know enough about it to tell you what the difference is.
rmichael
Forum Veteran
Forum Veteran
Mon Apr 19, 2010 4:39 am
So far I tested (WDS) AP v3.30 +wireless test and Stations v4.5 and results are the same as with v4.5 for all - as long as SNR is > 28 link is stable, speed around 35Mbps. Lower SNR requires unchecking higher rates otherwise link disconnects during large data transfers. Logs show either no pooling or excessive data loss as a reason for disconnect.
PS.: interestingly, when I reset the wireless settings on AP (after moving from v4.5 to v3.3), as tgrand suggested, and CCQ went from 30 to 100%...
Users browsing this forum: No registered users and 34 guests
