MUM Europe 2020
GuJack20
Trainer
Trainer
"router was rebooted without proper shutdown (cause 1)"
Wed Oct 29, 2008 10:54 pm
What does this mean?? It is a RB333 and i tried also to upgrade the firmware... This didn't solve this..
Does anyone have a clue about this??
--Do you remember that guy who gave up? Neither does anybody else!
Caci99
Re: "router was rebooted without proper shutdown (cause 1)"
Sat Nov 01, 2008 10:50 am
I've seen there are others with this problem, take a look at these previous threads
http://forum.mikrotik.com/viewtopic.php ... it=cause+1
Judging from this discussions looks like this is related to RB333 only, and to its
specific feature of monitoring the health (voltage) of the routerboard.
Maybe is there something wrong with health monitoring, that's why it wasn't
implemented anymore on others RouterBoards?
But what about RB333? Can be introduced an option to disable this option
in case we experience such problems?
-Toni-
Don't crash the ambulance, whatever you do
schtaaf
Sun Nov 09, 2008 5:47 pm
Hi, I got this message today with my RB600R. Seems like there is a serious bug somewhere. Where are the Tech People?
normis
Mon Nov 10, 2008 1:36 pm
either you have a kernel panic, which makes the 'watchdog' reboot the router, or something else unknown. make sure you run 3.17, and Bootloader 2.18 and if it continues, make a supout.rif file immediatelly after it reboots, then send to support
omidkosari
Trainer
Trainer
Mon Nov 10, 2008 3:21 pm
3.17 ?!
normis
Mon Nov 10, 2008 3:31 pm
sorry 3.16
Caci99
Mon Nov 10, 2008 5:02 pm
Hi Normis, is the solution you recomed related to the RB600 or to the RB333 as well?
-Toni-
normis
Tue Nov 11, 2008 10:26 am
It's not a solution, just an idea that you can try.
Anyone who experiences this issue, PLEASE make a supout.rif file IMMEDIATELLY after the router boots after reboot.
JetCat
Fri Nov 21, 2008 9:17 am
I have a same problem. Routerboard RB333 with 3 CM10 cards, OS 3.16 , fw 2.18. Sometimes it works a few hours, sometimes two minutes than "cause 1" and reboot. When I switched watchdog off than routerboard stopped working totally.
normis
Fri Nov 21, 2008 9:20 am
send to support, not forum
highonsnow
Thu Mar 26, 2009 6:23 pm
Unfortunately we've experienced this also on an RB600 in our network.. we're keeping an eye on it
normis
Fri Mar 27, 2009 1:09 pm
remember that "rebooted without proper shutdown" can be caused by any number of things. hardware failure, power outage or kernel panic. this is a very generic message
Caci99
Fri Mar 27, 2009 1:53 pm
Yes of course Normis, but in this case we are talking about:
and this cause 1 is the question, what is it?
I have noticed this happens on routerboards with powerpc CPU,
both RB333 and RB600
Thank you, Toni
-Toni-
normis
Fri Mar 27, 2009 2:51 pm
cause 1 = no cause, generic error :)
highonsnow
Fri Mar 27, 2009 3:02 pm
I was wondering... I couldn't find it in the documentation http://www.mikrotik.com/cgi/search.cgi? ... s/ros/3.0/
Caci99
Fri Mar 27, 2009 11:02 pm
:lol:
-Toni-
highonsnow
Fri Mar 27, 2009 11:12 pm
Albania eh? I have to say I loved Tirane..
Yea... It's a bit of a conundrum, A cause being no cause :)
Caci99
Sat Mar 28, 2009 11:20 am
Highonsnow, i have to agree with you in this case, I love Tirana too :)
Best regards
-Toni-
flower
Sat Apr 06, 2013 10:48 am
In my manner I am using the RB450G, i am also phasing the same issue. But I observed it finally it solved. folder.exe virus in the network. loop is forming and the switches is blinking heavily. When i removed the virus in clients. no problem at all.
my network is safe and my RB is safe.
STP is enabled in RB's may be it will solved, if the virus is in the network.
And one more thing is somebody told with high voltage problem, it's also one of the problem may be, i am not say accurately..
I don't know about that.
Once check every one..
bluestu
Sat Aug 02, 2014 11:58 pm
We've had this issue on a 1100AHx2 so we replaced with a CCR1036-12G-4S and the same issue happens. I've sent a support.rif through to support from straight after it happened on the CCR. Fingers crossed we can get to the bottom of this as it's a serious, serious flaw.
lsettembri
Wed Oct 15, 2014 3:58 am
Have you found a solution? I have the same problem with a 1100AHx2, and can't solve the problem.
ondercsn
Tue Jan 20, 2015 1:13 pm
I had this problem, too. After spending my whole a weekend found that the problem source is adapters and POE Switch. Changed the adapter of POE Switch and pluged in the antennas directly to power supply. and it's solved. happy end
osamakalad
Thu Mar 03, 2016 7:07 pm
Users browsing this forum: MSN [Bot] and 85 guests
