vipe
3.17 Problems
Tue Nov 25, 2008 7:54 pm
:D :D :D :D :D :D :D :D :D :D :D :D smilies
thank you fixed the bug
cartes
Re: 3.17 Problems
Tue Nov 25, 2008 9:06 pm
Could you be elaborate on what problems this version is supposed to have fixed? Your graphs were not very clear.
Thanx in advance for your input.
Regards
HASSAN
Chupaka
Re: 3.17 Problems
Wed Nov 26, 2008 12:33 am
3.17? (O_o)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
janisk
Re: 3.17 Problems
Wed Nov 26, 2008 1:21 pm
where did you read that it is fixed? and where did you download 3.17?
vipe
Re: 3.17 Problems
Wed Nov 26, 2008 6:43 pm
3.6-3.16 from the version of the
Plans to run two missions a day are problems
For example:
/system script add name=e-backup source={/system backup save name=email}
/system scheduler add interval=1d name="test" on-event=e-backup
Two back-up
imtrulylovd
Re: 3.17 Problems
Wed Dec 03, 2008 12:02 am
Probably support sent the version to the user. Please first notify them at the support e-mail, and then post test results here as well, for community discussion and group effort problem solving.
parrini
Re: 3.17 Problems
Wed Dec 03, 2008 3:30 am
Regards
HASSAN
The graphs are clear, with a 6 day uptime and the job scheduled to run every 24h, there should be only 6 "Run Counts", the image shows 12 runs...
So, fixed in 3.17(or whatever)? Really?
airstream
Re: 3.17 Problems
Sat Dec 06, 2008 1:29 am
This scheduler bug has been around for most of v3! see: http://forum.mikrotik.com/viewtopic.php?f=9&t=22675 it can have a snowball effect if your 24hr or even 48hr timed scripts call other scripts in their runtime - you will end up with the same script running twice concurrently and on some occasions this will crash a V3 router.
17 sub releases and this is still a big problem. I wrote to support at V3.6, V3.11, and 3.15 the replys were "it will be fixed in a future release". How many releases exactly? will this be fixed before V4?
Keep tryin' its bound to work!!
ROOT@COSMOS> Reality.sys corrupted -- Reboot Universe (Y/N)?
>_
parrini
Re: 3.17 Problems
Sat Dec 06, 2008 2:29 am
I read somewhere that this problem only appears when the script is scheduled to run in a round time, finished with :00 minutes. A workaround would be set the script to run at broken times like 13:01 pm instead of 13:00 pm. I don't use scheduled scripts so I can't tell if this is true but doesn't hurt to try... :)
airstream
Re: 3.17 Problems
Sat Dec 06, 2008 2:48 am
Unfortunately this is not the case... Some of our scripts are scheduled to run 11:58pm and 12:04am etc but they still run twice.
We even tried running the same script via two separate schedulers each set at 2 day intervals but starting opposing days. Even at 48hr (2d) scheduler runs the script twice.
>_
interpoint
Re: 3.17 Problems
Sat Dec 06, 2008 10:24 am
I just upgraded an x86 router from 3.10 to 3.17 and it factory defaulted the config ! :(
I am downgrading and restoring from a backup now.
Shane Hartigan
Director - Integrated Media Solutions
MikroTik Certified Trainer
MTCNA, MTCRE, MTCWE, MTCINE, MTCTCE, MTCIPv6E
omidkosari
Trainer
Trainer
Re: 3.17 Problems
Sat Dec 06, 2008 11:11 am
Me too . :shock:
interpoint
Re: 3.17 Problems
Sat Dec 06, 2008 12:10 pm
I was running Dude rc8 on the old machine and this appears as Dude 3.10.
The latest version of Dude is 3.00 and is not a beta version or a rc.
This is a bug as I had to "downgrade" to the latest version as Mikrotik refused to install the 3.00 version as 3.10 was installed eventhough 3.10 is older than Dude 3.0
I have restored from backup and recovered my router and all is now working on ROS 3.16 and Dude 3.0 :)
Shane Hartigan
Users browsing this forum: CZFan, mjezierski, Nevon and 198 guests
