jffowler
lower polling values
Tue Nov 25, 2008 10:33 pm
I'd like to lower the polling frequency for some servers, but it appears that 5 seconds is the lowest Probe Interval value. Is there a way to change this to every 1 second? (this would be helpful to troubleshoot a couple servers that infrequently have 1-2 second network connectivity issues).
I'm using theDude 2.2, but can upgrade if that'd make a difference.
AND THANKS MicroTik!!! TheDude is a great piece of software!!!
- Josh
Aug
Re: lower polling values
Tue Nov 25, 2008 11:37 pm
I'm using 3.0rc3 and if I go to settings for the device, the polling is selectable down to 1 second.
Aug
jffowler
Tue Nov 25, 2008 11:57 pm
Can you hit Ok, and it'll save it w/ that?
In 2.2, it shows 1 sec for me, but if I click Ok, it brings up an error saying "probe interval must be at least 5 seconds", and won't save the value until I fix it.
- Josh
normis
Wed Nov 26, 2008 11:24 am
I suggest installing version 3, but I'm not sure if you will be able to keep your maps
rebellion
Fri Dec 05, 2008 4:20 pm
- Josh
no, he can't hit ok, i'm using rc3, and minimum poll interval is 5 sec.
sky
Fri Dec 12, 2008 1:00 pm
I'm using 3.0, not rc.
Same here, there are 1, 2 and 3 seconds intervals, but they don't work, so minimal, that works fine, is 5 seconds.
jffowler
Sun Dec 14, 2008 11:47 pm
Thanks, everyone! Appreciate the responses.
Users browsing this forum: No registered users and 11 guests
