nenapop
Winbox "router has been disconnected"
Sun Dec 07, 2008 11:54 pm
I have some troble with my router.
When i try to connect from some other real ip on real IP of my routers real IP over winbox, it just just pop up the "router has been disconnected" window. When i try to connect over other ethernet port, it connect. I realy need to have a possibility to connect remoteliy from some other real IP so i can control my router.
Please help me, it is PC with Mikrotik OS ver 2.9.27
jwcn
Re: Winbox "router has been disconnected"
Mon Dec 08, 2008 12:59 am
Upgrade your ROS and stop using an illegal copy.
nenapop
Mon Dec 08, 2008 1:30 am
Not exacly the answer that i need....
NEEEXXXT
jwcn
Mon Dec 08, 2008 4:16 am
That is the only answer you will receive here. Normis, this topic needs to be locked.
Equis
Forum Veteran
Forum Veteran
Mon Dec 08, 2008 7:43 am
Ok, how bout Upgrade your ROS and stop using an "outdated" copy.
normis
Mon Dec 08, 2008 8:52 am
Make sure you are not using the MAC winbox connection, as this is very unstable. And also please upgrade, because if there is a bug, it's already fixed a long time ago.
Users browsing this forum: Yeehaa and 84 guests
