Belyivulk
Xen: failed to copy files to image
Mon Dec 08, 2008 4:28 am
Hi Guys,
When trying to make a routeros image file with Xen i get the error 'failed to copy files to image'. Does anyone have any idea on how to fix this or am i missing a step? I'm reading directly from the Wiki.
Cheers in advance
Normis - the thread was right here since earlier.
janisk
Re: Xen: failed to copy files to image
Mon Dec 08, 2008 10:37 am
what command did you use, what version?
try something like
/xen make-routeros-image file-name=asdfg file-size-128
if you do not specify size, it can fail.
also, you can try with smaller file size, but take in account, that you wont be able to expand it later on. Also, 64 Mbytes would be enough.
Belyivulk
Mon Dec 08, 2008 10:42 am
Hi Janisk,
i tried that and got this
[admin@MikroTik] > /xen make-routeros-image file-name=asdfg file-size=128
So i'm completely lost still
Cheers
sever
Wed Dec 10, 2008 7:43 am
same thing here. I've tried it on 3.17 and 4.01b.
[admin@NEW Genesis BCU] /xen> make-routeros-image file-name=ros1 file-size=512
I can see it creating the file until it gets to completion of 512 size, then it throws the above error.
I have tried it on different x86 machines as well as changing the file size. Same error all the time winbox or command line.
Thanks in advance for any help.
J.
Belyivulk
Wed Dec 10, 2008 9:06 am
its good to know i'm not alone on this one
sever
Wed Dec 10, 2008 7:02 pm
My feelings exactly after spending a few hours on this issue. Nice to know I am not alone either.
So Janisk / Mikrotik? Is this a bug? What can we do to help?
Thanks in advance,
J.
sever
Thu Dec 11, 2008 3:49 pm
I sent e-mail with supout.rif file to support@mikrotik.com. Hopefully we'll get some info soon.
Meanwhile I have scoured the forum and not been able to find an answer.
I'll be sure and post mikrotik response.
Thanks,
J.
sever
Thu Dec 11, 2008 7:12 pm
I received a swift response to my email: :lol:
Thanks Mikrotik.
Hello Jay,
Yes, thank you very much for the report. We discovered that it is not possible
to create an image on 3.17, we will try to fix it. Currently you may try to
use 3.13 version for Xen, it should work there.
Regards,
Sergejs
I will be trying that ASAP. I will post my results shortly.
J.
Belyivulk
Thu Dec 11, 2008 10:04 pm
And i will watch closely for your results
janisk
Fri Dec 12, 2008 10:18 am
it is fixed - wait for next release.
sever
Sat Dec 13, 2008 2:45 am
I did try downgrading to 3.13. Unfortunately... did not work. Same results. :(
I am waiting patiently for new release.
Janisk, any idea when the fix will be released?
Thanks,
J.
sever
Sun Dec 21, 2008 9:58 pm
Hello Mikrotik......?
Sergejs in Tech Support mentioned in an email a new ROS release upcoming that fixes the "Xen bug" in 3.17.
Any idea when that is forth coming?
Thanks Mikrotik for all of your hard work and time producing a reliable product that allows me to "provide" for my family.
Merry Christmas!
j.
janisk
Mon Dec 22, 2008 9:01 am
there is no ETA yet.
tete
Tue Feb 03, 2009 3:08 pm
I have had the same problem on ROS 4.0Beta1
Antonio Sanchez
System Administrator
Granada (Spain)
janisk
Tue Feb 03, 2009 3:30 pm
working on 3.20
if you want to check if it is working - try the newest available version.
tete
Tue Feb 03, 2009 5:35 pm
Ok
I have installed 3.20 and the problem is solved.
Now I have other error.
When I try to create the new VM it says in the status "failed to setup VM".
Any Idea?
Greetings
Antonio Sanchez
Granada (Spain)
janisk
Thu Feb 05, 2009 1:23 pm
check your memory usage - reduce for memory for host, leave some 32 or more MB for hypervisor and then assign memory to VM, then everything should be fine
tete
Thu Feb 05, 2009 6:54 pm
This did not resolved the problem.
The situation is this; I have VMWare Server 2.0 installed for testing evironment. I this server I have installed a Level 0 version of ROS 3.20 using the ISO file.
The Mikrotik VM has 512 Mb of RAM and 1 GB HD.
I configure the Ethernet interface to get into the mikrotik. Then in /xen I created a ros.img with 64 mb. It is created correctly and I setup memomry to unlimited.
Then I create a VM with this ros.img 64 M of ram and console server port 64000, CPU 1 and weight 256. I press OK an then the same error appears. "Status: Failed to setup VM"
There is enough memory amount to run the VROS.
Greetings
Antonio Sanchez
Granada (Spain)
tete
Fri Mar 06, 2009 8:32 pm
Hi all,
After our MUM visit, we have deployed a fresh CF with a L4 Licence on a PIV with 1Gb of RAM.
I have follow the Wiki instructions line per line and no results. The status bar of the xen window stiils saying "Failed to setup VM" after enable this from console.
The system is running ROS 3.20 for INTEL/AMD.
Any Ideas?
Greetings
Antonio Sanchez
Granada (Spain)
dssmiktik
Forum Veteran
Forum Veteran
Wed Jul 01, 2009 1:27 am
Same thing here. Followed steps exactly from wiki.mikrotik.com and error "failed to setup vm". I'm using ROS 3.25. I have plenty of memory and disk space. Every single step went fine except when trying to enable the VM.
Mikrotik, why is this happening? Are we the users to blame? Has this feature been tested? Can we get a descriptive reason as to why this might be happening?
Doug
Chupaka
Wed Jul 01, 2009 1:47 pm
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
dssmiktik
Forum Veteran
Forum Veteran
Wed Jul 01, 2009 11:51 pm
I know it says that, but there should still be a reason? If it's a bug, I understand, but I'm just curious why it's happening. I've heard alot of users success with Xen, so I though I'd give it a try.
Doug
tombrdfrd66
Thu Jul 02, 2009 2:46 am
How about shifting this thread to the 'Metarouter and Xen' forum where it belongs?
I've noticed that with v3.16 I get the "failed to set-up vm' report, but the VM will still start and run.
The more I know, the more I know I don't know.
dssmiktik
Forum Veteran
Forum Veteran
Fri Jul 03, 2009 8:28 am
Is it not better to post problems here (as well as support with Mikrotik) as maybe someday the software will move from (alpha,beta) to stable?
I think Mikrotik is doing a great job and these forums are for Mikrotik users to help each other out and help make Mikrotik a kick-ass product. If you never test and report on alpha/beta software how is Mikrotik going to make it better? The only reason they choose to put Xen on their site is so people could test it and help make it into production software.
My 2 cents, sorry for the rant,
Doug
omega-00
Sun Dec 20, 2009 6:01 am
I've been running v4.3 and creating some test xen images. What works one time doesn't always work another and if I simply repeat the command it works.
admin@MikroTik] /xen> make-routeros-image file-name=ros32.img file-size=32
[admin@MikroTik] /xen> /
[admin@MikroTik] > file
[admin@MikroTik] /file> print
 # NAME             TYPE             SIZE                 CREATION-TIME
[admin@MikroTik] /file> ..
[admin@MikroTik] > xen make-routeros-image file-name=ros32.img file-size=64
  status: finished
[admin@MikroTik] > xen make-routeros-image file-name=ros32.img file-size=128
failed to create image
  status: finished
[admin@MikroTik] > xen make-routeros-image file-name=ros32.img file-size=32
[admin@MikroTik] >
nz_monkey
Tue Jul 19, 2011 7:21 am
I too am experiencing this problem but with RouterOS 5.5 and KVM.
/kvm make-routeros-image file-name=ros-kvm1.img file-size=64
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
mersudin
Sun Nov 27, 2011 3:18 am
i tried using and still trying to use it. u should try setting memory something like 16MiB or something less untill u see status: running, i have 768MiB RAM for host mikrotik 3.30 and unable to use more than 43MiB for CentOS 5.1 image, it just seems to limit memory usage on something else other than MemoryforMain set to Unlimited.
mersudin
Sun Nov 27, 2011 8:20 pm
after playing around with RoS version i came to conclusion that Mikrotik 3.19 works best for x86 xen.
janisk
Mon Nov 28, 2011 1:19 pm
on x86, install 5.8 (or latest :) ) and try to see if you still have a problem. Then send supout.rif
XEN problems will not be fixed ever.
mersudin
Thu Dec 01, 2011 2:56 pm
VmWare Esxi would be best but i tried to be cost efective since i have only need to keep freeradius and mysql services and that is more than enough for xen hypervisor :)
janisk
Thu Dec 01, 2011 4:15 pm
Esxi cannot be integrated as part of RouterOS. It is known that free version of Esxi is working ok with RouterOS.
mersudin
Fri Dec 09, 2011 4:00 am
been there done that (in my case keeping entire lower end server was to much power hungry), and i don't know who made centos image for Xen but there is and error made as module alias for eth0, in /etc/modprobe.conf first line " alias eth0 ne2k-pci" should be "alias eth0 xennet" and if module xennet not found its located in /lib/modules/[uname -r]/kernel/xen/drivers/netfront/xennet.ko just run insmod path_to_xennet.ko and it should load it up and virtual interface is running between virtual machine and mikrotikOS. I know that KVM and hardware virtualisation on any other hypervisor is good performance but not cost effective for some basic services as php,mysql,radius. is there any why to install xen-3.19 on 3.30 system i know it's stupid but there where some npk tools on net to edit npk files signatures , stupid and probably illegal :) ,as it seems there is only problem with xen package on 3.30, wireless driver is better than on 3.19.
Users browsing this forum: arm920t and 62 guests
