ddavis
Not getting down email notifications with Dude 3.0
Mon Dec 08, 2008 5:56 pm
I don't seem to be getting notifications when things go down, only when they come up. This has been a problem for previous versions I've used (3.0 beta 8). Anyone have any ideas?
rebellion
Re: Not getting down email notifications with Dude 3.0
Mon Dec 08, 2008 6:08 pm
add "unstable->down"
bellis
Mon Dec 08, 2008 7:06 pm
and unknown-> down
"If it ain't broke, you're not tryin"
sdrenner
Thu Dec 11, 2008 5:41 pm
I have the same issue with not getting down only up.
If I add unstable>down I get email within a minute, I don't want unstable>down
I want down after 5 minutes.
which is how I have it set up for.
rebellion
Thu Dec 11, 2008 7:33 pm
oh man...
configure your pollings timings. section probe down time and probe down count
and by the way
you r have lot of packet loss?
sdrenner
Fri Dec 12, 2008 6:02 pm
Seeing how no one knows out to explain this I will try:
If you want to receive notice that something is down you need to look first at how the Dude looks at the status of a device.
Here is the order of things
1st 2nd 3rd
Up -> unstable -> down
So if you want notification when it's unstable put a check next to: up -> unstable
if you want notification when it's down you would put a check next to: unstable -> down
and for when it's back up from down you would put your check next to: down -> up
or for when it back up from unstable put your check next to: unstable -> up
I only look for Status of Down and then back up.
So I only have checks next to
unstable -> down
down -> up
Users browsing this forum: No registered users and 6 guests
