piotrjamroz
VPN PPTP configuration on RB433AH ROS 3.17 problem
Thu Jan 15, 2009 12:25 am
Hello guys!
I have a problem with my VPN configuration.
I'm usung RB 433AH with ROS 3.17.
I'm trying to get access to my LAN (172.20.0.x / 24) using VPN connection.
I configured eth1 on RB with LAN address (172.20.0.250), and I added eth2 public address (83.3.251.75/29), added default route, then I configured PPTP server.
VPN connection is working correctly (I can get inside LAN), but ONLY when I'm using other public address within the same subnet (i.e. 83.3.251.76/29).
The problem is, when I'm trying to connect via VPN from internet - it doesn't work (no connection).
Obviously I must have forgot about something, but what?? Would appreciate any suggestions.
Simple network diagram below.
piotrjamroz
Re: VPN PPTP configuration on RB433AH ROS 3.17 problem
Thu Jan 15, 2009 12:31 am
Here's the /ip route print detail output from my RB 433AH:
0 A S dst-address=0.0.0.0/0 gateway=83.3.251.73,bridge1
interface=bridge1,bridge1 gateway-state=reachable,reachable
distance=1 scope=30 target-scope=10
1 ADC dst-address=83.3.251.72/29 pref-src=83.3.251.74 interface=bridge1
distance=0 scope=10
2 ADC dst-address=172.20.0.0/24 pref-src=172.20.0.250 interface=ether3
distance=0 scope=10
3 ADC dst-address=172.20.0.253/32 pref-src=172.20.0.250
interface=<pptp-internal> distance=0 scope=10
piotrjamroz
Thu Jan 15, 2009 7:21 pm
Guys please, I really need some help with this.
sophal
Fri Jan 23, 2009 9:07 am
please read this link maybe can help u
http://forum.mikrotik.com/viewtopic.php?f=10&t=27382
Regards
Lor Sophal
lor.sophal@gmail.com
mrz
Fri Jan 23, 2009 9:16 am
route configuration is wrong
remove your current default route and add this one
/ip route add gateway=83.3.251.73
and is there any reason why public IP is on the bridge interface?
piotrjamroz
Fri Jan 23, 2009 9:50 am
As for using bridge interface - I have no particular reason for that. So I removed bridge interface.
In the mean time I upgraded to ROS 3.19.
It seems that in few cases I have managed to establish VPN connection to the router - but it was disconnected very fast.
I've changed default route configuration as You suggested. I'll check it out today.
Btw here's my log (before above changes):
(failed login attempt from internet)
jan/21 19:55:40 pptp,info TCP connection established from 83.4.129.165
jan/21 19:55:40 pptp,ppp,info <pptp-0>: waiting for call...
jan/21 19:55:46 pptp,ppp,info <pptp-0>: terminating...
jan/21 19:55:46 pptp,ppp,info <pptp-0>: disconnected
(successfull login from local subnet 83.3.251.72/29)
08:38:46 pptp,info TCP connection established from 83.3.251.77
08:38:46 pptp,ppp,info <pptp-0>: waiting for call...
08:38:47 pptp,ppp,info formInternet: authenticated
08:38:48 pptp,ppp,info formInternet: connected
08:38:48 pptp,ppp,info,account internal logged in, 172.20.0.233
08:38:48 pptp,ppp,info formInternet: using encoding - MPPE128 stateless
It looks to me as if VPN server was ok. But the problem is somewhere at routing level.
piotrjamroz
Fri Jan 23, 2009 10:50 am
Ok I can say that problem was solved.
mrz You were right, my default route rule was wrong.
Thank You for Your support :-)
Users browsing this forum: snagles and 149 guests
