Freman
Password Recovery - Ancient Install
Thu Jan 15, 2009 3:52 pm
G'day all.
I've dug up a flash disk with an ancient install of Mikrotik 2.9rc1 on it. No-one here can remember the password from back then. I don't suppose I can do a Net Install or something on it to reset the password and regain the use of the license?
normis
Re: Password Recovery - Ancient Install
Thu Jan 15, 2009 3:53 pm
Yes, reinstalling will reset config, but license should stay. I don't know about this old version though, I think you will need to purchase a new license to use v3. You need to find an installer from back then
Freman
Thu Jan 15, 2009 4:19 pm
Ooh, found a newer CF card, 2.9.43 - Same problem, tho, lost password we've gone through so many.
How do I go about it? Just drop the CF card into my laptop and tell NetInstall to install?
normis
Thu Jan 15, 2009 4:20 pm
yes, netinstall with unchecked "save config" will do it
Freman
Thu Jan 15, 2009 4:24 pm
I've plugged the CF card in, loaded up NetInstall, clicked on the drive, and nothing really has happened, all the software-id/key/save config fields are disabled.
Freman
Thu Jan 15, 2009 4:59 pm
Ah, that's sorted.
Another question, What are the upgrade rules? Can I take this 2.9.51 to 3.18?
Letni
Thu Jan 15, 2009 5:24 pm
Boot it up and check under /System License to find out what you can upgrade to.
-Louis
Users browsing this forum: Baidu [Spider], Majestic-12 [Bot], Psyx0, sindy, Znevna and 230 guests
