MUM Europe 2020
breazer
SMS Notification
Wed Jan 21, 2009 6:17 pm
Hi
Has anyone ever used SMS notification with The Dude.
I would like to send out an sms if our internet link goes down, I wont be able to use an internet sms gateway as there will be now link to it.
Regards
Breazer
lebowski
Re: SMS Notification
Wed Jan 21, 2009 7:27 pm
Are you going to have a phone connected to your dude server?
If your intenet connection is down how will you send sms?
Just create a new notification that executes a program.
That program sends the sms message to the phone that is connected to your dude server.
On that note I am sure you can run a dial up adapter from a batch job... if you want to dial into another ISP to send the sms.
That would be easier and cheaper if you have a dialup account already.
The batch job would look like this...
RASDial | FindStr /i "My Dialup" > nul 2>&1
If ErrorLevel 1 RASPhone -d "My Dialup"
HTH
hkunnana
Wed Jan 21, 2009 7:53 pm
I am currently using this setup:
A SMS gateway that accepts email and forwards it as an SMS message
A commnd prompt emailer that accepts arguments
I created a batch file that will formulate the message according to the input parameters, (Although I've faced difficulties passing arguments from Dude) anyway, I created few ready made messages that will be triggered as locally executed command.
Also you can follow up this thread for similar issue:
http://forum.mikrotik.com/viewtopic.php?f=8&t=29112
lebowski
Tue Jan 27, 2009 2:47 am
Hey hkunnana
How does your SMS gateway send a SMS message if the internet connection is down?
hkunnana
Tue Jan 27, 2009 7:18 am
Hey hkunnana
I am not using the Internet to send SMS messages.
I have an SMS gateway machine that was first connected to a cellular phone directly, and now it is connected via leased line with the local cellular communication company.
The SMS gateway is used by various applications in the business, and I am using it to send Network Alerts as well.
lebowski
Wed Jan 28, 2009 3:49 pm
Oh that is cool. We might do something like that in the future.
Thanks for your reply
SD
breazer
Wed Jan 28, 2009 4:09 pm
Hey hkunnana
What hardware you using for the gateway
hkunnana
Thu Jan 29, 2009 2:46 am
As for the SMS gateway, it is a normal PC with Windows XP on it, Actually I have two gateways now (one on a PC, and the other on a VMware machine)
It is not the hardware, it is the S/W (NowSMS)!
breazer
Thu Jan 29, 2009 1:42 pm
Thanks, How do you send the alerts from The Dude to the gateway
hkunnana
Thu Jan 29, 2009 5:46 pm
I think you should know how your gateway accepts requests. Actually I am not too deep in NowSMS s/w, all I know is that it accepts SMTP and http requests.
I was given an SMTP account for the network alerts and I use a mailing s/w that accepts arguments.
ckgth
Sun Feb 08, 2009 5:47 pm
Hello!
I have setted up Dude on my RB/433ah on Ros 3.20.
The Notification-Button shows only "execute locally", no "execute on server"! Why?
I can also send no SMS over my connected Gsm-Modem... With winbox and terminal "/tool smsm send" i can.
regards
Christian
Users browsing this forum: No registered users and 9 guests
