lcrhea25
Please Help!! Not reporting correct IP.
Mon Jan 26, 2009 4:42 pm
Most of our customers do not need real world ip's so we give all our customers private ip's. There are a few that need them though. Most work with how we do this but their are a few that have some problems because when they do what is my IP on the internet it is reporting the ip of our main router right before our internet circuit. We are giving these real ip's out in the NAT Firewall.
chain=srcnat action=src-nat to-addresses=x.x.x.x (real IP)
src-address=x.x.x.x (private IP)
chain=dstnat action=dst-nat to-addresses=x.x.x.x (private IP)
dst-address=x.x.x.x (real IP)
Can anybody tell me another way to do this so it will report the Real IP we assign to them or what else I need to do in addition to what I have already done.
Thank you!!!
SurferTim
Re: Please Help!! Not reporting correct IP.
Mon Jan 26, 2009 5:27 pm
I would try this:
add chain=srcnat action=src-nat to-addresses=xxx.xxx.xxx.xxx src-address=192.168.0.2/32
add chain=srcnat action=masquerade out-interface=ether1
This presumes the server's internal ip is 192.168.0.2
xxx.xxx.xxx.xxx is the public IP for that server.
Order is important in all entries.
Chupaka
Mon Jan 26, 2009 5:33 pm
I think it's because you use WebProxy, don't you?
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
lcrhea25
Mon Jan 26, 2009 11:39 pm
I would try this:
I tried that and it still doesn't report the ip we set them to. Also we are not running a WebProxy. Any other ideas???
Chupaka
Tue Jan 27, 2009 12:32 am
do counters on src-nat rules increase?..
please give us full export of NAT rules...
lcrhea25
Tue Jan 27, 2009 5:05 pm
Ok the first part is where I am masquerading all our private ips so they will work on the internet. The bottom part is where I am doing the one to one nats for our customers.
add action=masquerade chain=srcnat comment="" disabled=no src-address=\
10.10.2.0/24
10.10.3.0/24
10.10.4.0/24
10.10.5.0/24
10.10.6.0/24
10.10.7.0/24
10.10.9.0/26
10.10.9.248/30
10.10.9.252/30
add action=masquerade chain=srcnat comment=Reeps disabled=no src-address=\
10.10.2.248/30
add action=src-nat chain=srcnat comment="Leo Salas" disabled=no src-address=\
10.10.3.7 to-addresses=66.76.210.193
add action=dst-nat chain=dstnat comment="" disabled=no dst-address=\
66.76.210.193 to-addresses=10.10.3.7
add action=src-nat chain=srcnat comment="Dr. Bandel NAT" disabled=no \
src-address=10.10.3.6 to-addresses=66.76.210.194
66.76.210.194 to-addresses=10.10.3.6
add action=src-nat chain=srcnat comment="Dirk Abbott" disabled=no \
src-address=10.10.6.37 to-addresses=66.76.210.195
66.76.210.195 to-addresses=10.10.6.37
add action=src-nat chain=srcnat comment="Dawn Cato" disabled=no src-address=\
10.10.3.196 to-addresses=66.76.210.196
66.76.210.196 to-addresses=10.10.3.196
add action=src-nat chain=srcnat comment="Edward Smith" disabled=no \
src-address=10.10.5.23 to-addresses=66.76.210.197
66.76.210.197 to-addresses=10.10.5.23
add action=src-nat chain=srcnat comment="Graham Lane" disabled=no \
src-address=10.10.3.71 to-addresses=66.76.210.198
66.76.210.198 to-addresses=10.10.3.71
Chupaka
Tue Jan 27, 2009 5:21 pm
hmmm... didn't you see that below rules are not working (not counting any packets)? =)
all your users are just masqueraded - move all 'individual' rules above masquerade rules
lcrhea25
Tue Jan 27, 2009 5:55 pm
Wow it's always something simple. Thanks that did the trick it appears!! whatismyip.com is reporting correctly now. I'll have them try it for what that need it for now. Thanks again!
Users browsing this forum: Google [Bot], MSN [Bot] and 85 guests
