lcrhea25
Changing Users Speeds
Mon Jan 26, 2009 5:56 pm
I am using the User Manager for all my customer to authenticate pppoe. They are getting their IP and speeds from here. I'm am getting ready to give them all faster speeds. Is there a quick easy way to change all my users speeds in the user manager? It will take a while if I have to click on each user one at a time and change their speeds in there.
Thank you.
sergejs
Re: Changing Users Speeds
Tue Jan 27, 2009 10:03 am
Perhaps you can run some scripts from the console to modify,
tool user-manager user
settings, however new queues will be applied after HotSpot user logout and new login.
mknnoc
Trainer
Trainer
Mon Mar 09, 2009 10:51 am
can you give a sample script to do that?
Users browsing this forum: No registered users and 4 guests
