PreggieP
Blocking websites
Thu Feb 19, 2009 9:42 am
I've installed the web-proxy as per the example on the wiki, I would like to know if we could block websites from a text or spreadsheet file?
If this can be done, it would make my life much easier.
Kind Regards
Preggie Pillay
normis
Re: Blocking websites
Thu Feb 19, 2009 9:47 am
after you have added one or two block rules to your webproxy access list (and they are working), do the following:
1. command "/ip proxy access> export file=rules"
2. download that file to your PC and open with a text program
see how that file is made? all you need to do is add extra lines with other addresses. you can use a spreadsheet program to do this. the file can be imported with the "/import" command
PreggieP
Thu Feb 19, 2009 9:53 am
Thank you, not exactly what i had in mind, but it will work all the same.
Kind Regards
Preggie Pillay
normis
Thu Feb 19, 2009 9:58 am
if you can somehow automate the process of updating this file (like a Macro or something), then you can also make RouterOS auto-fetch the file and execute it with the "fetch" tool. It will download it from a webserver and run it.
PreggieP
Thu Feb 19, 2009 10:01 am
The "/import" command does not work, when i did a check it only lists export. I'm assuming i'm meant to do this at /ip proxy access
I'm Using v3.19
Kind Regards
Preggie Pillay
normis
Thu Feb 19, 2009 10:02 am
no, you should do "import" at root level
PreggieP
Thu Feb 19, 2009 10:16 am
I'm new at all this, how would you actual setup fetch rules
Kind Regards
Preggie Pillay
normis
Thu Feb 19, 2009 10:23 am
[admin@I] /tool> fetch address=www.mikrotik.com path=index.php
host=forum.mikrotik.com
status: connecting
status: downloading
downloaded: 7KiB
duration: 1s
this is something to use also:
http://wiki.mikrotik.com/wiki/Using_Fet ... ress_Lists
also you will be able to use this feature:
*) automatically execute uploaded scripts that have name *.auto.rsc;
