Montana
Terminal Mode acting Weird
Tue Mar 03, 2009 7:03 am
I have a RB333 located on a mountain top that has a Public IP address that runs ospf to several other RB's down in the valley. The problem that I have is that I have to access one of the RB's down stream but I cant view the contents from the terminal mode. I can get in to another RB333 or 532 down stream in terminal mode view that routers content and make changes. The new RB433 that I have installed down stream works and I can log in to it from terminal mode but I cant view its contents. When I tell it to "interface wireless reg" it just blinks once like it is doing something but doesnt show anything. I can move around inside the RB but it want print anything. What is going on?
jtech
Re: Terminal Mode acting Weird
Wed Mar 04, 2009 10:16 pm
I've found this exact issue with version 3.12 or 3.13. Upgrade to the most recent version and it goes away. The most obvious issue is with using MAC telnet...if you type IP ADDR PR it just scrolls through the print results quickly and doesn't actually display anything. An upgrade to at least 3.2 fixes it every time.
Cheers,
JTech
