rpengineering
Bridged Network to Routed Network migration
Fri Mar 13, 2009 3:47 pm
Dear,
I need to migrate from a bridged wireless network to a routed wireless network have you any guidelines to make the network reconfiguration?
Regards
Egate
Long time Member
Long time Member
Re: Bridged Network to Routed Network migration
Sun Mar 15, 2009 10:37 am
The best way is to change the ip's on router boards and access points, in order for routing to be able to work. Then activate routing rip on all your routers. This will sort your router paths automatically. To see if it is running go to ip routes. Should be many routes, getting more as you change router boards. As soon as this is done. Disable bridge. If done correctly, every thing should keep on running. Very easy. 8) Biggest thing is the ip's make a nice exel spread sheet.
Happy days. :-)
rpengineering
Mon Mar 16, 2009 6:19 pm
i aldeady know it.
I need configuration guidelines - examples.
Access point (wlan1 wlan2 ethernet) routes and firewall configurations
edge router configuration
ecc.
andreacoppini
Trainer
Trainer
Mon Mar 16, 2009 6:39 pm
i aldeady know it.
ecc.
For an overview on how you should approach it, go through Tiktube.com as I recall there was a presentation about this during one of the Poland MUMs, not sure which one though!
If you need specifics, please hire one of us here :D
- No strings attached -
<< Please give good Karma if this post helped you. Press the + button above the Location entry
rpengineering
Tue Mar 17, 2009 5:39 pm
Dear,
I' ve not founded the mum presentation,
Can you give me an hand to make this migration ?
Regards
andreacoppini
Trainer
Trainer
Tue Mar 17, 2009 7:25 pm
sure can help you with it.. send me a private message with your e-mail or Skype address
rpengineering
Wed Mar 18, 2009 3:09 pm
i'm sorry but i'm not able to send private message in this forum, i do not have private messages link
Chupaka
Wed Mar 18, 2009 11:41 pm
[offtop]
omg! they switched them off again =(
Normis, please, enable PMs =)
[/offtop]
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
rpengineering
Tue Jun 14, 2011 12:16 pm
Dear,
i've done the migration successfull..
using ospf and mpls for centralized pppoe.
it works very very well
goofy
Tue Jul 19, 2011 10:13 am
did you use VPLS?
rpengineering
Fri Jul 22, 2011 6:23 pm
yes, i use ospf, mpls , vpls
goofy
Fri Jul 22, 2011 11:24 pm
rpengineering,
What's your mtu?
I used some uplinks ubnt.
ubnt's support MTU 1518
it is not work on our network with ubnts, I think
virgin
Sat Jul 23, 2011 9:52 am
Cain i have ur email id....i also want to migrate bridge network to router network. Can u help me with that.
rpengineering
Tue Jul 26, 2011 1:10 pm
<goofy>
i use for internal routing mtik and for bbones ALCOMA or mtik and MPLS/VPLS works fine!!
rpengineering
Tue Jul 26, 2011 1:11 pm
Dear,
i can help you but
i've mp disabled please use my skype id alexrpeng
Regards
rpengineering
Tue Jul 26, 2011 1:12 pm
rpengineering,
What's your mtu?
My mtu is 1504
Users browsing this forum: benc1337, Bing [Bot], ChristopherFS, LSan83, LynxChaus, mada3k, RackKing, sfrode, XEEE and 104 guests
