pokeman
blocking windows sharing but how to allow ?
Sun Mar 29, 2009 2:47 pm
Hi there
I am using Wireless setup x3.17 RouterOS on network the user connect pppoe session. i created a rule in dhcp /32 "address=192.168.0.0/24 gateway=192.168.0.253 netmask=32 " for user blocking sharing now my user getting mask 255.255.255.255 . My Microsoft portal server on 192.168.0.4. perviously my user directly connected with my portal server . don't required to connect pppoe session . after subneting the portal not working . anyone give me idea what should i do ?
normis i recently purchase the 2nd licenses as your policy MT gives basic support. i submit the ticket for another issue but no response from your team
thanks in advance
pokeman
Re: blocking windows sharing but how to allow ?
Sun Mar 29, 2009 4:11 pm
currently my client download data from Ms-portal. local downloading are restricted with 64k . how can i exclude from limit
rmichael
Forum Veteran
Forum Veteran
Mon Mar 30, 2009 4:03 am
From docs:
Probably, you want to exclude the server from being limited, if so, add a queue for it without any limitation (max-limit=0/0 which means no limitation) and move it to the beginning of the list:
http://www.mikrotik.com/testdocs/ros/2.9/root/queue.php
Users browsing this forum: Google [Bot], MSN [Bot], r41nbuw and 131 guests
