MUM Europe 2020
vlada1
MPLS dont work with vlan
Tue Apr 14, 2009 7:37 pm
Router os is v3.22 standard mpls package is installed. ( not mpls-test)
when i add vlan interface in /mpls ldp interface router goes up to 100% for 5 minutes then back to 5 %
After that all http traffic got worse , but icmp ( ping and trace ) show that is all ok on the network.
I started turning off mpls until i come to network where i have vlans and when i disable mpls there all worked as before.
mikrotik team?
Chupaka
Re: MPLS dont work with vlan
Tue Apr 14, 2009 8:39 pm
use mpls-test package. it has all recent fixes and improvements
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Eising
Tue Apr 14, 2009 11:20 pm
Yeah, you shouldn't get scared by the mpls-test name. All development happens with it, and I've been pretty happy with it so far. I would actually say that 3.22 with routing-test and mpls-test is production ready, unless you rely on ospf sham-links.
The road to hell is paved with good intentions.
vlada1
Wed Apr 15, 2009 2:15 pm
No , even with mpls-test dont work
and one thing more on all RB433 with mpls or mpls-test http traffic work bad.
Mplsguy
Wed Apr 15, 2009 3:22 pm
Make sure that your setup fits in MTU limits of your hardware, see
http://wiki.mikrotik.com/wiki/Maximum_T ... uterBoards
Default mpls-mtu is 1508, also for VLAN interface. If packet gets labelled with 1 MPLS label and 1 VLAN tag, your hardware (routers and switches) must be able to transmit 14 + 4 + 4 + 1500 = 1522 byte packets (not counting FCS). Other than that, there should be no difference in running MPLS over VLAN interfaces.
vlada1
Thu Apr 16, 2009 10:32 am
yeah you right ,mtu is problem, on every mikrotik where is vlan or bridge interface mpls dont work as expected.
but yesterday i run same on cisco equipment and all worked fine.
and if this dont work , then i will use mikrotik only to bridge , ether or wireless and put cisco router behind for PE or RR.
what proof that mikrotik is not for profesional use
Chupaka
Thu Apr 16, 2009 12:09 pm
you are so funny =)
just decrease MTU to fit your hardware limits - and all will work fine ;)
fr4
Tue May 05, 2009 2:20 am
hi,
i have some problem with vlps, i have a lot of 433ah with 1522 mtu hardware limit i have understand that i need almost 1540 mtu for vpls, how i must set mtu in
/interface ethernet set ether1 mtu=?
/mpls interface set 0 mpls-mtu=?
/interface vpls set myvpls mtu=?
/interface bridge set pop mtu=?
/interface taffic-eng set te1 mtu=?
/interface pppoe-server server set 0 max-mtu=? max-mru=?
i need vpls for put in my network a pppoe concentrator and i put all vps in pop bridge in concentrator
i'm a bit confused thanks for any help
Bye Fr4
Mplsguy
Tue May 05, 2009 4:47 pm
The only thing you have to change is /mpls interface mtu (in your case - most likely to 1504, if you are not using also VLANs). VPLS will fragment packets according to it.
fr4
Tue May 05, 2009 6:26 pm
Thanks for reply :)
i have tried but i this problem :(
http://forum.mikrotik.com/viewtopic.php?f=14&t=31583
you have any idea for this ?
Bye Fr4
Users browsing this forum: No registered users and 12 guests
