mstead
Where Is Routing Test 3.23 For PPC?
Wed Apr 22, 2009 11:41 pm
Am I blind or is the routing-test package v3.23 missing from the PPC download. I am downloading the file all_packages-ppc-3.23.zip from MT.
Regards,
Malcolm
skillful
Trainer
Trainer
Re: Where Is Routing Test 3.23 For PPC?
Wed Apr 22, 2009 11:46 pm
Test packages are not included in all_packages. You have to download them separately from the mikrotik download page.
mstead
Thu Apr 23, 2009 12:05 am
Thanks for the reply. However if you click on the "view content" link for the above named file it clearly mentions routing-test as one of the contained packages. Can you see a separate link for routing-test-3.23-ppc.npk as I cannot?
Malcolm
Just to add - I did a bit of detective work and found it located at
http://66.228.113.58/routing-test-3.23-ppc.npk
But I still see no link for it. I just used the link for mpls-test and changed mpls -> routing!!
normis
Thu Apr 23, 2009 9:01 am
test packages are now included in the routeros big package. I will make sure the separate links are returned though
Users browsing this forum: Google [Bot] and 154 guests
