Mark66
Connect the same computer network through vpn
Fri May 01, 2009 11:43 am
I'm trying for days to find a way to create a type of network so that:
My situation is as follows:
pc1 88.137.199.30/24 through router1----> (to master router)
pc2 88.137.199.178/24 through router2----> (to master router)
(from clients) ---> Master Router gw 88.137.199.1 loopback----ether0======>INTERNET
Nota:
I'm thinking if you can use ipsec to connect the routers arranged in tunnel mode.
But I don't know how to do :(
Can you give me any idea?
Thank very much!
MarK
Egate
Long time Member
Long time Member
Re: Connect the same computer network through vpn
Fri May 01, 2009 12:54 pm
Have got no idea what your setup is you want. However, most important, make sure routing is correct. Every thing can ping each other. After that it should not be a problem.
Happy days. :-)
Mark66
Thu May 07, 2009 5:53 pm
I have solved!!!
Thank very much
Users browsing this forum: Bing [Bot], Majestic-12 [Bot], WarlitoBaya and 92 guests
