MUM Europe 2020
GERRYNET
mini-pci 802.11n mikrotik
Fri May 15, 2009 10:48 pm
finally something in 802.11n and Mimo Mikrotik
GERRYNET
Re: mini-pci 802.11n mikrotik
Fri May 15, 2009 10:55 pm
For more information check:
Search http://www.fcc.gov/oet/ea/fccid/
Grantee Code: TV7
Product Code: R52N
via:mikrotikexpert.com
Qusay
Sat May 16, 2009 1:49 am
Good work "even if I waited all these years to see it"
expunge
Sat May 16, 2009 2:43 am
Ahhhh... and the truth surfaces. They have had working 802.11n support for long enough to develop, test and validate these cards yet they say they don't have viable 802.11n support or that they're waiting for the final standards. Sounds like they'd just rather not have you use the SR71's. Bad move since I know a lot of people who would have rather used Mikrotik hardware with the Ubiquiti cards starting months ago but instead had to go to a complete solution from another provider.
Hopefully they'll have some results out soon. Maybe a release of RouterOS with some 802.11n support built in as well. Hopefully it was worth putting off customer demands in exchange for developing your own hardware. Regardless of how we've got to this point, at least we're finally close to ready for an 802.11n rollout with Mikrotik gear.
nz_monkey
Sat May 16, 2009 10:23 am
From all the tidbits recently it looks like 802.11n support in RouterOS is imminent, which is great news.
I hope that is not the production design.
Why ?
- It does not have MMCX connectors
- From the product name it sounds like it is dual band
I would prefer a design more similar to the Ubiquiti SR cards, with MMCX connectors and single band operation, e.g. R5N for 5Ghz and R2N for 2.4Ghz
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
maxster
Sat May 16, 2009 1:21 pm
I'll believe it when MT announce it.
Funny though; people already complaining about design flaws :-)
nz_monkey
Sun May 17, 2009 12:16 pm
Haha I'm not too fussed really, I just wouldn't be using the card shown above in outdoor installations as I consider the U-FL style connectors are just far too flimsy.
If they released a R5N similar to the R5H I would be a very happy man.
rainmaker
Sun May 17, 2009 1:31 pm
mmcx connector is the way to go mikrotik
GERRYNET
Mon May 18, 2009 5:27 pm
Among many things selected what I believe is the most interesting..
GERRYNET
Mon May 18, 2009 5:32 pm
Among many things selected what I believe is the most interesting...final
chvdr
Tue May 19, 2009 9:00 am
Did you actually tasted it.
Best regards,
C. G.
If nothing to say, do not say anything...
All thoughts that have huge effect actually are simple...
chvdr
Tue May 19, 2009 9:07 am
and where did you bought from
Best regards,
C. G.
GERRYNET
Tue May 19, 2009 3:57 pm
Mikrotik people he has sent the FCC a mini-pci card that works in MIMO to be evaluated technically and obtain approval of such an entity. The FCC is the Federal Communications Commission of the United States.
Is not yet on sale, there are no reviews available information, only what has been published and approved a few days to make the FCC, but according to comments in some forums said that Mikrotik is working internally with a module for the v4. 0 to work with this card MIMO, so we see what happens in the next few days
Via:www.mikrotikexpert.com
greetings
GERRYNET
roc-noc.com
Forum Veteran
Forum Veteran
Fri May 22, 2009 3:32 am
It was announced to distributors yesterday along with the data sheet and pricing.
http://www.roc-noc.com/pdf/R52N/R52n.pdf
Mikrotik has promised 802.11n support in ROS by the end of this month.
It looks like we are on our way!
Tom
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
meno
Fri May 22, 2009 8:09 am
in my local reseller they sell that miniPCI
nz_monkey
Fri May 22, 2009 2:26 pm
It will be interesting to see how this performs in outdoor environments.
titius
Fri May 22, 2009 4:51 pm
Can we use One antenna on AP side and ONE antenna on client side and use N standard?
chvdr
Fri May 22, 2009 5:35 pm
the question seems to be a bit silly, but we tested n card with one antenna. it works, but not propertly enought... such as 50% of usual card.
i do not recommend to waste a time to do such tests
Best regards,
C. G.
miahac
Long time Member
Long time Member
Fri May 22, 2009 5:53 pm
I guess I never checked if mimo would work in 5mhz/10mhz channels. I quit.
Network Administrator
Kansas Hosting and Wichita Data Centers
infowest
Fri May 22, 2009 6:55 pm
Don't bag on the UFL connectors too much. From what I've read, the MMCX, while more convenient / reliable / un-frustrating tend to act as stronger antennas causing more cross talk between themselves. I'm guessing the UFL connector was a concious design choice to allow better separation and less interference between the two connectors.
infowest
Fri May 22, 2009 6:56 pm
Anyone tested the new 4.0 beta (the one with MIMO support) with the UBNT cards?
nz_monkey
Sat May 23, 2009 2:42 am
Right, now that 802.11n is out of the way.... How about the RB616 ?
802.11n is nice, but what I really need is the RB616 with higher CPU speed, a little more RAM (or dimm slot) and really good layout so I can run R5H's in all 6 slots.
Imagine having an RB616 as a Distribution node. 200mbit 802.11n link back to your data centre and 5xR5H on parabolic dish. Or 802.11n to other distribution nodes, MPLS, a switch and RB433's out to your POP's.
tierpath
Sun May 24, 2009 1:11 am
N isn't out of the way, let it stabilize then work on this.
magnavox
Sun May 24, 2009 3:08 am
I tried UBNT SR71-A, but ROS seem not recognize it...
Best Regards...
InoX
Sun May 24, 2009 7:15 am
read the pdf...you must activate .n in ROS
magnavox
Sun May 24, 2009 10:18 am
Already activated...
Best Regards...
sonny
Sun May 24, 2009 3:01 pm
You wrote enable .n support, how can I do this? Which pdf?
Karl Sonnleitner
Senior Wireless-Expert
Restlesspowerbox - managed powersupply for Routerboards
dawam
Trainer
Trainer
Sun May 24, 2009 3:39 pm
* RouterOS 802.11n support
* PCC matcher
* SMP improvements
* MUM 2009
http://www.mikrotik.com/pdf/news18.pdf
Everything looks complicated to begin with, but it's surprisingly simple when you understand it.
GERRYNET
Tue May 26, 2009 8:18 pm
Some tests of 802.11n Mikrotikhttp://forum.mikrotik.com/viewtopic.php?f=7&t=32143
regards
Users browsing this forum: No registered users and 17 guests
