skermode
Setting Interface to blank
Thu May 21, 2009 9:26 pm
I am currently attempting to set the in-interface (and out-interface) of a Firewall NAT rule to blank. In WinBox, all you have to do is set the combobox to the blank option to achieve this. My solution requires using the api/terminal so I don't have the luxury of WinBox.
For example's sake, to set a port to blank, you send the value "0," and the router stores "" as the port. In addition, to set an ip-address to blank, you would pass "0.0.0.0," and the router often stores that as blank. Any time unit stored as a blank is set by passing a "0."
What is the "blank" keyword for interfaces (or in-interface, out-interface)? I have tried:
0, -1, all, none, null, no, n
All results return the same "input does not match any value of interface" error. If I submit a blank value, I get an "ambiguous" error. All I want to do is intentionally set in-interface/out-interface to blank.
The only way to leave it blank is to never send a value. I want to use an automated process to create firewall rules and I don't want to have to fine tune eight functions (4 for add, 4 for edit) when I can use just one.
Thanks for the help in advance,
Scott
changeip
Re: Setting Interface to blank
Thu May 21, 2009 10:57 pm
unset ?
skermode
Thu May 21, 2009 11:04 pm
That's what I'm using for my workaround at this time. I have a function that adds/edits rules and does not modify the sensitive ones (like in-interface). If applying a value, set it, otherwise unset. Seems like the only solution at this point.
Good minds think alike, eh?
Thank you for your input on this.
janisk
Fri May 22, 2009 10:46 am
unset is not a workaround.
either you set your value, that you think is default, or unset variable.
skermode
Fri May 22, 2009 5:30 pm
Janisk, so you're saying:
There is not way to set the in-interface to blank, only to set it to an actual interface (ex. ether1), or just never set it at all. Should I want to clear it, I still cannot set it to blank, I can only unset. It's not a workaround, it's the only way.
Sorry, but your comment was short so I needed to clarify :D
Chupaka
Sat May 23, 2009 9:09 pm
what is API syntax for 'unset'?
skermode
Tue May 26, 2009 4:28 pm
If the menu allows for unset, here is the api structure for it:
/.../unset=numbers=[api id numbers sep. by comma]=value-name=[field to unset]
for example
/ip/firewall/nat/unset=numbers=*1=value-name=dst-address
/ip/firewall/nat/unset=numbers=*1,*4=value-name=hotspot
Some menus will not allow it. For example, the /ip/address/ section does not contain a definition for unset.
Hope this helps.
(EDITED- Forgot to include "unset" command in my example)
Chupaka
Wed May 27, 2009 12:02 am
wow! It's working, thanks =)
taduikis
Thu Dec 07, 2017 2:58 pm
Sorry for bringing up this topic, but I’m currently trying to do the same: set in-interface to none for many dstnat rules via console. set X in-interface=“” doesn’t work. Is there still no way unsetting it without using api style workarounds?
Chupaka
Thu Dec 07, 2017 3:09 pm
/ip firewall nat unset 123 in-interface
where 123 is rule number from 'print' command
taduikis
Thu Dec 07, 2017 3:24 pm
I've accidentally found it on my own, but anyway thanks Chupaka. You're as always helpful :)
eezzaatt
Sun Jun 28, 2020 12:02 pm
Just put ! before the element that you want to be blank
check out this example where here I want to put blank value to "check-gateway" so it will be like this "!check-gateway" :
/ip route set [find dst-address=1.1.1.1/32] [u]![/u]check-gateway
Users browsing this forum: No registered users and 193 guests
