Try to use first only one chain and make the test and get that link stable working at max speed. then enable extended channel support to use 2 20mhz channels and try to get the max speed.
After that try the same with the other chain.
If everthing works, you can try to enable both chains at the same time. If that fails (unstable link) it means that the dual pol. antenna has some problems - interfernece between the both chains. If you have an option - try to use seperate antennas.
Have you tried use fixed data-rates? Some other posts say that the automatic datarate-selection doesHello @ all.
We are a small wisp in Germany. Im reading for a long time here in the forum. We have problems with N, too. The same Problem as chvdr.
Our Equipment at both Sites:
RB433AH + R52N + 2*30dBi Mars Antennas Flat Pannel (No DUAL!!) but in Dual-Polarisation (1 * hor + 1 * ver).
The 2 Antennas (H + V on both Sites) are mounted in a distance of 1 meter. The Distance of the 2 Points (AP and Client) are 11 Km.
The Line is TOP.
But the Results are the same as chvdr. Receive or Send allone are no Problems and the CCQ is at 95% - 100% TX and RX. Only when Traffic is set to both, the Link is breaking down. The Results are the same as chvdr. The CCQ is then at 3% - 4% TX and RX. We have all the settings tested but there is no better. I don't understand what the problem is becaus another user here in the forum have stable links with same hardware! We have the same Line with dual-Antennas tested but the same results with the others.
Are there any Mounting-defaults on the sites between the antennas?
Thanks for help.....
joban
tell us one reason to do that. As I told you before, we have actual link with the same antennas on 5GHz. Bonded cards xr5. Also, we use antennas with different polarization, i.e. one is vertical, another - horizontal.Your problem is most likely a problem of separation between the antennas. Try dual pol antennas with the same setup..
The Line is TOP.
joban
not work well.
Stefan
AFAIK there are 2 versions of mars antennas dual pol.. one of them isn't working good because the separation between the two connectors wasn't enough and they were causing interferences...
I tested a N link with 2 separated antennas and didn't have enough isolation. Same link with Jirous Antennas works flawlessly.
I don't understand this..... has anyqone a answer to this question?Sorry for my question but 2 seperate antennas with different polarization has more isolation between the polarisations as a dual pol antennas, isn't it?
It can be done. Look at expensive equipment like Orthogon (now Moto). They canLet's just admit: N is good on a test bench but when we take it outside we all have problems.
I switched from MKTK to UBNT and back playing with all kind of N h-ware and antennas; doesn't work as reliable as advertised... not just yet in outdoor. Manny days spent to run tests, climbing towers and replacing h-ware.
Indoor - works just peachy.
Shame... 7 years of struggling for the standard to be ratified by the Wireless Alliance from which 2 years of N draft 2.0.
Transmission on up to 3 streams supporting up to 450mbps, packet aggregation (the famous A-MPDU), block coding (STBC) - they all look good on paper but not on real life.
I am frustrated. I think N sucks, in the end; I'll probably change my opinion in a month or probably 12, never know![]()
Regards,
Steven
check this out:... make you wonder - what kind of reference OS/system Atheros uses?
AtherOS + Atherboard
Regards,
Steven
I have a Nstreme Dual Link on 5G with 28dBi panel antennas, XR5 and RB433AH at 27 Km doing the same as your N setup.I've just setup an N link, 11.5km
Site A: 411AH + R52N + http://www.mars-antennas.com/item/g_ant ... _1-44.html (MA-WA56-DP25N)
Site B: 411AH + R52N + http://www.l-com.com/item.aspx?id=22099
both sites are pretty busy with RF, and I don't know all frequencies (ie other operators!) so it's a guessing game to find a channel. Clear LOS.
As for the settings, I've pretty much winged it .. click a few buttons, not really knowing why, and now it's running and I hope it doesn't fall over ...
nstream, WDS, callibration off, HT extension below channel
Everything is pretty much default, the most confusing thing for me is which HT supported and HT basic settings to set!! If someone could explain this a little more to me?
Also, I do suffer from not R'ing TFM, so if there's a good "if you want to setup an 802.11n link, read this first" document/site anywhere, let me know also.
Performance:-
thruput (I've an RB1000 connected to site A, and a RB493 at site B)
I get 25 Mbps FD tcp, and 30Mbps FD udp ... which I'm happy enough with for now.
settings:-
/interface wireless
set 0 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=26 antenna-mode=ant-a area="" arp=enabled band=5ghz-onlyn basic-rates-a/g="" \
basic-rates-b=1Mbps comment="" compression=no country=ireland default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=0 default-forwarding=yes \
dfs-mode=none disable-running-check=no disabled=no disconnect-timeout=3s frame-lifetime=0 frequency=5320 frequency-mode=manual-txpower hide-ssid=no \
ht-ampdu-priorities=0,1,2,3,4,5,6,7 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-12,mcs-13,mcs-14 \
ht-extension-channel=below-control ht-guard-interval=any ht-rxchains=0,1 ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-12,mcs-13,mcs-14 ht-txchains=\
0,1 hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 hw-retries=4 l2mtu=2290 mac-address=00:0C:42:3A:CD:B9 max-station-count=\
2007 mode=ap-bridge mtu=1500 name=wlan1 on-fail-retry-time=100ms periodic-calibration=disabled periodic-calibration-interval=60 preamble-mode=both \
proprietary-extensions=post-2.9.25 radio-name=000C423ACDB9 rate-set=configured scan-list=default security-profile=default ssid=mik-new-n station-bridge-clone-mac=\
00:00:00:00:00:00 supported-rates-a/g="" supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tx-power-mode=default update-stats-interval=disabled wds-cost-range=50-150 \
wds-default-bridge=bridge1 wds-default-cost=100 wds-ignore-ssid=no wds-mode=dynamic wmm-support=disabled
/interface wireless manual-tx-power-table
set wlan1 comment="" manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:0,HT20-\
1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20-7:0,HT40-0:0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7:0"
/interface wireless nstreme
set wlan1 comment="" disable-csma=no enable-nstreme=yes enable-polling=yes framer-limit=3200 framer-policy=none
/interface wireless
set 0 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=23 antenna-mode=ant-a area="" arp=enabled band=5ghz-onlyn basic-rates-a/g="" \
0,1 hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 hw-retries=4 l2mtu=2290 mac-address=00:0C:42:3A:CD:06 max-station-count=\
2007 mode=station-wds mtu=1500 name=wlan1 on-fail-retry-time=100ms periodic-calibration=disabled periodic-calibration-interval=60 preamble-mode=both \
proprietary-extensions=post-2.9.25 radio-name=000C423ACD06 rate-set=configured scan-list=default security-profile=default ssid=mik-new-n station-bridge-clone-mac=\
00:00:00:00:00:00 supported-rates-a/g="" supported-rates-b=1Mbps tx-power-mode=default update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=\
your problem in windows mateHello Normis .
I test 4 link with 802.11n , with RB/600A ,R52N , 30dBi parabolic .
On all of them when run BTest , the bandwidth are 115~149 Mbps depend on distance , but this is not my problem .
when I send file from windows computer to another windows computer the traffic rate in WLAN interface show me MAX 57 Mbps and cpu usage is 60%~70% .
I set these four link (Bridge-Station) and set route , (Bridge-Station) and set Eoip-T and Bridge with Ether1 , (Bridge-Station-wds) and Bridge Ether1 with Wlan1 and Nstreme is enable .
When I set Bridge-Station-wds and bridge Ether1 with Wlan1 I get the best result on my link but this best result only allow me to send data on tow computer only 57 Mbps .
I can get picture and send it for you .
Steven,I have a Nstreme Dual Link on 5G with 28dBi panel antennas, XR5 and RB433AH at 27 Km doing the same as your N setup.
you can use bonding and achieve more.
So: what is the point of N? - all right you use a card instead of two so you save 50 bucks
N is advertised as we should be worry about ether ports of our boards not being able to sustain the wireless traffic...
Steven
You should run Nstreme with 802.11abg protocols, with 802.11n currently it's not recommended to use Nstreme. We are working on an entirely new Nstreme version, but it's not implemented in v4, because it's not made yet.4.0 is out!!
Did you fix nstreme on 802.11n?
Did you make any change on 802.11n at all?
... that is worth an upgrade for our links, that isDid you make any change on 802.11n at all?
I understand your problem mate but none of us knew it all from the beginning, we all learned as the technology evolved.Steven,I have a Nstreme Dual Link on 5G with 28dBi panel antennas, XR5 and RB433AH at 27 Km doing the same as your N setup.
Steven
I agree that an nstream2 link would be as good ... in fact it would be better, as I would know more about it and what to do if something goes wrong.
my problem is I don't know enough about 802.11n .. and what the options/settings mean. Are other people's optimum settings reached by trial and error? Is there a reason for choosing MCS-0, MCS-4 and MCS-15 (for example)? Does disabling periodic calibration always stop periodic disconnects? I understand that this is all test software .. I suppose I'm looking for more information ...
E
I think this is laughable. N was the major feature for 4.0. Couldn't be in 3... Had to upgrade licenses to it. ( And thank you for making that no cost). But as we all are learning N interference has made it mostly unsuitable for populated areas without Nstream to combat it and Nstream for N is not being recommended. So 4.0 is a non-product in the wireless world. 4.0 should not have become a release candidate without a working Nstream and certainly not released as a "Product".... Have fun at all the user meetings, because they should have been delayed for your getting Nstream working...You should run Nstreme with 802.11abg protocols, with 802.11n currently it's not recommended to use Nstreme. We are working on an entirely new Nstreme version, but it's not implemented in v4, because it's not made yet.4.0 is out!!
I'll bet you are correct...Does seem very odd. I'm trying to understand why 4.0 would be released without the crown jewel (Nstream) working properly in N.
I can only guess there is addtional new hardware coming that needs 4.0 and MT didn't want to release on RC firmware...
George
Even at the thought of that delay (working N, nstreme whatever), many $ for companies that can sell high quality licensed equipment. E. g. NERA... Motorola...I think this is laughable. N was the major feature for 4.0. Couldn't be in 3... Had to upgrade licenses to it. ( And thank you for making that no cost). But as we all are learning N interference has made it mostly unsuitable for populated areas without Nstream to combat it and Nstream for N is not being recommended. So 4.0 is a non-product in the wireless world. 4.0 should not have become a release candidate without a working Nstream and certainly not released as a "Product".... Have fun at all the user meetings, because they should have been delayed for your getting Nstream working...You should run Nstreme with 802.11abg protocols, with 802.11n currently it's not recommended to use Nstreme. We are working on an entirely new Nstreme version, but it's not implemented in v4, because it's not made yet.4.0 is out!!
I don't see how anything has changed? In v3 you didn't have 802.11n, all you had is 802.11abg with Nstreme. You still have the same in v4, only you have turbo-less 802.11n in addition to that.
hahaI don't see how anything has changed? In v3 you didn't have 802.11n, all you had is 802.11abg with Nstreme. You still have the same in v4, only you have turbo-less 802.11n in addition to that.
N without Nstream to defeat interference is slower that a/g.... Not much of a product...
Changelog mentions nothing about NRouterOS 4.1 !!
Hi all,
this is only for your information
after running a 6 km link in a country side with acceptable bandwidth we tried to establish an 802.11n 2 km-link at the city location as high speed last mile solution.
The result is: Unusable. We are not able to get a stable result. The RX levels and the signal quality was very good. I think there is to much interference ...
With reference to my last post i have tried this through PC-PC and still only 35mb/s. I have tried using only one chain and still the throughput is only 35mb/s. It appears that the second chain may not be being used.Hi Guys!
I am in need of some help.
I have previously setup a test link with a 2 x R52 Wireless cards and 2 x 433AH Routerboards with a TCP throughput of 70mb/s TCP with FTP file transfer between 2 laptops. I recently received 2 x R52N card and was very exited about the the possible thoughput.
I have setup a link using 2 x dipoles, 2 x R52N Wireless cards and 2 x 433AH Routerboards. After some testing i got the link throughput upto 63mb/s TCP using the onboard bandwith test. The CPU was running at 100% so i then moved to a FTP file transfer between 2 Laptops.
The results fluctuated between 20mb/s and 33mb/s. Could anyone shed some light on possible problem?
I have checked that antivirus and firewall are turned off.
Cheers
Let me re-phrase that:Also can someone tell me for 300mb/s do you have to be using 2 x RB52N cards?
Where do you see ethernet involved in this test???RB411AH has 100mbit fdx ethernet..... how possible >180 mbit/s in UDP ????But I can see big differences with and without.
More bandwidth, more stability... just like a 802.11a link.
so what? user not downloading anything. tell them all to run torrents at max speedTorch running on AP side. Monitor wlan interface running Station side.
We also have the same setup but only 10.5km link and have tried Dual Pol Jirous 24Db dishes and also Dual Pol Jirous 29Db dishes. I am using RB433AH and R52N Card.we are testing N in a 15.6km link with Dual Pol Jirous 24Db dishes,
signal is at -68/-70 noise is at -115
We are unable to run the link stable and to pass a decent traffic.
The better modulation it can get is 58-HT, but not able to pass more then 25mbps full duplex. And Also at zero traffic the ping is very erratic.
With just 5mbps of real traffic we have 20-50ms jitter.
very sad to not use turbo on r52n, so we cant be back to the old config..............
regards
Ros
The VPLS Method is establish between the two wlan of the 433AH's and doesn't passthrough the ethernets.. so i don't see your MTU problem..3. WDS - Does it work, or not? Does it cause a performance hit? We need to be able to pass vlans over 433AH's, so we can't use the MPLS method (not enough MTU room).
We do that (replacing a with n-draft. one chain. ). Terrible results. Don't wasting your time.Is anyone try to replace 5Ghz turbo link with 802.11n link using only one chain, antenna ?
Can I get more bandwidth simple replacing miniPCI card ?
Good 5Ghz turbo nstreme link in bandwidth test get 75Mbit in one way UDP test, can be faster only replacing miniPCI card ?
Thanks...
I agree too it would not be a good move..Is anyone try to replace 5Ghz turbo link with 802.11n link using only one chain, antenna ?
Thanks...
This is not completely true - 11n has other advantages besides multipath - the most important being frame aggregation and block acknowledgement (used even if you have one chain), which ensures more efficent use of medium, therefore, provided that link quality allows the use of 11n rates, throughput will increase, even in 20MHz channel.802.11N or MIMO technology actually takes advantage of multipath to increase throughput as well as range. So one antenna will prohibit you from engaging the full potential. Your system will effectively behave like an 802.11a system...
hi fly
I have installed the p2p link but I can't not getting tx/rx rate more than 65 MBit
Can you help me out with your configuration . Because I'm new on N so if you can give me any advise how should I use HT and HT MCS .
thx
Selim
theorytically true. but have you ever seen that...
It might be usable at about 4.30Let's just admit: N is good on a test bench but when we take it outside we all have problems.
Regards,
Steven
If it doesn't work, why is v4 in a stable release? N-Streme is a staple of the MT wireless system and you say it's completely worthless in v4 for N.You should run Nstreme with 802.11abg protocols, with 802.11n currently it's not recommended to use Nstreme. We are working on an entirely new Nstreme version, but it's not implemented in v4, because it's not made yet.4.0 is out!!
Polling type operation is required to deliver quality, consistent service when there are dozens of CPE with high usage levels.I don't see how anything has changed? In v3 you didn't have 802.11n, all you had is 802.11abg with Nstreme. You still have the same in v4, only you have turbo-less 802.11n in addition to that.
What version were you using before ?4.2 is much better regarding ping/latency at high bandwidth and stability on 802.11n links. Great work!
Hi All!
I need help!
I used Turbo Nstreme2, p2p link, distance 4,5km, and works fine. Bandwidth 50/10Mbit live traffic, ping 1-10ms max.
I will need a bigger bandwidth because of this I changed the link it for a N link.
Now the ping time is high and packet loss.
Detail:
x86 system, r52n, antenna dual jirous 24db
Distance 4,5km
Tx signal strengh -65
TX/RX CCQ 70-90%
AMPDU all
Chain 0,1
bandwidth test (TCP/IP) : half: 100Mbit, full: 50/50mbit ping 200-300ms
in live download the bandwidth max 25-30mbit the ping time is 40-50 ms.
Why? Ideas?
ps: sorry my english
0 R name="wlan1" mtu=1500 arp=enabled disable-running-check=no interface-type=Atheros 11N
mode=station ssid="ST" area="" frequency-mode=superchannel
country=no_country_set antenna-gain=0 frequency=5460 band=5ghz-onlyn scan-list=5400-5500 rate-set=default
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps
max-station-count=2007 ack-timeout=dynamic tx-power-mode=default periodic-calibration=default
periodic-calibration-interval=60 dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none
wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=no default-ap-tx-limit=0 default-client-tx-limit=0
proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no security-profile=profile1
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0,1,2,3,4,5,6,7 ht-guard-interval=any
ht-extension-channel=above-control
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-
15
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-txchains=0,1 ht-rxchains=0,1 ht-amsdu-limit=8192
ht-amsdu-threshold=8192 hw-retries=4 frame-lifetime=0 adaptive-noise-immunity=none
1-3 monthsHow long we must wait for working NSTREME ? for 802.11N 2x ?
me too.
However, one thing is strange. I put two NS M5 on the same places and guess what? They work flawless, connected at 216mbps. One of them is without a dish, and the other is strapped with a wire over the feed of the 1.5m dish used to test r52n.
Maybe the tx-power can be an issue? I saw that the nano-stations have plenty of it. However, they don't have as much cpu power as a 1.5ghz p4, so they can't get that much bandwidth through the link.
Bottomline, i am waiting for a bunch of sr71-15 and for nstreme2 using N cards. Until that... back to ns m5 and nstreme2 classic.
ROTFL man 802.11N from UBNT 148 $ for working bridge!!!!!!! 100 Mbit/s no problem.....just see:I have seen a huge amount of posts on the forum relating to the "slagging off of N mode"
But has anyone actually got any useful experiences of using 80211n in an Urbanistic type environment, eg AP's mounted on street lights down a narrow street, where N might benefit from reflections,
Rather than all these posts where folk are trying to squeeze every ounce of throughput by using N over a PtP link, where the whole concept of 80211n has been misunderstood.!!!
what equipment did you use here radios tails board power supply and antennaROTFL man 802.11N from UBNT 148 $ for working bridge!!!!!!! 100 Mbit/s no problem.....just see:I have seen a huge amount of posts on the forum relating to the "slagging off of N mode"
http://www.youtube.com/watch?v=XF_G_BIYqhU
We want same good radio, working N-streme from mikrotik.
Yes, please post it.Got a good result with newest software version using 2 duel pol dishes a link of 20 miles aprox over sea is running at 80 mbps half duplex and actually does do 40/40 full duplex which we thought pretty good. It has a signal in the 50s and is using nstream which does bomb out ocasionally but works quite well. Could post images of test later if anyones interested?
Change Local and Remote Tx Size to 150-300, and you will see dramaticaly CCQ and speed degradation. (I was test it on 10 km link on 60 cm dish, -65 Rx/Tx signal strenght).
The last stable version with N cards in our environment was 4.0beta3. Everything since has been worse.The software has many bugs still. I am actually surprised the software is not labeled as beta as the problems with Nstream etc means we can't use it in production properly yet. I'm looking forward very much to more work from MT and it certainly looks promising with these results so far, but it should still be called beta version in my opinion?
I don't have enough CPU to do tcp tests at the moment. It maxes the CPU at 25-30 mbps with the routerboard generating the traffic. I will set up a dedicated bandwidth test from behind the link soon but haven't had time.
What is your performance with TCP 20-streams?On 1500 byte packets looks so good (but not on small)
10 km link
60 cm dish on each side
dual polarity emmitor
R52N cards
Nstreme
+1In ROS 4.3 Nstreme(BESTFIT frame 4000) works well for traffic comprising of packages 500-1500bytes.
But real traffic heave many 48-200bytes packet effect :CCQ crash from 90-95% to 30% , data rate drops lower & and again and again.
why dont you all people try too use the ip packing ? it should kill small packets.In ROS 4.3 Nstreme(BESTFIT frame 4000) works well for traffic comprising of packages 500-1500bytes.
what card did you used & r52n?Got a good result with newest software version using 2 duel pol dishes a link of 20 miles aprox over sea is running at 80 mbps half duplex and actually does do 40/40 full duplex which we thought pretty good. It has a signal in the 50s and is using nstream which does bomb out ocasionally but works quite well. Could post images of test later if anyones interested?
1)IP packing not work in BRIDGE MODE only routing.why dont you all people try too use the ip packing ? it should kill small packets.In ROS 4.3 Nstreme(BESTFIT frame 4000) works well for traffic comprising of packages 500-1500bytes.
No the Ubnt sr71-15. Also I have fixed all settings. I have fixed ack, rates are just set to only the top two ht rates, turned off all advanced features like calibration etc to make it work.what card did you used & r52n?Got a good result with newest software version using 2 duel pol dishes a link of 20 miles aprox over sea is running at 80 mbps half duplex and actually does do 40/40 full duplex which we thought pretty good. It has a signal in the 50s and is using nstream which does bomb out ocasionally but works quite well. Could post images of test later if anyones interested?
Yes, you're right. The truth is that the mikrotik is not ready for "real world" N applications now. I stopped all my tests, because the 802.11n (from mikrotik) at this stage is absolutely unusable, except for laboratory use. PS: R52n tests only.Comes to me very crazy how is it possble the 4 software is here for a months and such a horrible situation was not fixed until now.
I have the same problem.Well, after some tests, the N with r52n cards is performing very bad , at link where r52 card in A-turbo and nstreme mode performing aroung 40mbit HD, the N link without nstreme is disconnecting all the time , max troughput is aroung 10-12mbit real HD traffic.
Pitty i was fan of MK architecture, but the UBNT products are nowadays flawless and working at first deployment -same location , same antennas , on the other hand i had spent weeks of testing N links on MK platform getting very bad results with now "stable" 4 firmware.
I will switch where needed to M5 products and wait until MK release really working solution. Comes to me very crazy how is it possble the 4 software is here for a months and such a horrible situation was not fixed until now.
Hope the MK programmers will fix this soon.
Jan
Donno, whats very strange to me also, that i cannot without Nstreme push the wireless links over 10Mbits(real traffic, not generated UDP) - either a or n mode, but im sure Ubnt or other architectures are not using NO ack protocol and they are performing much better - airmax disabled M5 products for example. Also i dont expect the Ubnt product are equipped with more CPU power than MK boards.I have the same problem.Well, after some tests, the N with r52n cards is performing very bad , at link where r52 card in A-turbo and nstreme mode performing aroung 40mbit HD, the N link without nstreme is disconnecting all the time , max troughput is aroung 10-12mbit real HD traffic.
Jan
Is it possibile that there are some unstable modules?
Have you a comparation with simple 802.11a+n-stream on same links?α> Two Channels (extended channel mode), Two chains, nstreme = Receive Sustain 164Mbps, Send Sustain 165Mbps, Both Sustain 100Mbps. (full duplex Ethernet LOL) [mcs 0,15]
b> Two Channels (extended channel mode), One chain, nstreme = Receive Sustain 100Mbps, Send Sustain 100Mbps, Both Sustain 55Mbps. [mcs 0,15]
c> One Channel Two chains, nstreme = Receive Sustain 90Mbps, Send Sustain 90Mbps, Both Sustain 50Mbps. [mcs 0,8]
d> One Channel, One chain, nstreme = Receive Sustain 48Mbps, Send Sustain 48Mbps, Both Sustain 25Mbps. [mcs 0,8]
what do you mean by this ?PS. Normis - may we all have a "surprise" update to 4.4 with winbox fixed up, that it allows editing transmit power for DT modes ? i'm to lazy to ssh or terminal and get these fixed by typing...
Yes improve 802.11n + Nstreme for small packet traffic (CCQ drops drasticly)Well from my extensive testing so far, I would say 11n is very good if you have a strong signal. of -60 or above. But for low signals it's much worse than 11a right now performance wise. And becomes very instable. Im sure with a little more work it will be great. And reading after UBNT it's just the same story there.
Lets send some GOOD VIBES to the MT programmers to help them. Your work is great so far we only need a few more improvements now.
+1Yes improve 802.11n + Nstreme for small packet traffic (CCQ drops drasticly)
What kind of signals and noise floors do you have for your 50km link? How has it been performing? What kind of TCP throughput are you getting? I have one that is similar length that I'm thinking about upgrading from 5ghz A to N to get more speed.So now I have stable ~50km link with 90Mbps-SD traffic.
/ interface wireless info print
interface-type=Atheros AR5416
chip-info="mac:0x80/0x2, phy:0xd0, a5:0xc0, a2:0x0, eeprom:0x0"
pci-info="00:13.0"
capabilities=tx-power-control,ack-timeout-control,virtual-ap,alignment-mode,scanning,nstreme,sniffing,power-channel,ht40-a,ht40-g,wmm,14
default-periodic-calibration=enabled
supported-bands=2ghz-b,5ghz,2ghz-g,5ghz-10mhz,5ghz-5mhz,2ghz-10mhz,2ghz-5mhz,5ghz-11n,2ghz-11n
Make BT for 200bytes UDP packet & check CCQ/RATE/PING.....Config and description(unfortunatelly only polish- you can use google translate):
http://www.cyberteam.pl/artykuly/conten ... 32505.html
btw> the board is 1,6 atom x86 which you can also find somewhere on this website.
The first test at 24km+rb600+r52n is located under the link(above)
You can watch the test at http://www.youtube.com/watch?v=eNZO5as93Do
Big thanks to MT!
Happy new year
The thing is that in older ros versions the small packets were not pooled or the link was repeatedly reassociating/disconnecting.no differnece between 4.3 and 4.4 over 802.11n difficult link.
regards
Ros
see post obove yours, that says - use VPLSWe have an alternative to WDS for 802.11n when we want to bridge two ethernets. But, Is there any way to have a repeater on 802.11n without using WDS on a single wireless interface?
Wrote Mark: I posted just minutes ago a new message can you check and send me back your comments please... bets regardsI would be great if the first people to test the new 802.11n support in RouterOS v4 beta 3 would post their experiences here in this thread.
Anyone who will post some 802.11n wiki tutorial with images and setup configurations that work with good speeds, will get a Level6 license from me
the same but nstream also stop working on non-N wireless cards (Atheros AR5413). The same message about pooled and disconnectingThe thing is that in older ros versions the small packets were not pooled or the link was repeatedly reassociating/disconnecting.no differnece between 4.3 and 4.4 over 802.11n difficult link.
regards
Ros
Are you using x86 box? check the system clock and uptime if it isn't running 10 times faster when you use nstreme?the same but nstream also stop working on non-N wireless cards (Atheros AR5413). The same message about pooled and disconnectingThe thing is that in older ros versions the small packets were not pooled or the link was repeatedly reassociating/disconnecting.no differnece between 4.3 and 4.4 over 802.11n difficult link.
regards
Ros
What is your signal strength?Hello, I have a problem with the "n" link. ROS 4.4.
Distance 800m, 2 separate antennas 26dbi in different polarization.
Client.# jan/02/1970 01:30:48 by RouterOS 4.5
# software id = RGKP-MP7S
set default authentication-types="" eap-methods=passthrough group-ciphers="" group-key-update=5m interim-update=0s management-protection=disabled management-protection-key="" \
mode=none name=default radius-eap-accounting=no radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX \
radius-mac-mode=as-username static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=none static-key-0="" static-key-1="" static-key-2="" static-key-3="" \
static-sta-private-algo=none static-sta-private-key="" static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=none tls-mode=no-certificates unicast-ciphers=\
"" wpa-pre-shared-key="" wpa2-pre-shared-key=""
/interface wireless
set 0 ack-timeout=dynamic adaptive-noise-immunity=ap-and-client-mode allow-sharedkey=no antenna-gain=0 area="" arp=enabled band=5ghz-onlyn basic-rates-a/g=54Mbps basic-rates-b=\
1Mbps,2Mbps,5.5Mbps,11Mbps comment="" compression=yes country=poland default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=0 default-forwarding=yes \
dfs-mode=none disable-running-check=no disabled=no disconnect-timeout=3s frame-lifetime=0 frequency=5600 frequency-mode=manual-txpower hide-ssid=no ht-ampdu-priorities=\
0,1,2,3,4,5,6,7 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 ht-basic-mcs=mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15 ht-extension-channel=below-control \
ht-guard-interval=any ht-rxchains=0,1 ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15 ht-txchains=0,1 \
hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 hw-retries=15 l2mtu=2290 mac-address=00:1D:0F:BB:8C:66 max-station-count=2007 mode=\
bridge mtu=1500 name=to_pkp on-fail-retry-time=100ms periodic-calibration=disabled periodic-calibration-interval=60 preamble-mode=both proprietary-extensions=post-2.9.25 \
radio-name=001D0FBB8C66 rate-set=configured scan-list=default security-profile=default ssid=router-lv station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g=\
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tx-power-mode=default update-stats-interval=disabled wds-cost-range=50-150 \
wds-default-bridge=none wds-default-cost=50 wds-ignore-ssid=no wds-mode=disabled wmm-support=enabled
set to_pkp comment="" manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:0,HT20-1:0,HT2\
set to_pkp comment="" disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=3998 framer-policy=best-fit
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no streaming-max-rate=0 \
streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
monitor:# jan/02/1970 01:28:38 by RouterOS 4.5
# software id = ZZ0M-XS5B
/interface wireless
set 0 ack-timeout=dynamic adaptive-noise-immunity=client-mode allow-sharedkey=no antenna-gain=0 area="" arp=enabled band=5ghz-onlyn basic-rates-a/g=54Mbps basic-rates-b=1Mbps \
comment="" compression=yes country=poland default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=0 default-forwarding=yes dfs-mode=none \
disable-running-check=no disabled=no disconnect-timeout=3s frame-lifetime=0 frequency=5600 frequency-mode=manual-txpower hide-ssid=no ht-ampdu-priorities=0,1,2,3,4,5,6,7 \
ht-amsdu-limit=8192 ht-amsdu-threshold=8192 ht-basic-mcs=mcs-0 ht-extension-channel=below-control ht-guard-interval=any ht-rxchains=0,1 ht-supported-mcs=\
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15 ht-txchains=0,1 hw-fragmentation-threshold=disabled hw-protection-mode=\
none hw-protection-threshold=0 hw-retries=15 l2mtu=2290 mac-address=00:1D:0F:BB:8C:1E max-station-count=2007 mode=station mtu=1500 name=to_kosciol on-fail-retry-time=100ms \
periodic-calibration=disabled periodic-calibration-interval=60 preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=001D0FBB8C1E rate-set=configured scan-list=\
default security-profile=default ssid=router-lv station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g=6Mbps,54Mbps supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps \
tx-power-mode=default update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled wmm-support=\
enabled
set to_kosciol comment="" manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:17,HT20-1:\
17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,HT40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-7:17"
set to_kosciol comment="" disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=3998 framer-policy=best-fit
2xRB433 +r52nstatus: connected-to-ess
band: 5ghz-11n
frequency: 5600MHz
tx-rate: "270.0Mbps-HT"
rx-rate: "270.0Mbps-HT"
ssid: "XXXX"
bssid: XX:XX:XX:XX:XX:XX
radio-name: "XXXXXXXXXX"
signal-strength: -54dBm
tx-signal-strength: -55dBm
noise-floor: -113dBm
signal-to-noise: 59dB
tx-ccq: 99%
rx-ccq: 88%
p-throughput: 152110
overall-tx-ccq: 99%
authenticated-clients: 1
current-ack-timeout: 31
wds-link: no
nstreme: no
framing-mode: none
routeros-version: "4.5"
last-ip: 192.168.1.220
802.1x-port-enabled: yes
compression: no
wmm-enabled: yes
current-tx-powers: 6Mbps:18(18/21),9Mbps:18(18/21),12Mbps:18(18/21),18Mbps:18(18/21),24Mbps:18(18/21),36Mbps:17(17/20),48Mbps:16(16/19),54Mbps:13(13/16),HT20-0:16(16/19),
HT20-1:16(16/19),HT20-2:16(16/19),HT20-3:16(16/19),HT20-4:16(16/19),HT20-5:16(16/19),HT20-6:15(15/18),HT20-7:11(11/14),HT40-0:15(15/18),HT40-1:15(15/18),
HT40-2:15(15/18),HT40-3:15(15/18),HT40-4:15(15/18),HT40-5:15(15/18),HT40-6:14(14/17),HT40-7:10(10/13)
notify-external-fdb: no
Notice who I was quoting and replying to.you can see it in his picture. signal is -47
You method to tetst from PC to PC is correct.hi ,freinds
we used rb433ah with WLM200N5
and used this config but when we test it with mikrotik bandwidth test it,s stable and band width is 190 or 200mb but when we transfer file from a pc to another bandwidth is not stable and it has low bandwidth for ex 55 or 65 or maximum 70 mb
can you help us
thanks
hello,friendhi ,freinds
can you help us
thanks
Work's fine, have N link with nstreme. ~3km.
It is not fair to compare this to dual nstreme as currently 802.11n doesn't work with nstreme.
band: 5ghz-11n
frequency: 5600MHz
tx-signal-strength: -56dBm
tx-ccq: 97%
rx-ccq: 87%
p-throughput: 140175
overall-tx-ccq: 97%
wds-link: no
nstreme: yes
compression: no
wmm-enabled: yes
i think that's two chains, am i wrong ?ht-txchains=0,1 ht-rxchains=0,1
cool! do you have any traffic running on it? what throughput do you get in both directions?
Hello, the radios are r52nwhat radios you using?
and whta antennas you got set up? with this config
can you post your configeration here for up please
int wi pri advanced
0 name="wlan1" mtu=1500 mac-address=00:0C:42:61:71:1D arp=enabled disable-running-check=no interface-type=Atheros 11N radio-name="000C4261711D"
mode=ap-bridge ssid="ntest-km" area="" frequency-mode=superchannel country=no_country_set antenna-gain=0 frequency=5180 band=5ghz-onlyn
scan-list=default rate-set=configured supported-rates-b="" supported-rates-a/g="" basic-rates-b="" basic-rates-a/g="" max-station-count=2007
ack-timeout=dynamic tx-power=17 tx-power-mode=all-rates-fixed periodic-calibration=disabled periodic-calibration-interval=60 dfs-mode=none
wds-mode=disabled wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=no default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25
wmm-support=disabled hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=short compression=no
allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0,1,2,3,4,5,6,7 ht-guard-interval=long
ht-extension-channel=above-control ht-supported-mcs=mcs-0,mcs-7,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15 ht-basic-mcs=mcs-0 ht-txchains=0,1
ht-rxchains=0,1 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 hw-retries=15 frame-lifetime=0 adaptive-noise-immunity=none
int wi nstreme pri
0 name="wlan1" enable-nstreme=yes enable-polling=yes disable-csma=no framer-policy=best-fit framer-limit=3998
int wi manual-tx-power-table pri
0 name="wlan1" manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:0,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20-7:0,HT40-0:0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7:0
no that not suported ,wds is working fine on N ?
with nstreme ?no that not suported ,wds is working fine on N ?
i hawe link ower ~2km
routerboards is rb433 (300mhz) and r52n cards , use 17 dbi patch antenas 1X
signal -70... -68 and signal to noise ~40db , i use vpls
tcp traffic over 30-40mb half duplex .
no , config is (AP-->station)with nstreme ?
5ghz5Ghz or 2,4Ghz ???
I'm trying 802.11n on rb800 with r52n radio card, and ROS 4.5 . The results are excellent.
The same configuration on alix 2d2 (WDS bridge or MPLS + VPLS , as described on the wiki) does not work at all.
The machines are connected, but no data output when I do the BT and sometimes they suddenly reboot. Someone has already solved this situation?
My config ( in WDS mode ) is :
-bridge interface with ether1 and wlan1
-wireless mode : station-wds (or bridge)
-band : 5GHz only n
-freq. : 5500
-HT chains : Tx 0 1 / Rx 0 1
-HT AMPDU : 0 1 2 3 4 5 6 7
-wds mode : dynamic
-wds def. bridge : bridge_name
-nstreme : enabled (on bridge machine frame policy : "best fit")
On rb800 it work fine but if i try with alix ... nothing .
We have seen something similar with R52n. In our case the TX rate falls to 1Mbps-SP and CCQ to ~20%. Signals are very good. I have been searching for these symptoms in the forum. I can't believe that only I have problems with these cards. I think there is something wrong with them.2) The N radios seem to "gather" errors or something. If the radio is running max throughput for a period of time it will all the sudden stop and only move a few kbps for 10-15 minutes or until disabled and re-enabled, then back to normal operation. During the problem periods the rate, ccq and signal looks perfectly normal.
nstreame wich 1x antena is a senselessness , in my opinion nstreame justified when use 2X antena in order duplex speed success .
Could you please share us the result of a tcp test with rb800 on 802.11n?
I'm interested in the numbers, is it enough good as a PC
-band : 5GHz only n
-freq. : 5500
-wds mode : dynamic
@pampi
Do the test in both direction UDP frame size set 200b & measure the ping latency.
Or just run this link productively.
I have a link to the production set static 216/216 Mbps CCQ always 99/99%, TX / RX Signal 50dB, 100Mbit possible with UDP packets 1500b ethernet is limit.
But the ping latency in the 30/10 traffic Mbitsis not acceptable 20-50ms (802.11a Turbo Link is 5-10 ms MAX!!!!!) jitter is weak, Nstreme not work.
The same experience here!I put the test config back, couse I see your post, that for a period of time, it stops.
Now its running 1day 15 hour, one bandwidth test with maximal throughput till now, at the moment I change the direction. No disconnections, no speed dropdowns, I monitored the interface with snmp. I see the interface statistic and there are no errors, but lots of data transmited
Here's what I did:
The testbed:
5Ghz, N-Only mode, ROS version 4.5
Laptop-----RB800 + R52N + DualPol Ant <-----20meters (a few walls in between)-----> DualPol Ant + R52N + RB800-----Laptop
Everything seemed fine. I was getting stable 270/270Mbps Tx/Rx rate and a 95/95% CCQ. The bandwidth test in the RouterOS run fine, and gave me mind-blowing results:
- one way TCP :120-140Mbps
- both ways TCP: ~ 82/87 Mbps
I left this - one way - test running for 3 days!! Not a single glitch, no disconnection, perfect! Just like pampi, I was very happy!
BUT!
The tests between the two laptops (with gigabit eth ports) weren't so great at all... The one way test (copying file from one laptop to another) gave me some 25-30Mbps max.
Then I took the whole setup outside and put it to the test under real-world circumstances :
Very noisy environment @ 5.4GHz!
Corporate Net---RB800 + R52N + DualPol Ant <-----1300m-----> DualPol Ant + R52N + RB800---Corporate Net
And then, the problems began to emerge...
First of all, I've got a very good signal strength -48~51 / -48~50 dBm ... but just like merlinthemagic and congo said... everything was fine for some time, and then, under 50-60 Mbps of traffic and 10-11kpps, suddenly, everything seemed to collapse! The RX-rate fell from 216-270Mbps to 6-12Mbps, and the CCQ did the same... from 90% ---> down to 5-7%. If I left it this way... sometimes it recovered itself after an hour, or so... but if I wanted a quick recovery, I had to reboot one of the RouterBoards...
The ping was somewhere between 4-6ms with 5GHz-Turbo mode (Compex AG card), but with this 5GHz-N-only link it looked like it was multiplied by a factor of 8... somewhere around 30-40ms
... had to put back the old miniPCI cards and the 5GHz-Turbo mode to regain the stability we were accustomed to...
Conclusion: a lot of work (coding) is required by MikroTik to make these N-links stable and ready for the "Real World" circumstances
I wish they (MikroTik engineers) could be here to see with their own eyes the behavior of these N-links... or would it be helpful if I send a supout.rif file to them for analysis ...?
Regards
Is that with a 20mhz or 40mhz channel?After months of playing with N this is what works for me. Removed all a and b data rates and just use one ht-mcs rate that your link preferes. I have 18km link running single chain using only mcs=4 basic and supported. On btest i get 64Mb throughput and production data 58Mb one way. Also have 2km link set on mcs6 supported and basic and on btest get 100Mb and real data 94Mb. Also have a 40Km link set msc4 single chain doing 50Mb real data and lastly an 8km link running dual pol dishes msc10 doing 120Mb real data. The key was with the hw retries and data rates. Also all the link from 10Km up is running nstreme as it doesn't like to work on the short links.
All in all am extremely happy with me links. They all performing very well.
@professorAfter months of playing with N this is what works for me. Removed all a and b data rates and just use one ht-mcs rate that your link preferes. I have 18km link running single chain using only mcs=4 basic and supported. On btest i get 64Mb throughput and production data 58Mb one way. Also have 2km link set on mcs6 supported and basic and on btest get 100Mb and real data 94Mb. Also have a 40Km link set msc4 single chain doing 50Mb real data and lastly an 8km link running dual pol dishes msc10 doing 120Mb real data. The key was with the hw retries and data rates. Also all the link from 10Km up is running nstreme as it doesn't like to work on the short links.
Check out this dual pol antenna for 802.11n. http://www.antennas.com/DATA-SHEETS/ARC ... 113009.pdfdoes 802.11n works on the 5ghz band
I thought so, thank you for your confirmation. These two channels are very close in frequency, so it's easy to get intererference.I didn't get many answers on my thread, so...
How about 2 chains on an AP and one chain on the CPE? Would that increase the download speed, upload speed or the same as a single chain?
On a small AP, has anyone run a high gain omni along with a lower gain omni? I'm looking at a Hyperlink 15dBi with a 8 or 10dBi for the second chain. Wider beamwidth for closer customers and cheaper as well.
I agree with separating the pigtails as far as possible, however, outside of an N connection, I am hesitant to run 2 cards of the same frequency in the same box. I've got a 433 running a 3 sector 2.4GHz setup, works quite well. I've got several 600 with 2.4 AP and 5GHz ptp in and out. I am catching tons of self interference in the 5GHz band with careful location of the pigtails.DO not cross Pigtails on outdoor boxes, put them on left and right, so they could not be connected. I have a link on 433ah 2x5ghz-turbo link, all work fine. I think, this could make good interference (pigtails together)
Happy new year (norouz) .
about wireless link 802.11n !?
for about 3 meter , routerboard 411AH , R52N , 16dBi dual Polar antenna , with eoip bridge ; test with btest on wlan we have about 222Mbps RX or TX and TX:103Mbps and RX:85Mbps ; and test with btest on ethernet 95.5Mbps
for about 2.001 KM with routerboard 800 , R52N , 2 * 29dBi parabolic antenna , with eoip bridge ; test with btest on wlan about 127Mbps and test with btest on ethernet 117 Mbps ; i send file with 524MG from 4 windows computer to 4 windows computer about 5,5 minutes for all computer , and copy file to 2 windows with IDM(internet download manager) from 2 RB411U(USB2 Flash) with ftp by 79Mbps . cpu usage is 8%
for about 3.7 km with routerboard 411AH , R52N , 28dBi dual polar Dish antenna ......... ; test ................................................. about 127Mbps RX or TX on WLAN and 95.5 Mbps on Ethernet .
Yes. Try it on small packets, like 100 bytes.UDP tests are not relevant...
9 months and still no progress 802.11n does not work correctly with production traffic. Ping is a high latency is not acceptable for 30-50ms for 40/10mbit traffic. Nstreme still does not work correctly with production traffic, falls CCQ miserably when Nstreme is enabled.
RouterOS v4 works fine. What the problem? See above thread, most issues have been solved with proper configuration. 802.11n is very hard to configure, lots of new options that need adjusting. You have to ask for help if you have issues.And new alpha version of ROS v5 when ROS 4 is in beta state. :/
Why release ROS v5 when v4 is very beta version?
Uuups. You're happy with your 11n implementation? Expect that there will be others who manageRouterOS v4 works fine. What the problem? See above thread, most issues have been solved with proper configuration. 802.11n is very hard to configure, lots of new options that need adjusting. You have to ask for help if you have issues.And new alpha version of ROS v5 when ROS 4 is in beta state. :/
Thank you. Can you tell us some release dates prediction for these two features I mentioned? Are you already working on that?It's already added
Well you should make wiki for this. I tried several weeks to get your N solution to work - no success. Tried 3 different locations, all the time same result - high ping, low throughtput.Do you have an issue with 802.11n ? Please, give us your configuration, and tell us what's wrong. We will try to help.
this only means that you don't know about the hw-retries setting, which affects latency, and can decrease it. As I said, configuration issuePing is a high latency is not acceptable
I try hw-retries setting 15, 5, 0 on AP & APC no change but if I set 0 some ping lost no stable.this only means that you don't know about the hw-retries setting, which affects latency, and can decrease it. As I said, configuration issuePing is a high latency is not acceptable
I think bigger hw-retries means worse latency not true for point too point link.small hw-retries means good latency, lower link stability
bigger hw-retries means worse latency, higher link stability
choose your target and experiment accordingly, to balance latency and stability
Normis;small hw-retries means good latency, lower link stability
ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no \
antenna-gain=0 antenna-mode=ant-a area="" arp=enabled band=5ghz-onlyn \
basic-rates-a/g="" basic-rates-b="" comment="" compression=no country=\
poland default-ap-tx-limit=0 default-authentication=yes \
disable-running-check=no disabled=no disconnect-timeout=3s \
frame-lifetime=0 frequency=5180 frequency-mode=manual-txpower hide-ssid=\
no ht-ampdu-priorities=0,1,2,3,4,5,6,7 ht-amsdu-limit=8192 \
ht-amsdu-threshold=8192 ht-basic-mcs=mcs-0 ht-extension-channel=disabled \
mcs-0,mcs-7,mcs-8,mcs-14,mcs-15 ht-txchains=0,1 \
hw-fragmentation-threshold=disabled hw-protection-mode=none \
hw-protection-threshold=0 hw-retries=15 \
max-station-count=2 mode=bridge mtu=1500 name=wlan1 on-fail-retry-time=\
100ms periodic-calibration=disabled periodic-calibration-interval=60 \
preamble-mode=short \
rate-set=configured scan-list=5180,5760,5320,5825 \
security-profile=default ssid=awmn-2315-3665 station-bridge-clone-mac=\
00:00:00:00:00:00 supported-rates-a/g="" supported-rates-b="" \
update-stats-interval=disabled \
wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 \
mt client config:/interface wireless security-profiles
set default authentication-types="" eap-methods=passthrough group-ciphers="" \
group-key-update=5m interim-update=0s management-protection=disabled \
management-protection-key="" mode=none name=default \
radius-eap-accounting=no radius-mac-accounting=no \
radius-mac-authentication=no radius-mac-caching=disabled \
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=\
static-sta-private-algo=none static-sta-private-key="" \
static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=\
none tls-mode=no-certificates unicast-ciphers="" wpa-pre-shared-key="" \
/interface wireless
set 0 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no \
antenna-gain=0 area="" arp=enabled band=5ghz-onlyn basic-rates-a/g="" \
basic-rates-b="" comment="" compression=no country=poland \
default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=\
0 default-forwarding=yes dfs-mode=none disable-running-check=no disabled=\
no disconnect-timeout=3s frame-lifetime=0 frequency=5180 frequency-mode=\
ht-amsdu-limit=8192 ht-amsdu-threshold=8192 ht-basic-mcs=mcs-0 \
ht-extension-channel=disabled ht-guard-interval=any ht-rxchains=0,1 \
ht-supported-mcs=mcs-0,mcs-7,mcs-8,mcs-14,mcs-15 ht-txchains=0,1 \
hw-protection-threshold=0 hw-retries=15 l2mtu=2290 mac-address=\
00:0C:42:61:72:04 max-station-count=2 mode=bridge mtu=1500 name=wlan1 \
on-fail-retry-time=100ms periodic-calibration=disabled \
periodic-calibration-interval=60 preamble-mode=short \
proprietary-extensions=post-2.9.25 radio-name=000C42617204 rate-set=\
configured scan-list=5180,5760,5320,5825 security-profile=default ssid=n \
station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g="" \
supported-rates-b="" tx-power-mode=default update-stats-interval=disabled \
set wlan1 comment="" manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,\
6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps\
:17,HT20-0:0,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20-7:\
set wlan1 comment="" disable-csma=no enable-nstreme=no enable-polling=no \
/interface wireless
00:0C:42:61:72:01 max-station-count=2 mode=station mtu=1500 name=wlan1 \
proprietary-extensions=post-2.9.25 radio-name=000C42617201 rate-set=\
set wlan1 comment="" disable-csma=no enable-nstreme=no enable-polling=yes \
i add ip 10.10.10.1 to mt-ap, and 10.10.10.2 to mt-client to ether1 at mt's:eeh ..
1. Run test over vpls (test to ether ip - not transport/remote/wlan ip )
2. Test run on ROS not on pc with winshit
eeh ..
