MUM Europe 2020
wireless12
will this method reduce or eliminate the interference
Mon May 25, 2009 12:49 pm
hii all.
when we make a base station using 2.4 GHz, we have to face lot of difficulties due to extensive interfence in 2.4 GHz and it also hav only 3 non overlaping channels. some time its very hard to run our network in 2.4 GHz.
But when we see in wireless setting we find 2 GHz-10MHz and 2 GHz-5Mhz aslo,Now my question is if we starting using these two band instead of 2.4 GHz only. can we come out with good results becuase when we do a scan we dont find any network on these band...
will these band will remain uneffected of interfernce by huge number of 2.4 GHz (default & traditional Band)networks in that area.. the client CPE is also a mikrotik gear.
thxxx..
wireless12
Re: will this method reduce or eliminate the interference
Mon May 25, 2009 2:05 pm
no ideas...?
wireless12
Tue May 26, 2009 12:35 pm
heyyyyyyyyyyy....whts up? is this is so much tough question.?
normis
Tue May 26, 2009 12:39 pm
no, this is not related to that. interference can still come on this channel, it doesn't mean you will see it in scan list. interference can also come from non-wifi devices. to avoid interference use a different frequency. the frequency bandwidth (5 or 10mhz) doesn't matter so much
Users browsing this forum: No registered users and 34 guests
