MUM Europe 2020
titius
How many clients can be connected to one AP G mode
Tue May 26, 2009 11:51 am
So what is the number of stations that can be connected and use FULL G capacity, Im talking about perfect world here.
Ibersystems
Re: How many clients can be connected to one AP G mode
Fri May 29, 2009 11:35 am
Hi, only 7.
Nahhh.. It's a joke. You can have hundreds users but it depends on what are they doing and the type of RB.
Martín
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
titius
Fri May 29, 2009 1:31 pm
hundreds of them using full g transfer rate ?? I dont think so
Ibersystems
Fri May 29, 2009 2:27 pm
It depends on your country. Isn't the same Noise in NYork or in a remote mountain.
Martín
titius
Fri May 29, 2009 2:49 pm
normis
Fri May 29, 2009 2:50 pm
I know people who have a little over a hundred stations, but it depends on what speed you want to give your customer.
roc-noc.com
Forum Veteran
Forum Veteran
Fri May 29, 2009 2:52 pm
The correct answer is: only one at a time.
Obviously if two people are connected and both downloading from an unlimited bandwidth site at the same time, they will have lower download speeds than if just one just one person is connected and downloading.
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
titius
Fri May 29, 2009 3:27 pm
so hundred stations is really really big. :) .
You cannot offer them 512Kbps internet, imagine they all use it at the same time.
So for 1 Mbps up and down you can connect abou 10 users in a perfect situations?
normis
Fri May 29, 2009 3:33 pm
real throughput of G in regular mode is something like 30mbit?
Ibersystems
Fri May 29, 2009 3:51 pm
This is not the perfect world! haha.
Martín
InoX
Fri May 29, 2009 5:56 pm
in a real point to multipoint you can't have more than 15mbps. Not even with only 10 clients conected
titius
Sat May 30, 2009 3:22 am
Thank you inox, straight answer :)
How many clients can be connected, asume every one have 1 mbps up/down and use it at same time?
InoX
Tue Jun 02, 2009 3:54 am
to have 30 clients online means that you must have at least double connected. I have 30 users connected through 9 AP Client with 4 and 6 mbps each, on a single sector and no complains. The chance that everybody to download is very low. Most of the time 4-8mbps on the sector.
titius
Thu Jun 04, 2009 9:45 am
Yes, and what if file transfer is allowed? :) I mean local file sharing :).
pedja
Long time Member
Long time Member
Thu Jun 04, 2009 11:15 am
In my experience, anything more that 12 clients is problem. I am talking about local networking, with unlimited speed.
InoX
Fri Jun 05, 2009 1:19 am
agreed
dchouinard
Fri Jun 05, 2009 6:33 pm
Interesting topic here.
I have 20+ laptops with domain logon over wireless link in a school. I have to admin that things are really slow. Takes forever to students if any more than 10 laptop are booted within an area. I tried to implement queues to allow smoother operation but I'm still not satisfied.
Based on what I heard on this topic, I understand that I'm overcharging my AP and I need to deploy more AP.
Any trick to do that. Should I put more wireless card in my AP? Install more AP on different channels? on the same channel? What are the best practice to allow a large amount of laptop avec a small area?
Dany Chouinard
titius
Sun Jun 07, 2009 2:45 pm
Well maybe you could try WDS, or more AP wide spread on different channels, but then you must link all AP-s. So maybe WDS is the best sollution for you. . .
dchouinard
Mon Jun 08, 2009 5:19 pm
I tought that WPS was used to link AP with a wireless link? I currently use cat5 cable with PoE to keep the wireless spectrum as clean as possible for students laptops.
Every APs talks to a radius server for WPA authentication, is that the kind of link between APs you're talking about?
I do feel that I'm missing something. If I ever wish to significantly increase the number of current users in an area - for a convension or something like that - I don't beleive that my current setup would handle the charge.
Dany Chouinard
Users browsing this forum: MSN [Bot] and 25 guests
