MUM Europe 2020
doush
Long time Member
Long time Member
Lowest Possible Tx-Power R5H
Sun Jun 14, 2009 11:52 am
Is there a value not to exceed decreasing the Tx Power ?
For mine, even when I set it to 0 , I can establish links. Any limit that can damage the card ?
doush
Long time Member
Long time Member
Re: Lowest Possible Tx-Power R5H
Mon Jun 15, 2009 11:57 am
anyone please ?
aaa
Mon Jun 15, 2009 11:10 pm
I not understand your idea, why you need decrease output power? What you doing with 0dBm or 1dBm output power?
doush
Long time Member
Long time Member
Tue Jun 16, 2009 1:06 am
I have oversaturation of signals like -30 -40 or -50. I want to stabilize the links at -65 to get the max throughput thats why I have to decrease the txpower. (Changing the antennas is not an option in my case)
0ldman
Tue Jun 16, 2009 7:49 am
I can't see where lowering the tx can damage the card. Eventually, you'll just get to the point where it doesn't transmit.
I don't know if the R5H has an external amp or not, I imagine so, so eventually, I think the amp is just going to quit boosting signal. As in, you turn it down 1dB more and you lose signal entirely (rx -65, down 1dB, nothing).
Just a moderately educated guess tho... I don't know if you can even put negative numbers in the tx power tho.
Nuke
Tue Jun 16, 2009 5:42 pm
0dbm is 1mW so it will still connect, try setting it to something in the minus range eg. -10dbm is 0.1mW
doush
Long time Member
Long time Member
Fri Jun 19, 2009 12:42 am
thanks nuke. it helped a lot.
Users browsing this forum: llubik and 18 guests
