MUM Europe 2020
JohnWifispots
Pl guide me on the basic set up
Tue Jun 30, 2009 8:18 am
I am a newbie to Mikrotik.
Bear with me if I am asking fundamental question.
I am trying to get the below set up for some testing environment.
PC#1 --> RB411A (Station) ------ Wireless ---> RB433 (AP-bridge) --> PC#2.
I am using R52 Radio Modules.
I can associate with the AP.
More over, when I log in through Win Box from RB411 side , I can see both the MAC IDs of the miniPCI connected to RB411 & RB433.This means that they are wire lessly connected?
Below is the IP schema I had followed.
RB411 side (Station)
PC IP Address : 192.168.0.10
Mask 255.255.255.0
Gateway 192.168.0.1
RB411 ether1 192.168.0.225
RB411 wlan1 192.168.0.1
RB433 side (AP)
PC IP Address : 192.168.0.20
Mask 255.255.255.0
Gateway 192.168.0.100
RB433 ether1 192.168.0.100
RB433 wlan1 192.168.0.1
My objective here is to run the Bandwidth test from the PC #1 to PC#2 & vice versa.
Currently I can not even ping the units from the PC behind.
I am sure I am missing something here.
Any hint would be of great help.
Thanks,
normis
Re: Pl guide me on the basic set up
Tue Jun 30, 2009 9:35 am
either you need some routes, or you need to add some masquerade rules. I suggest this:
http://wiki.mikrotik.com/wiki/Making_a_ ... ireless_AP
and this
http://wiki.mikrotik.com/wiki/MikroTik_ ... _Questions
JohnWifispots
Tue Jun 30, 2009 11:50 am
Thanks Normis,
I tried the follg as route
RB433 side
Destination = 0.0.0.0/0
Gateway WLAN
Gateway interface WLAN1
Preferred source address 192.168.0.225
RB411 side
Gateway WLAN
Preferred source address 192.168.0.100
Also, tried the masqurading, no effect..
From the AP side, I can also the client's MAC ID in the registration page, which means , the wireless connection is OK.
Any idea, what I am missing here?
Or can you suggest what routes I need to follow exactly for this requirement?
Thanks,
JohnWifispots
Tue Jun 30, 2009 6:52 pm
Normis,
You have any suggestion to try out?
Thanks,
JohnWifispots
Sat Jul 18, 2009 4:23 pm
Looks like the default route added by the router is causing this problem.
Is there any way to remove it ?
I tried by removing it through IP--> Route menu, but I get the message
Can't remove Route <....> - can remove only static routes [6]
Any thoughts?
Thanks,
poli5681
Sat Jul 18, 2009 4:53 pm
You don need to use routes for this. Just configure one device as ap-bridge (or simply bridge) and the other as "station wds".
Add a bridge and add the ether and wlan ports to that bridge on both devices. As long as your PCs are in the same subnet you should be able to do bandwidth tests, or whatever, over the wireless bridge.
Hope that helps.
JohnWifispots
Sat Jul 18, 2009 6:44 pm
Thanks Poli,
1. I restored to defaults all the settings, configured as you have suggested.
2. Added Route in RB433 for the network of PC behind RB411.
It finally worked .
Adding the Route was necessary to ping from the PCs..
Thanks again..
Users browsing this forum: ds0209 and 11 guests
