-headstrong-
Maximum data sources?
Wed Jul 01, 2009 11:21 pm
Hi Guys
I have a dude server with about 30 data sources and 30 charts running on my VISTA laptop with 3 gigs of ram.
Is there a limit to the number of data sources that can be running simultaneously because some of mine keep freezing as I add new ones
lebowski
Re: Maximum data sources?
Sun Jul 12, 2009 10:23 pm
I found that on a quad core I would have graphing issues when I had about 1000 data sources but I also have ciscoworks on the same box with 2k3 sp2.
I also found that graphing is much more accurate when you set the priority of the dude to high or real time with sysinternals process explorer. I also reduced my data sources to about 400. I was pinging every computer on the network as a test to see how many got shut off over night.
SD
-headstrong-
Sat Jul 18, 2009 5:03 pm
so if I upgrade my CPU then all my graphs should work?
sady
Mon Jul 20, 2009 4:01 pm
probably, also you may try separate server and client to two different computers. I assume, that graphical load lies only on client side.
Please, please, Open Dude Source! Pleaaaaseeeee!!!!!
-headstrong-
Wed Jul 22, 2009 6:21 pm
ok Im running the dude on a box and the client from my laptop...But I still have data sources that do not graph...!!AS#@!A!
Sometimes I change the interval from 30 seconds to 20 seconds and that seems to jumo start it....But doing that every few days for 50 data sources is a nightmare...
any thing else to try?
lebowski
Thu Jul 23, 2009 2:38 am
Did you try setting the dude server to high priority?
-headstrong-
Fri Jul 24, 2009 4:15 am
yip but no sucess...
Have a look at my attachments...The probe-function.jpg shows my configurations to pull the stats from the Mikrotik...and the service graphs shows that the dude gets the values from the mikrotik when I add the custom probe to the device, but for some reason the graphs do not show....
Any ideas?
-headstrong-
Fri Jul 24, 2009 9:55 pm
Fixed it :) !!!!!
I changed my error condition to "" and the graphs magically started working :D
Users browsing this forum: No registered users and 15 guests
