Caci99
Netinstall on RB411R and RB750
Wed Jul 08, 2009 7:07 pm
It looks like there is no way to do netinstall on the new RB411R
and RB750, since both of them don't have Serial Port, right?
-Toni-
Don't crash the ambulance, whatever you do
InoX
Re: Netinstall on RB411R and RB750
Thu Jul 09, 2009 2:34 am
in the picture RB411R have serial port
normis
Thu Jul 09, 2009 9:31 am
which picture? no it doesn't. wait for the newsletter
InoX
Thu Jul 09, 2009 11:38 am
this one
normis
Thu Jul 09, 2009 11:53 am
it's not the RB411R
Caci99
Thu Jul 09, 2009 12:12 pm
So Normis, what about netinstall? :)
-Toni-
normis
Thu Jul 09, 2009 12:18 pm
holding the small little button during boot will run the network booting option.
janisk
Thu Jul 09, 2009 1:57 pm
to be exact, push button, and plug in power, wait till router beeps and light goes off on the router. after that router will boot up from your netinstall. You should run netinstall before operation because wait time is rather short to start booting
Caci99
Thu Jul 09, 2009 2:06 pm
Is this button visible in any of the published pictures?
I haven't acquired any of these routerboards yet, so I can
only see the pictures :)
Thank you
-Toni-
normis
Thu Jul 09, 2009 2:09 pm
all routerboards have this button. pick up any you have
Caci99
Thu Jul 09, 2009 5:40 pm
I guess you're talking about what I long beleived was the
non working "reset hardware button" ha ha.
-Toni-
normis
Fri Jul 10, 2009 9:06 am
before it loaded the backup bootloader. now it has an additional function.
Caci99
Wed Sep 09, 2009 5:12 pm
Sorry to bring this topic back, but I just tried netinstall on RB750 as described
but didn't succeeded. Netinstall version 3.28 and RB750 with RouterOS 3.29
And looks like RB750 doesn't have any beep during boot
Any help?
-Toni-
changeip
Thu Sep 10, 2009 2:28 am
u using port 1 ?
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
Krusty
Thu Sep 10, 2009 11:32 am
same here, I got RB750 (bought for tests) and need to reinstall, no serial connector, netinstall dont see it and dont work, Im trying port 1 and port 5, no beep while booting, cause it dont have any speaker...
I tried to power off, push reset, and while holding reset turn power on, it seems to boot normaly, no change, but default configuration is loaded
I cant use default config, cause something on that RB is corrupted, while Im able to connect via telnet, run check installation, then I got plenty of error messages that I have to contact support :) Wingox dont work, it says "could not get index: missing file"
so how can I reinstall this RB ?
normis
Thu Sep 10, 2009 11:34 am
please look at the quick guide:
http://www.routerboard.com/pricelist/do ... ile_id=106
it says there:
Hold this button during boot time longer, until LED turns off,
then release it to make RB750 look for Netinstall servers.
Krusty
Thu Sep 10, 2009 11:56 am
it says there:
I try this before, 1st and 5th port, netinstall dont see that RB
normis
Thu Sep 10, 2009 12:30 pm
why do you need to netinstall anyway? did you try to reset it first?
Krusty
Thu Sep 10, 2009 1:01 pm
as I say, my installation of MT is corrupted, Im not able co connect via winbox, because it says "index missing" if I try to connect via telnet and run "check-install" than I got plenty of errors, that some files are missing. Yes I have tried to reset configuration, many times :)
I already tried to upload new package through FTP, it says no enought space... I realy thint I got defective piece and I will try to make reclamation on this...
BTW: I realy hate this default configurations :) especialy when RB dont have serial port and dont like my ethernet card so Im not able to connect to MAC address :) I think I will stay with RB450 :)
normis
Thu Sep 10, 2009 1:06 pm
1. RB450 also has default configuration, exactly the same as RB750. Strange that you didn't notice
2. at first startup, RouterOS asks you if you want to remove it, this is an option
3. Index Missing is not a RouterOS issue, but a Windows issue. Try to connect from another PC and make sure you use port 2-5
I really recommend you to read the simple steps on the cardboard box :)
Krusty
Thu Sep 10, 2009 1:11 pm
1. yes I noticed it, but RB450 got serial port so Im able to revert this default config via serial and make my own, no need to change IP on computer and make a lot of annoying stuf around :)
2. yes, true, Im using serial for this first start, witch RB750 dont have
3. I already tried this, If i try to connect to second RB750 that it works, but this one dont work....
normis
Thu Sep 10, 2009 1:18 pm
you must use Winbox on the first startup, it will ask you about config, and you will have the ability to push the "remove config" button. NO configuration needs to be added in your laptop. Use Winbox over MAC address if you wish
Krusty
Thu Sep 10, 2009 1:26 pm
I think you dont read what I wrote up there :)
now its pointless I will send it to my reseller, cause it seems to be broken piece :) I've bought a lot of routerboards, but none behaved like this one... grrr :?
normis
Thu Sep 10, 2009 1:34 pm
As I said, you need to change the PC first
Like I said, it's a windows driver issue
Krusty
Thu Sep 10, 2009 1:39 pm
I tried to connect to MAC from one PC, where It works, same error "index missing"....
normis
Thu Sep 10, 2009 1:41 pm
OK, do the following:
1. connect a simple ethernet cable from this pc to the first port of the RB750
2. turn off ALL firewall and antivirus programs on this PC, try to do this on a non-Vista machine :) you can even right-click and run Netinstall as administrator
3. Run netinstall and enable PXE in the settings
4. Turn on the RB750 while holding the button, hold the button until the LED turns off, then release button
5. wait until it appears in Netinstall window of devices
Krusty
Thu Sep 10, 2009 1:48 pm
1. done
2. done, hate vista, so there is no problem :lol:
3. done - Ip set to 172.30.183.222
4. done
5. no result, RB dont appear I only see my own HDD drives
I was so desperate that I tried to boot simple PC to netinstal, only to see it work, yes, PC boot to netinstall PXE, got the IP I set, but RB dont....
normis
Thu Sep 10, 2009 1:53 pm
ok, in that case, contact the seller, sorry
Krusty
Thu Sep 10, 2009 1:56 pm
no need to apologize, I am glad that you try to help me :)
thanks for help
GuJack20
Trainer
Trainer
Mon Oct 05, 2009 1:24 pm
Tried with different Netinstall versions with no success in RB750 until i found MikroTik Router Installer 3.29 (the new way of naming Netinstall i think) and everything run smoothly as described in the previous posts, so you MUST use MikroTik Router Installer 3.29.
--Do you remember that guy who gave up? Neither does anybody else!
normis
Mon Oct 05, 2009 1:32 pm
Interesting. That will be changed to Netinstall, thanks for noticing :)
gowifi
Wed Nov 18, 2009 1:31 am
Hi There, I just had a RB/411R that seems to have a corrupt OS so I thought I would Netinstall using the info above and it does not see the Netinstall program. Unfortunately I do not have a copy of Netinstaller 3.29. I have used Netinstall for years with the standard method using the serial port so am sure it is set up correctly. Any thoughts?
Thanks Dale.
normis
Thu Nov 19, 2009 9:41 am
try Netinstall 4.2, and do what the Quick Guide tells you to - hold the button, turn on the router, when the LED goes off - release the button. Then it will start looking for netinstall servers.
http://www.routerboard.com/pricelist/do ... ile_id=124
winet
Thu May 13, 2010 2:59 pm
i've gotten the same problem, after trying to upgrade to 4.9, the OS got corrupted. but then, reading this thread and following normis instructions, i've successfully netinstall-ed the RB750, thanks
lukkes
Sun May 23, 2010 7:08 am
Hi, it works for me with netinstall 4.9, holding the reset button near the power plug, until the ACT led stop blink, and wait a few seconds the netinstall detect the RB750...
If you found this post useful don't forget about the karma viewtopic.php?f=1&t=41148
Feed Your FAITH Then Your Doubts Will Starve To Death...!!!
adriavidal
Tue Sep 27, 2011 1:42 am
My router board 750 seems totally bricked.
Booted with the reset button pressed do nothing, none beep, no blink, all the leds get on, only act is off.
Any suggestion is welcome, thanks.
boardman
Wed Feb 15, 2012 8:07 pm
Our's too, was fine, upladed 5.13 .npk file, reboot ... then bricked ... connected port LED is ON, then all LED turn ON the unit reboot PWR and ACT LED always on ...
Netinstall do not work.
Any ideas?
Regards
Caci99
Thu Feb 16, 2012 2:28 pm
from the user guide document on RB750 (http://routerboard.com/pdf/356/rb750gl-ug.pdf):
Hold this button during boot time longer, until LED turns off, then release it to make the RouterBOARD look for Netinstall servers.
Try it once more before giving up.
-Toni-
boardman
Thu Feb 16, 2012 6:48 pm
Any ideas?
Regards
Will do, thanks
Users browsing this forum: Google [Bot] and 110 guests
