MUM Europe 2020
Real
802.11n real test and work on my network
Thu Jul 23, 2009 8:32 pm
Hello ,
i am not very good in english ,but i think i can help answer in question about real work of N standart.
In my city 5gh band is used allmost all posible chanels ,one radios use 5gh others 5gh-turbo and other then scaning i find about 5-8 N standart radios ,is not good for my network but all working fine :)
in both ends i have rb600 with full 8 slots used, 3 cards in one end use 5gh-turbo and one r52n ,in other rb600 2 cards use 5gh-tubo and one r52n.
before i use Nstrem2 to conect these 2 rb600
distance betwen them is 2.4km ,used 4 panel 23db antenas, 4x 5gh 16db wireless cards ,5gh-turbo mode ,bandwidth is about 30mbps in+out.
Now (about 1 weak) this bridge is working on N standart.
used 2 dishes 26db ,i rebuild from one polarization to V+H polarization ,2 r52n wireless cards in rb600.
optimal seetings i tested and used i find then all instaled on tower,optimal frequency is hard to find but 5210mhz is work best there.
other seetings :
AP: ap-bridge mode
set 6 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no \
antenna-gain=0 antenna-mode=ant-a area="" arp=enabled band=5ghz-onlyn \
basic-rates-a/g=6Mbps basic-rates-b=1Mbps comment="" compression=no \
country=no_country_set default-ap-tx-limit=0 default-authentication=yes \
default-client-tx-limit=0 default-forwarding=yes dfs-mode=none \
disable-running-check=no disabled=no disconnect-timeout=10s \
frame-lifetime=0 frequency=5210 frequency-mode=manual-txpower hide-ssid=\
no ht-ampdu-priorities=4,5,6,7 ht-amsdu-limit=8192 ht-amsdu-threshold=\
8192 ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 \
ht-extension-channel=above-control ht-guard-interval=any ht-rxchains=0,1 \
ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mc\
s-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15" ht-txchains=0,1 \
hw-fragmentation-threshold=disabled hw-protection-mode=none \
hw-protection-threshold=0 hw-retries=15 mac-address=00:0C:42:3A:C7:CA \
max-station-count=2 mode=ap-bridge mtu=1500 name=myssid \
on-fail-retry-time=100ms periodic-calibration=disabled \
periodic-calibration-interval=600 preamble-mode=short \
proprietary-extensions=post-2.9.25 radio-name=000C423AC7CA rate-set=\
default scan-list=5200,5210,5220,5260,5310,5750 security-profile=default \
ssid=k.n.belaidis.net station-bridge-clone-mac=00:00:00:00:00:00 \
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tx-power-mode=default \
update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=\
bridge1 wds-default-cost=100 wds-ignore-ssid=no wds-mode=dynamic \
wmm-support=disabled
/interface wireless manual-tx-power-table
default seetings
/interface wireless nstreme
set myssid comment="" disable-csma=no enable-nstreme=yes \
enable-polling=yes framer-limit=3999 framer-policy=exact-size
client: station WDS
/interface wireless
set 7 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no \
hw-protection-threshold=0 hw-retries=15 mac-address=00:0C:42:3A:D3:C2 \
max-station-count=2007 mode=station-wds mtu=1500 name=myssid \
proprietary-extensions=post-2.9.25 radio-name=000C423AD3C2 rate-set=\
default seetings
enable-polling=yes framer-limit=3200 framer-policy=exact-size
first test before instalation :)
test made from PC to RB600 ,2.4km distance, RB show procesor 100% busy, one weak after instalation :
Real
Re: 802.11n real test and work on my network
Thu Jul 23, 2009 8:39 pm
my RB600 case:
Real
Thu Jul 23, 2009 8:43 pm
rebuid antena :
nz_monkey
Fri Jul 24, 2009 12:22 am
Those are a nice case, who manufactures them ?
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
Real
Fri Jul 24, 2009 1:11 pm
case is from wireless AP (2.4ghz) ,manufacturer Phenet ,it have only one N type conector ,
i dril holes and instal other pigtail's ( 10 pigtail's )
InoX
Fri Jul 24, 2009 6:18 pm
you know that the speed is low?!
Real
Fri Jul 24, 2009 9:04 pm
InoX ,yes i know that ,but because the test is made from pc to other side rb600 with all clients conected,2 eoip tunels and all wireless interfaces on , rb show about 45% procesor load ,then start test the procesor is 100% loaded , in future i do pc to pc test...
Real
Fri Jul 31, 2009 12:21 pm
Now both antenas is aligned for best signal and performance.
heavy rain today :wink:
i made UDP test's from PC to ather end RB600 : PC----RB600>>(N wireless)>>RB600
Vaako
Sun Feb 05, 2012 8:54 pm
@Real
What brand is that dish you are using?
Can you post more pics about the antenna feeder?
Please send me a personal mail I like to ask you others things too!
(i now it's an old post but i realy want to get more info about it)
Regards,
Vaako
npero
Mon Feb 06, 2012 7:46 am
Me looks like this is the dish is using in picture
http://www.voltplus.co.rs/Antene/P-seri ... 524P2.html
Vaako
Mon Feb 06, 2012 7:15 pm
@npero
Thanks for your response!
Thats exacly the antenna he is using:
brand: VOLTPLUS
model: 5542
He has modify it for dual-polarization and the model: 5524P2 is already dual-polarized.
The main problem of his modification is that the two antenna elements are too close to each other and causes interference!
Shure it wil work but not optimal.
Regards,
Vaako
elbena0
Mon May 07, 2012 7:46 am
Hello:
WOW Nice Case, looks like carrier grade!!!
Can you please post where can I get those kind cases, URL? or address.
Thanks in advance,
Joaquin
Chronicaust
Mon May 07, 2012 9:27 am
Are you not worried about cross-interference with 6 radios in one box? Maybe that is part of your noise problem.
Users browsing this forum: No registered users and 34 guests
