jone8880
broken wireless N in 4.04b
Sat Jul 25, 2009 1:15 am
after upgrade from 4.03 то 4.04 my wireless connection via N-card absolutly DEAD in all modes (5 g too) Interface enabled but dont scan nothing.
Gerard
Trainer
Trainer
Re: broken wireless N in 4.04b
Sat Jul 25, 2009 3:43 am
Try turning off adaptive noise immunity on both sides..
Certified Mikrotik Trainer
jone8880
Sat Jul 25, 2009 1:37 pm
adaptive noise was off
downgrade to 4.03 - everything work again
ps.
wireless card on chip Atheros AR928X (AR5BHB92/AR5009)AR5BHB92..miniPCIe
Chupaka
Sat Jul 25, 2009 3:36 pm
please write to support@mikrotik.com with supout.rif attached
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
jone8880
Sat Jul 25, 2009 9:23 pm
sent
jone8880
Tue Jul 28, 2009 1:17 am
i thinking that the problem with PCIe wireless cards because miniPCIe on chip AR5008E-3NX(AR5BXB72) dont working too but was working in 4.03b.
HaQs
Wed Jul 29, 2009 12:09 pm
I confirm problem with ROS 3.0 b4 - N pakage
When i upgrade ROS 4.0 b3 to b4 - card R52N mode 802.11a (apbridge - station WDS) On ROS b3 link estabilished , when i upgrade 0 packet RX, 0TX. Link Disconected. Scan ok. but don`t connect.
(ROS upgraded only on APbridge side).
uldis
Wed Jul 29, 2009 12:52 pm
just tested between two RouterOS v4.0beta4 with R52N and got working it in regular A mode and also in N mode with WDS (of course not at the full speed as with WDS you can't get the full speed).
HaQs
Wed Jul 29, 2009 1:58 pm
I tested with:
AP BRDGE (dynamic wds) ROS4.0 B4
STATION WDS ROS 3.25
Station can`t connect to AP
Witch ROS 4.0 b3 connecting OK
802.11.a without NSTREME
uldis
Wed Jul 29, 2009 3:16 pm
Just tested AP R52N card in 5ghz A mode using v4.0beta4 and Client with Station-WDS with R52 card using v3.27 connecting fine and traffic working passing without problems.
andreacoppini
Trainer
Trainer
Wed Jul 29, 2009 6:03 pm
uldis:
miniPCIe cards.. not the R52N
- No strings attached -
<< Please give good Karma if this post helped you. Press the + button above the Location entry
HaQs
Thu Jul 30, 2009 12:54 am
I Found bug.
In ROS B4 When: ADAPTIVE NOISE IMMUNITY enabled (AP and client mode) then AP don`t connect any CPE. In beta3 when enabled this option then all ok.
uldis
Thu Jul 30, 2009 11:02 am
I Found bug.
we will try to fix it.
uldis
Thu Jul 30, 2009 11:04 am
uldis:
Tried with mini-pci express wireless card and it is working fine in 2.4ghz mode. It is an Atheros XB91 reference design based card.
jone8880
Fri Jul 31, 2009 1:10 am
AR928X (AR5BHB92/AR5009)..miniPCIe
AR5008E-3NX(AR5BXB72) miniPCIe
don't work in 4.04b. i dont have other card for test.
uldis
Fri Jul 31, 2009 10:08 am
and when you just use Scan do you see other networks?
jone8880
Fri Jul 31, 2009 1:16 pm
no
uldis
Thu Aug 06, 2009 3:25 pm
no
you can check your router now - it should be working as we placed a fix there.
jone8880
Thu Aug 06, 2009 10:05 pm
no
I've make test fixed 4.04 with 4.03( the same cards). From 4.03 to 4.04 data transfer with normal rate, from 4.04 to 4.03 data transfer with rate 10-50 kb. Signal quality show 95-98% in two way. With nstream don't working- every time disconnect- data lost. So if you will place fix to other router you will test it together. See mail.
jone8880
Wed Aug 12, 2009 8:49 pm
ok.. its fixed. stay some problem with frame police.
Users browsing this forum: Beorn, gkk, Google [Bot], matthewkirby, sindy, tomislav91 and 75 guests
