davidw
Upgrade Script not running
Fri Aug 14, 2009 5:05 am
Hi There,
When I create and run this script the upgrade part works but the reboot does not.
/system script
add name=script1 policy=ftp,reboot,read,write,policy,test,winbox,password,sniff source="/system routerboard upgrade\r\n/system reboot\r\n"
I have to create 2 separate scripts to get the job done ?
Have tried all sorts of ";" delay 1's combination etc
Any ideas ?
Cheers
davidw
Re: Upgrade Script not running
Fri Aug 14, 2009 6:18 am
For anyone who is interested I got it to work this way.
/system script add name="upgrade" source="/system routerboard upgrade"
/system script run upgrade
/system reboot
Chupaka
Fri Aug 14, 2009 11:11 am
/system reboot
wo_Ot
why not just
/system reboot
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
davidw
Sat Aug 15, 2009 4:26 pm
/system reboot
wo_Ot
why not just
/system reboot
Tried that but it just did not seem to work in fact thats what I tried the very first time.
The system routerboard upgrade command ran but the reboot did not happen.
Chupaka
Sat Aug 15, 2009 7:12 pm
but you still do reboot manually - what has been changed?.. %)
davidw
Sun Aug 16, 2009 1:23 am
I should mention that I am running these commands via ssh remotely, not via local terminal.
Chupaka
Sun Aug 16, 2009 1:24 am
hmmm... are you waiting for reply, or simply send both commands?..
davidw
Sun Aug 16, 2009 1:36 am
Just sending both commands
Chupaka
Sun Aug 16, 2009 3:22 pm
maybe that's the problem...
ManyX
Tue Jul 10, 2012 1:27 am
You may import this script from scheduler
/import upgrade-fw.rsc
upgrade-fw.rsc
:if ([/system routerboard get current-firmware] != [/system routerboard get upgrade-firmware]) do={
:log error "Bios need upgrade";
/system script add name="upgrade" source="/system routerboard upgrade";
/system script run upgrade;
:delay 5;
/system script remove [find name=upgrade];
:delay 5;
/system reboot} else={:log warning "Nothing"}
regards.
BD
Users browsing this forum: cvalavik and 40 guests
