MUM Europe 2020
bney
Need to have the Dude send email when SNMP Oid changes
Fri Aug 14, 2009 7:56 am
We run a rural network with lots of battery systems in real remote locations. We need to have the dude trigger an email to the on-call pager when a specific oid, in this case the input voltage, drops below a specific threshold. I am not seeing an obvious way to do this, but that merely shows that I have not yet been initiated into the mysteries of this layer of Dude knowledge. Help from anyone would be appreciated.
sergejs
Re: Need to have the Dude send email when SNMP Oid changes
Mon Aug 17, 2009 2:34 pm
Yes it is possible.
Create new Probe,
which will be called Voltage,
select Type as SNMP,
put correct OID (which is reporting voltage),
set correct compare method to declare that service is down when value is lower.
Go to the Notification,
create new notification with type e-mail, correct server and correct e-mail
Go to the correct network map and select device, where voltage should be monitored.
Add Voltage service for device monitor,
switch to Notifications and check e-mail notification to use for voltage monitoring.
lebowski
Mon Aug 17, 2009 5:04 pm
yes it is quite simple, Check out the probe thread and search the dude forum for APC or UPS.
bney
Tue Aug 18, 2009 8:43 am
Many thanks from the Dude Newbie.
el berto
Tue Sep 24, 2013 5:31 pm
Hi, I haven't an internal server, so I would like to use gmail.
1) in server field Dude gives me error if I don't insert numerical IP address (instead of "smtp.gmail.com")
2) where can I insert e-mail access settings (username and password)?
Regards, Michele.
PeterSullivan
Thu Sep 26, 2013 2:17 pm
Yes it is possible.
Create new Probe,
Thanks sergejs for this simple explanation.
Users browsing this forum: No registered users and 4 guests
