karo84
BUG IN FIREWALL!!!
Sat Aug 15, 2009 6:32 am
HI!
/ip firewall filter print chain=forward
0 chain=forward action=accept src-address=23.3.3.10
then
/ ip firewall filter remove [/ip firewall filter find src-address=23.3.3.10]
or
/ ip firewall filter remove [find src-address=23.3.3.10]
What is going on?
I am using ROS 3.28
MT TEAM You have to fix this.
via winbox everything is ok, but via console you can add but NOT remove a firewall rule
I need to remove.
Regards Karapet
fewi
Re: BUG IN FIREWALL!!!
Sat Aug 15, 2009 6:44 am
You need to quote src-address, as it's a string.
Use
/ip firewall filter remove [/ip firewall filter find src-address="23.3.3.10"]
and it will work. It's not a bug, it's expected behavior.
HTH,
Felix
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
karo84
Sat Aug 15, 2009 11:19 am
Ia have tried. No difference.
davidw
Sat Aug 15, 2009 4:38 pm
Yep tested on v3.28 and can confirm the same behaviour
/ip firewall filter add chain=forward action=accept src-address=23.3.3.10
then
Does not work
I did get the following to remove it from the console
/ip firewall filter remove 5
not much use if you can't work out the number to remove though :)
fewi
Sat Aug 15, 2009 7:10 pm
Works for me on 3.28:
[admin@MikroTik] > /ip firewall filter add action=accept src-address=23.3.3.10 chain=output
[admin@MikroTik] > /ip firewall filter pri where src-address=23.3.3.10
[admin@MikroTik] > /ip firewall filter pri where src-address="23.3.3.10"
 1   chain=output action=accept src-address=23.3.3.10
[admin@MikroTik] > /ip firewall filter remove [/ip firewall filter find src-address=23.3.3.10]
[admin@MikroTik] > /ip firewall filter remove [/ip firewall filter find src-address="23.3.3.10"]
[admin@MikroTik] > /sys pack pri
Flags: X - disabled
 #   NAME        VERSION        SCHEDULED
 0   system        3.28
 1   dhcp        3.28
 2   routerboard        3.28
 3   ntp        3.28
 4   hotspot        3.28
 5   security        3.28
 6   advanced-tools        3.28
[admin@MikroTik] >
Users browsing this forum: Ahrefs [Bot], Baidu [Spider], Semrush [Bot] and 36 guests
