yadmin
3.28 X86 BUG?
Sat Aug 15, 2009 9:26 am
/tool cpu-test
NetworkPro
Re: 3.28 X86 BUG?
Sun Aug 16, 2009 2:38 pm
same here...
what about memory test ? :)
normis
Re: 3.28 X86 BUG?
Mon Aug 17, 2009 1:57 pm
NetworkPro
Re: 3.28 X86 BUG?
Mon Aug 17, 2009 2:41 pm
He must have entered /tool cpu-test but his picture shows just cpu maybe he hit tab or edited the picture
I tried the cpu-test and it did not work but I have found out that I can make 100% cpu by making a TCP bandwidth test from the router to the router itself but this is not a legitimate test but rather an overheating test ....
normis
Re: 3.28 X86 BUG?
Mon Aug 17, 2009 3:14 pm
/tool cpu-test
will be removed, it was only present in X86 systems, and it's only task was to excite your minds :) it doesn't do anything
NetworkPro
Re: 3.28 X86 BUG?
Mon Aug 17, 2009 3:26 pm
Is this a joke? So when my customers ask me - why the MikroTik routers do not work too often I will tell them - "Well they claimed they would work just to excite your minds. We will remove them now and replace them with Linux ;)"
normis
Re: 3.28 X86 BUG?
Mon Aug 17, 2009 3:47 pm
what did you expect me to say? OK. this was a bug, it will be fixed. there is no such command!
Users browsing this forum: GoogleOther [Bot] and 33 guests
