m4rk0
Suggestion / request for Routerboard hardware
Wed Aug 19, 2009 1:08 am
I want to suggest for new or upgrade current RouterBoards with at least one I/O RELAY (electrically operated switch) which would be controlled through RouterOS...
That wouldn't be big problem for Your electrical engineers...
Relay would be cool eg. to reset power supplies if on same location other RBs freeze or something like that and You want to restart them (for Output) OR for Input to add motion sensor and log activity on RB... + SCRIPTING it would be WONDERFUL!!! Etc...
And would be nice to add some kind of HARDWARE watchdog not in-software watchdog for reseting if ether/wlan ports are frozen...
Thank You and I hope You will consider about requests :)
normis
Re: Suggestion / request for Routerboard hardware
Wed Aug 19, 2009 2:03 pm
You can already monitor serial port signals: http://www.mikrotik.com/testdocs/ros/2. ... gwatch.php
Also, a number of routerboards have fan headers that can be connected to low power relay.
m4rk0
Wed Aug 19, 2009 9:51 pm
I didn't know for SIGWATCH...
Can You tell me how can I control fan headers to send signal to relay?
ctech4285
Thu Aug 20, 2009 4:09 am
i want temperatrue sensor and voltage sensor on board so i can narrow down why the routerboard runs unstable
normis
Thu Aug 20, 2009 8:54 am
some routerboard model already have voltage monitors
m4rk0
Thu Aug 20, 2009 3:22 pm
Does RB433, RB433AH, RB600 has fan headers and how to control them through ROS?
ctech4285
Fri Aug 21, 2009 2:31 am
RB433, RB433AH do have fan headers..
unter system helth you got a couple of options
m4rk0
Fri Aug 21, 2009 2:42 am
I can't find how to send signal on fan headers... If I put RELAY there...
