erudite
change IP, GATEWAY and DNS ADDRESS
Tue Sep 15, 2009 1:43 pm
I have mikrotik 2.9.45 version configure by one engineer who have left the company.It is configure as dhcp, NAT and firewall. We have a change of IP ADDRESS. Pls can somebody help me on how to change it to the new ip , gateway and DNS ?
SurferTim
Re: change IP, GATEWAY and DNS ADDRESS
Tue Sep 15, 2009 3:37 pm
Should not be a problem. I use ssh to manage my MT boxes.
add address=xx.xx.xx.xx/xx interface=ether1
/ip route add gateway=xx.xx.xx.yy
set primary-dns=zz.zz.zz.zz
set secondary-dns=ww.ww.ww.ww
Replace all with appropriate settings. Remove the old settings once the new ones operate ok.
erudite
Wed Sep 16, 2009 11:37 am
Thanks for your reply. If i implement all this command script with the new set of IP paramenter, won't it remove the old IPs ? OR How do I remove the Old onces after implementation. thanks
SurferTim
Wed Sep 16, 2009 12:07 pm
Inserting the new ips will not remove anything. The old ips should remain and working until you remove them.
print
remove X
Replace X with the line number of the ip you wish to remove. Same with the gateway.
erudite
Wed Sep 16, 2009 12:19 pm
Thanks once again. Now inserting the new ips with the old once in place, will it work with the new ip settings without removing the old onces ?
SurferTim
Wed Sep 16, 2009 12:26 pm
Yes. It should work with both ips.
ADD: The one it uses is normally determined by the masquerade or srcnat in "/ip firewall nat". If you use the masquerade rule rather than src-nat, the results may be unpredictable until you remove all but one ip from that interface.
erudite
Wed Sep 16, 2009 1:28 pm
AM greatful, I will implement this then get back to you later.
erudite
Thu Sep 17, 2009 12:28 pm
It works after removing the former gatway IP.
thanks once again.
bye
Users browsing this forum: Sob, soltero128 and 103 guests
