MUM Europe 2020
Nanflexal
Startup WISP - Help with initial config of RB750
Wed Sep 16, 2009 7:48 am
Hello guys, I'm new to mikrotic product so i need help about configuring RB750, I need help to combine 6 ISP & 3 dual wan dlink router and RB750.
Dual wan Link Router.
internet(1,2)----> dlink1
internet(3,4)----> dlink2 ------>RB750 ------>APs
internet(5,6)----> dlink3
I can't find affordable router that can bond 6 or 8 ISP so i will start Dlink lb-604 as starting WISP.
I plan to start 6 Mbps for culasi, calayuan, calintaan and bon-ot but as starting we have 15-20 sure users in this area.
Thank you very much
Alex
angboontiong
Re: Startup WISP - Help with initial config of RB750
Wed Sep 16, 2009 9:23 am
You may look for the Big 5 Load balancer...
Nanflexal
Wed Sep 16, 2009 12:49 pm
thank your input angboontiong, can you give me the exact model or link to that product?
Alex
InoX
Wed Sep 16, 2009 3:55 pm
Price: US $2,145.00
Condition: Refurbished
good luck
Nanflexal
Thu Sep 17, 2009 2:45 am
Price: US $2,145.00
good luck
I can't affor to buy it this time. maybe later once my network become operational.
anyway, I will try to Bond 4 or 6 ISP using Ubuntu. Thanks
normis
Thu Sep 17, 2009 10:34 am
RouterOS can't combine links to achieve 4x the original speed, but it can do load balancing and policy routing. RouterOS supports bonding only if at both ends of the link there are mikrotik routers
mobilexpi
Thu Sep 17, 2009 4:42 pm
normis:
I want to know if is it possible to install Mikrotik on a Virtual Private Server (in a datacenter) and then bond both links between my RB450G and the mikrotik virtualized?
Do you understand my idea?
angboontiong
Thu Sep 17, 2009 5:48 pm
or may u look for planet load balancer...
http://www.planet.com.tw
Nanflexal
Fri Sep 18, 2009 4:47 am
guys, do you have a guide on how to configure RB750?
My setup would be:
Thanks in advance.
@ Alex
Nanflexal
Fri Sep 18, 2009 9:08 am
Guys, i have another question, i was thinking of my 6 ISP with 1 Mbps speed in matnog, so i would like to know if my 6 ISP can reach in Bon-ot big?
Thanks in advance for your reply.
@ Alex
Nanflexal
Sat Sep 19, 2009 3:13 pm
after some consideration and presentation of technicals staff from reseller of qno product in the philippines, I will use their Load Balancer appliances with 4 WAN port, This load balancer has a fantastic features, you can make fail over or load balancing or use your 3 ISP at the same time.
some feature:
multi subnet
virtual protocol
Protocol Binding
WAN Transparent Bridge Mode
take note: this load balancer does not bond ISP / dsl connection.
My backbone is 4 ISP with 1 Mbps each. once my network is complete, i have 10 customer in culasi and 10 customer in calintaan and culayuan and 10 in bon-ot big. how many user can share this connection?
Nanflexal
Thu Sep 24, 2009 7:43 pm
anyone use RB750 to manage port range and is this manage switch?
Users browsing this forum: No registered users and 36 guests
