in4ni
WDS Bandwidth issue
Thu Sep 24, 2009 10:32 pm
I have a confusing bandwidth issue.
All APs are RB433's with R52H's,
Fileserver - AP1 - AP2 - AP3
AP 2 has 2 radios and is acting as my repeater
Bandwidth between AP1 and fileserver is geat (hard wired)
Bandwidth between AP1 and AP2 is ok (15mbs)
bandwidth between AP2 and Server is ok (15mbs)
WDS link established AP2 wlan1 and AP1 (WDS1)
Bandwidth between AP3 Wlan1 and AP2 Wlan2 is ok (17mbs)
Another WDS link established between AP3 wlan1 and AP2 Wlan2 (WDS2)
Here is where the problem is
Bandwidth test between AP3 and AP1 sucks (3mbs)
seems like im loosing bandwidth acriss the bridge, I have tried RTSP and that doesnt help
Any suggestions?
Thank you
Aug
Re: WDS Bandwidth issue
Fri Sep 25, 2009 12:25 am
Is it possibly interfence? Check your channels.
Aug
in4ni
Fri Sep 25, 2009 12:29 am
Thank you for the reply
I have tried different channels and i have lots of seperation between channels (wds1 and wds2)
thank you
Aug
Sat Sep 26, 2009 4:37 am
What's the bridge config on AP2?
/ interface bridge export
I sure miss the fishing in Jax.
Spent 15 years there bouncing between Naval Air Stations.
Aug
in4ni
Sat Sep 26, 2009 3:32 pm
# jan/02/1970 00:03:00 by RouterOS 3.28
# software id = 016T-GT92
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes \
comment="" disabled=no forward-delay=15s l2mtu=2304 max-message-age=20s \
mtu=1500 name=bridge1 priority=0x8000 protocol-mode=rstp \
transmit-hold-count=6
add bridge=bridge1 comment="" disabled=no edge=auto external-fdb=auto \
horizon=none interface=wlan1 path-cost=10 point-to-point=auto priority=\
0x80
horizon=none interface=wlan2 path-cost=10 point-to-point=auto priority=\
0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=\
no
[admin@AP-2] /interface bridge>
Aug
Sat Sep 26, 2009 6:31 pm
No queues, right?
Are you using nstreme?
Try disabling conn tracking
set enabled=no
Aug
in4ni
Sat Sep 26, 2009 6:56 pm
No Queues
no firewall rulz
Tried Nstream and that didnt seem to help much
Just turned off connection tracking to no avail
Thank you for the suggestions!!
Have a great weekend
und3ath
Wed Nov 04, 2009 11:05 pm
I have the same problem...
I had for 4 years this configuration: Ap1(rb133c) <- Ap2 (rb133c) -> Ap3(rb133c)
everything ran ok Ap1 --> Ap3 max 15 Mb
the same between Ap1, Ap2, and Ap2, Ap3
Cards were CM9
Last weekend I replaced AP1 and AP3 rb133c with RB411AH and R52s
In the middle AP2 there is now RB433AH with 2 R52s
It runs on 5G turbo (same frequencies and dishes as before)
NOW:
AP1 --> Ap2 cca 40-50Mb/s (UDP test)
AP2 --> Ap3 the same
but AP1--> Ap3 15 Mb/s
When there were rb133s the processor went to 100% at this speed. So I thought, the 15Mb/s speed is because low processor speed. But now the speed is the same 15Mb/s and processor on RB433 is on 6%...
Any ideas?
P.S. Router OS 3.30
in4ni
Wed Nov 04, 2009 11:18 pm
very frustrating for me as i like MT products. I had to use another product for this project as Mikrotik couldnt cut it. I just cant use Mikrotik with my hi-end customers as the lack of support in a situation like this would get me in a lot of trouble.
Just my 2 cents
Users browsing this forum: YaCy [Bot] and 23 guests
