eben
Sample Installations - Sticky Please
Sat Sep 26, 2009 6:07 pm
Everybody,
Please upload pictures of your installations. It'll help guys who aren't as experienced as some of us a good idea of how to do things right.
I'll get the ball rolling with an RB411, an R52 and a 24dBi grid antenna with 3m LMR400 cable.
Here's an RB600 mounted in an IP65 box.
normis
Re: Sample Installations - Sticky Please
Mon Sep 28, 2009 1:33 pm
no grounding for the board?
eben
Mon Sep 28, 2009 2:13 pm
Photo taken halfway through installation :)
Here's one of an RB600 and a RB433AH in the same box.
RB433AH bolts to the backplate with brass bolts.
RB600 used plastic stick on mounts. Hence ground cable.
jalokim
Tue Sep 29, 2009 8:09 pm
My PC boxes;)
jalokim
Tue Sep 29, 2009 8:11 pm
abbakadu
Wed Sep 30, 2009 9:33 pm
Hi All
We are busy to install a mikrotik network in RSA, we have learned the hard way about winds on our high sites. We have used 38mm by 1.6mm steel poles then our August winds came and blew our hole structure down and we had to rebiuld it with 50mm by 10mm steel poles and straped it down with 10mm cables, the grids had to be tied at the back with cables aswell becaus the L bracked have broken off by the wind, here are pickture after the rebuld Image
marioclep
Trainer
Trainer
Wed Oct 07, 2009 8:21 pm
:D :D :D
JwTPN
Thu Oct 08, 2009 12:35 am
Couple of piccy's to share, some might remember some pictures from a MUM presentation in singapore a couple of years back..
How we have built a tower structure in a VERY windy location with only 3 holes in the ground as well (hard to access site and VERY hard ground) - Note fence around bottom keeps animals etc out and provides strentgh to overal structure..
How we apply earthing to Coax cables at the bottom of one our our standard poles.
There has been a lot of talk in the past about the whole earthing issue and i suspect its something many people overlook.
Site im just building showing how i like to make use of wooded poles with microwave dish's (i hate wooden poles)
Also, note use of cable clamps, not a zip tie in site...
Enriq766
Tue Oct 13, 2009 6:42 pm
This is pretty typical of all our Smaller AP's. We have 5.8 back hauls to a Local 900Mhz XR9 system
What we have up top
Here is a custom job I did for the top of a building in the center of town
Proof that cisco and mikrotik can live in the same box :) This is 224 feet up on a coal burner for a power plant. Coal dust was an issue so silicone was used on the door and vent holes.
nz_monkey
Wed Oct 14, 2009 4:38 am
Hi Justin,
I really like the three pole tower design, the added strength eliminates any issues with "sail" area from the panels. We have been using the lighting arrestors to earth the cables as well as provide some protection against strikes, are you using the shield penetrating earth kits as well as arrestors, or just the earth kits ?
Regards,
Andrew
JwTPN
Thu Oct 15, 2009 1:07 pm
Hi Justin,
Regards,
Andrew
Yip that structure can handle a lot of load with panels or big dish's, and can have the tops extended -see the flanges on top (or doubled) to give more height if required.
As irony would have it im visiting that site tommorow (first time in a year) because a bad wind in a storm has destroyed the solar panels?!
To be honest we dont bother with lightening arrestors anymore couple of points why;
1: If lightening really has a go the gear is toast, give up, its cheap gear replace it...
2: Its really the static buildup (misty water laiden wind etc) that we are trying to get rid off and it normally shows with better more solid connections and long lasting wireless cards..
The effect has been though since being a lot more pro-active in earth things (and no we arnt perfect not every site is done - just the worst ones) i cant remember the last card we have had to replace thats had a fried rx or tx in it? (for no apprant reason)
Dont get me wrong either, we have a lot of sites in harsh places like the Marlbrough sounds and had a network down the west coast (south island) so these things get some discharge around them..
So to answer the question, earth kits only.
(usualy cabinent has an earth bar in it as well for radios/other gear as well)
PS- You ever get down this way Andrew? -Beer...
nz_monkey
Tue Oct 20, 2009 4:03 am
Hey Justin,
Yes I come down that way every now and then, I am actually down there next week. It would be great to catch up for a beer.
This is a bit ot, so might be best to email me tauranga at btg.co.nz
Regards,
Andrew
Ibersystems
Tue Oct 27, 2009 1:43 am
this is how to install a tower PART1
Mount the tower and the steel wires. These are steel wires of 8mm of diameter.
Mount the base tower and atach the tower to it with some help.. :lol:
Put the different level wires into the wires installed supports
Ibersystems
Tue Oct 27, 2009 1:46 am
this is how to install a tower PART2
Test and revise the tower with care when wires are fully installed
Claim for some help again to go up to the tower and
easy install the equipement
eben
Tue Oct 27, 2009 7:14 am
I'm worried about the weld penetration on this bracket.
Did you get this bracket x-rayed before mounting it?
Did the fabricator use plug welds from the back for added strength?
Ibersystems
Tue Oct 27, 2009 11:03 am
believe me, this support is very safe. It's 1 cm depht. It's welded and has 3 layers of protective coating. I'll send you more pictures when I have time.
CastorTroy
Wed Oct 28, 2009 10:58 pm
What we have up top
What kind of luck have you had with the DLI reboots? We've got 30 of them deployed, all running the latest firmware.
About 1/4 of them work, and are being replaced with products from Synaccess as budget allows.
*edit*
to add, all of our installations with failed DLI's are in climate controlled and power conditioned racks
nz_monkey
Thu Oct 29, 2009 10:18 pm
Here's one I did a few years back, we changed out 8m LMR spooled on the mast for some 4metre ones the next day. Identical setup at the far end. RB600 with 2xR52 running NStreme2 over 40Mhz channels with 80mbit full duplex, it was only just over 1 kilometer so TX power is as low as we could set it!
It could probably go faster, but seemed to be CPU limited as they were pegged at 100% during testing.
eben
Sat Nov 07, 2009 8:06 pm
Galvanised frame against the wall.
The hole through the wall is for 220V AC that's supplied from UPS in server room.
IP65 cabinet
Connector makes it easy to shut down power when maintenance is required.
28V / 12V industrial PSU
28V DC is run through LM7824 to reduce to 24V
2 x RB433AH
2 x R52H
2 x R5H
Bottom fan draws air through a filter
Top fans expel air into cavity behind the box
Cabinet is earthed to the antenna mounts and to an earth rod.
matrot2
Mon Nov 09, 2009 12:52 am
We install RB very close to the antenna.
UPS for 230 sometimes crash, then we use the AD-55 or AD-155 - http://tandem.ck.ua/ups_mt-eng.php.
Monitoring food http://tandem.ck.ua/ups_mtm-eng.php.
UPS-MT-monitor can also control the power, if RB411 (433) does not want to respond (hangs).
danielillu
Mon Nov 09, 2009 2:59 pm
Nice and neat install!
Where did you find those UPS-MT-monitor?
matrot2
Mon Nov 09, 2009 8:35 pm
UPS-MT-monitor produces enterprise "Tandem" in Ukraine.
Today, UPS-MT-monitor use in Poland, Sweden, Denmark, Italy, New Zealand ..... :)
spectrasurf
Fri Nov 13, 2009 3:19 am
eben,
who makes that enclosure? where did you buy?
eben
Fri Nov 13, 2009 8:33 am
eben,
We have outsourced cabinet manufacture to a company in Zimbabwe called "Electro Panels".
rmichael
Forum Veteran
Forum Veteran
Fri Nov 13, 2009 11:47 pm
The enclosure looks similar to one sold by many including streakwave (see streakwave enclosure on their website).
cramerit
Mon Dec 14, 2009 10:07 pm
For one of our backhauls..
433ah x2
R52n x2
Transtectors
Polyphasers
Enriq766
Tue Dec 29, 2009 7:32 pm
*edit*
Only problem we have ever had with these is 1 fan went bad and was buzzing very loud. They sent us a new one (fan) and took me 5 min to change out.
CastorTroy
Tue Dec 29, 2009 9:54 pm
*edit*
Interesting. Glad they're working for you. We had nothing but problems, and their customer service was not helpful to us at all.
j2sw
Fri Jan 08, 2010 5:45 pm
We have been posting some install photos on our page at http://www.mtin.net/blog. Been trying to post one a day
m4rk0
Sat Jan 09, 2010 6:15 pm
Nice, many great installations!! Good job!
I'll submit soon some of our installations...
BobcatGuy
Sat Jan 09, 2010 8:45 pm
I would be more worried about the grade 5 bolts used on there then the welds. I mean the welds do not look very good to me either, and they should of built them up more. But the welder was thinking what I was, Its a small tower anyways. Good to see they sealed the top to stop water from going behind the bracket and freezing, well.. I think that was in NewZeland? probably doesnt freeze there anyways :-)
I think you should replace the bolts, the sheer strength on the grade 5 bolts is pretty low, and even witht he vibration from the lines, they will probably wear and break sooner then you expect. Just hope you catch it... Literally.... before it falls.
I was thinking of setting up a 10 meter tower in my back yard, do you think the neighbors would mind? :-)
eben
Sat Jan 09, 2010 9:07 pm
How about this 24m from yesteryear?
sdischer
Trainer
Trainer
Thu Jan 14, 2010 5:45 am
Ok, this has to be one of two things:
1. A microwave "corner turner" (get it, grid points 90 degrees to the panel).
2. A cheapo ISP that wont buy weatherproof enclosures. Its one way to get rid of those antiquated Tranzeos. MikroTik baby!
j2sw
Mon Jan 18, 2010 6:01 am
Ozelo
Wed Jan 27, 2010 7:34 pm
cramerit
You plug those two r52n each one on a piece that looks like a 90 degree splitter. Is that true or that is not only a splitter, but a cavity filter?? Can I use a single polarity antenna with both r52n radio chains using a 5ghz splitter??
Thank you in advance.
Ozelo
hardings
Fri Feb 26, 2010 11:17 am
The blobs are trees!
Ibersystems
Sun Feb 28, 2010 8:26 pm
Waaaaho! Its cold there!!!
conjurer
Tue Mar 02, 2010 11:04 am
Where is this?
eben
Fri Mar 05, 2010 12:32 pm
Dbii boards are very sensitive to earthing issues.
This is the F20 2.4GHz unit.
Here you can see the Dbii board is earthed to the RB411, which is in turn earthed to the radio antenna.
The radio antenna is then earthed to a copper water pipe via an earth strap.
eben
Fri Mar 05, 2010 12:35 pm
Here's Poynting's 23dBi 5GHz integrated enclosure.
normis
Fri Mar 05, 2010 12:41 pm
maybe not very cold, but humid :)
eben
Sat Mar 06, 2010 4:24 pm
RB411, RB52, Poynting 23dBi panel.
We need to go back before the rains to run the earth wire from the bracket to an earth rod.
nz_monkey
Sun Mar 07, 2010 7:42 am
Hi Eben,
Are those Gewiss boxes you use ?
eben
Sun Mar 07, 2010 10:26 am
Hi Eben,
Yes they are.
talo1019
Thu Mar 11, 2010 5:44 am
Eben, I just wanted to clarify. Do you mean the the F20 gives issues when grounded? Or that it requires more grounding?
eben
Thu Mar 11, 2010 8:00 am
No! The F20 does not give issues when grounded.
However, they do need to be grounded, which is why when you guys ship them, there's an earth cable as part of the package. I've not used one that's not been grounded properly, but I suspect that performance will decrease if it's not grounded properly.
normis
Thu Mar 11, 2010 8:02 am
a nice blog you have!
talo1019
Thu Mar 11, 2010 8:05 am
Good to hear.
Was having a discussion with my boss as to what you actually meant. He thought you meant that something was going on when you grounded it.
Thanks for clearing that up.
warwick09
Thu Mar 11, 2010 5:38 pm
I've been looking for something similar for a long time... where do you get the enclosure and attachment which affixes to the grids mounting arm?
To make sure I'm seeing correctly, thats a 24dbi 2.4 correct... (was thinking it's a 19)
would TRULY appreciate it, as Im getting tired of using bulky enclosures and having to field crimp lmr to fit the install. :D
Regards
eben
Thu Mar 11, 2010 5:52 pm
Gewiss enclosures can be purchased in most countries.
Here's a UK company that sells the product.
http://www.csedistributors.com/acatalog/gewiss.html
As for the mounting to the antenna. That's something that I designed and I get laser cut. I'm sure if you take a piece of metal and play, you'll come up with something that you can get made.
It's a 24 on a nice 50mm galv pole with 3mm wall thickness.
JorgeAmaral
Trainer
Trainer
Tue Mar 30, 2010 2:11 am
433ah x2
R52n x2
Transtectors
Polyphasers
Can you please tell my where to buy those polyphasers?
How about performance?
Kindly regards,
Jorge Amaral
dnyl
Tue Apr 20, 2010 1:41 am
Our installation in Budapest. Nstreme dual, 2*SR5, rb333, 90cm dual polarized antenna, 1,5 km p-p link, tx power: 0 dbm (!), 71 mbps full duplex.
coaxial
Tue May 18, 2010 1:00 am
awesome
kimssky
Tue Jul 27, 2010 8:22 pm
8)
Muqatil
Trainer
Trainer
Tue Jul 27, 2010 10:36 pm
Don't you get bad behaviours of the UPS batteries in an external enclosure?
j2sw
Thu Jul 29, 2010 6:28 pm
We have put several small UPSes in little enclosures. No problem with them. All our UPSes are on 2 year replacement cycles though.
j2sw
Thu Jul 29, 2010 6:33 pm
kameelperdza
Tue Aug 03, 2010 2:16 pm
My Instalation from work to my house
dingsingo
Tue Aug 03, 2010 3:08 pm
one of my Project. 5Ghz on a old Oeltower, 27m high. It stay in the middel of a small City as a museum.
24 Volt "Mean Well Powersupply" with Accu, on the Towerground.
Cases with RB/433AH, a 23dB 5Ghz Antenna to Backbone.
Two 90 Grad sEctor for connect to users.
dingsingo
edgar_abraham
Wed Aug 11, 2010 7:26 pm
Hello all
I have a couple of questions because i really want to use mikrotik to make point to point and point to multipoint links.
1.- How long the coaxial cable can be?
2.- What is the distance aprox. that you have a point to point link or point to multipoint
thanks and have a nice day.
normis
Thu Aug 12, 2010 9:31 am
1. Not more than 2m. Longer cable means loss of signal.
2. Depends on the antenna and wireless card, and also the conditions (visibility, interference, trees, water). Can be up to 200Km if conditions are perfect, and points are on mountains or big towers.
kameelperdza
Thu Aug 12, 2010 11:28 am
LMR400- cable
loss 2.4Ghz 0.50db/meter
loss 5.8Ghz 0.73db/meter
Im using 4 meter cable without any problems.
eben
Thu Aug 12, 2010 11:39 am
Kameeltjie...
Have you tried LMR600?
kameelperdza
Thu Aug 12, 2010 12:28 pm
Kameeltjie...
No sorry scoop only have lmr 195 and lmr 400. Lmr400 is much better option than lmr 195
eben
Thu Aug 12, 2010 4:16 pm
RF Designs in Cape Town sell LMR600, as well as the correct N Type connectors. They can also make up the cabels if you don't have a crimping tool.
adrianatkins
Long time Member
Long time Member
Sat Aug 28, 2010 3:43 am
The first post looks good, but i'd be much happier if there were two or three bricks on top of the legs as well as under them.
Where i live we get really strong winds in Feb + March.
The Dish would Fly.
exebug
Sat Sep 04, 2010 11:36 am
Which one would you use ???
adrianatkins
Long time Member
Long time Member
Sat Sep 11, 2010 11:16 pm
ostinato
Cool & Quiet :P
Mon Sep 13, 2010 2:02 pm
Rb493AH with custom aclyric box
- 3 ADSL Connection
- 2 Dedicated
Supply for :
1. Game Center (25pc)
2. Internet Cafe (20pc)
3. Hotspot
eben
Sat Sep 25, 2010 12:00 am
Here's a little project that I'm working on at the moment. It's still on the bench being tested, but will soon be on a tower.
I started with a galvanised plate to mount the equipment on and drilled holes and set up mounts for the RB600 / 800 and the switch.
I then cut holes for the fuse boxes, mounted the fuse boxes and mounted some PoE injectors with some cable management strips.
You can see an aluminium heat sink in the top right hand corner. Some PVRs will be mounted there.
eben
Sat Sep 25, 2010 12:03 am
Here's the back of the panel with most of the wiring done.
Power is from 2 x 12V 70A batteries that are specifically designed for this type of work. They are charged by a Meanwell PSU. Power is supplied to a series of MCBs that will be located in close proximity to the batteries.
eben
Sat Sep 25, 2010 12:18 am
The MCB panel is wired as follows:
Left MCB - Main switch, feeds 2nd MCB and stepdown transformer.
2nd MCB - 24V up the tower to the routerboard panel.
Stepdown transformer converts 24V to 13.8V and feeds 3rd MCB and fuse block.
3rd MCB - 13.8V feed up the tower to the routerboard panel.
Fuse block - Cabinet fans, GSM Commander and alarm.
Here are the RB600 and the RB450 mounted on the panel.
Here are the PVRs that provide 12V and 9V.
eben
Sat Sep 25, 2010 12:26 am
ether1 on the RB600 goes to the TPLink switch
ether3 on the RB600 goes to the RB450
ether2 - ether5 on the RB450 go to PoE injectors 10 - 13. This will allow me to set up UBNT Nanobridges or Rockets as dumb bridges and have router to router connections without any traffic collissions normally associated with switches.
The bottom 9 PoE injectors are all connected to the TPLink switch and will eventually be connected to RB711A boards that will be connected to sectoral antennas. These boards ether1 ports will all be in the same /28 subnet as ether3 on the RB600. Or, I could use UBNT rockets with their sectoral antennas to build a hybrid access point down the line.
As things stand, the RB600 will have 1 x R52H, 2 x R5H and 2 x F50Pro and will do all the AP work, but there's room for expansion ;-)
And yes, those are 2 x 512MB CF cards on the RB600.
eben
Sun Oct 03, 2010 5:15 pm
Board and batteries in and working.
I need to get some insulating material onto the door to stop any potential battery short circuits.
1 x R52
2 x R54
1 x R52Hn
2 x F.50Pro
The Lyles Golden Syrup container is used to hold mothballs.
Ibersystems
Mon Oct 25, 2010 5:58 pm
The Dish would Fly.
hoaohahoahoahohoaohaohahoahoahoa xDD
yes! Here some High voltage lines were broken last year because of wind.. : P
NetVicious
Thu Nov 11, 2010 10:07 am
Only one clamp to the wall ? Take care when you get a lot of wind.
eben
Thu Nov 11, 2010 10:40 am
The bracket is made from 5mm steel that's galvanised.
The pole is 50mm with a 2mm wall thickness. Again galvanised.
Now for the magic.
The wall plugs are Fischer "UX". They are the so called "Four Way Plugs" that expand in many directions and stick like proverbial s**t to a blanket.
That setup recently survived a storm with 130km/h winds.
NetVicious
Thu Nov 11, 2010 12:41 pm
Now for the magic.
Yeah! It sounds good. Very good clamp and very good plugs.
In this case it's should be ok, but IMHO it's better to have two clamps (of poorer quality if you want) because with only one clamp the mast will move a bit with some wind (30-50km/h) and it could create movement to the pieces (screws, nuts, ...) and this resistance could be weaken with some time. My suggestion it's always two clamps and better when more distance separates the clamps on the mast because the fixation will be better.
csallor
433,711 Combo
Tue Dec 07, 2010 6:43 pm
RB433 (3 cards) + RB711 Combo
ubunet
Thu Mar 03, 2011 6:26 pm
This work has 6 sectors Ubiquiti XM5 with 17dBi antennas-90 º.
These AP are in bridge mode and connected to a RB-493AH server does PPPoE, QoS.
In the box there are 6 feeds 24v to the AP, and two 15v for 2 NanoStation M5 that make PtP. RB-493AH 24V.
Are the antennas too close together? I've thought up another mast and separate at least 1 meter. do you think?
This is the box:
Best Regards,
NetworkPro
Wed Mar 09, 2011 10:27 am
Currently I have no proof that separating the antennas even more would have any benefit.
If it works - keep them like they are. Check signal and quality levels in high traffic times.
ubunet
Wed Mar 09, 2011 12:46 pm
Thank you, the signal is good but for now the network is in test, there are
not high traffic for the moment. I will see the production behavior in 3 month.
Best regards
biomecanoid
Wed Apr 13, 2011 7:05 pm
My installation details later on ...
biomecanoid
Wed Apr 13, 2011 7:14 pm
2. More pics
biomecanoid
Wed Apr 13, 2011 7:16 pm
3. More pics
biomecanoid
Wed Apr 13, 2011 7:25 pm
4. Hotspot
biomecanoid
Wed Apr 13, 2011 7:29 pm
aysan
Thu Apr 14, 2011 11:03 pm
This picture taken from a hotel in Antalya / Turkey.
Nanflexal
Mon May 23, 2011 2:29 pm
My repeater.
Solar Panel
Picture taken from, Sagrada Bulan Sorsogon, Philippines
eben
Wed Jul 20, 2011 9:10 pm
Here we have a little DIN rail.
The circuit breaker on the left is the "main switch".
From there AC power is supplied to 2 circuit breakers.
The breaker on the left controls the blue and white Meanwell DIN rail mount power supply. That power supply in turn powers the Planet ATA next to it. The Planet ATA is the cheapest device with an IP address that I've been able to find. It is powered "in the wild" so it will go off if there is a power failure and then Dude will notify me.
The breaker on the right controls the timer, which turns power on or off to the large power supply. The batteries connect to that power supply. As do the attached devices.
Each attached device is then powered on or off via a circuit breaker. Two breakers are for the RB750 and the RB250GS. One is for an external device and the other two are for future use.
This is what it looks like in a cabinet with a custom built battery tray and 3 x 105AH batteries.
Lastly, here is the "external device" mentioned above. RB435G, RB750, 4 x POE injectors for appliances.
nz_monkey
Thu Jul 21, 2011 1:26 pm
Where did you get the standoffs that are holding up the RB435G ??
eben
Thu Jul 21, 2011 10:09 pm
http://www.miro.co.za/detail.aspx?pid=2 ... =Utilities
Your local RS Components should also have them.
dallas
Long time Member
Long time Member
Fri Aug 19, 2011 9:13 pm
Hey Bobcat. I am looking for a friend in Canada. Please email me at dallasweitzel@gmail.com or call me.
dnyl
Fri Sep 30, 2011 12:18 pm
Leased line customer endpoint.
temuri426
Fri Sep 30, 2011 3:04 pm
hello, this is my installation.. 8km link
unfortunatelly dont have pictures of the other side..
NetworkPro
Fri Sep 30, 2011 3:48 pm
Please note that roof can obstruct fresnel zone leaving received power and quality lower than what otherwise would be possible.
kembiet
Thu Nov 03, 2011 10:39 pm
HotSpot in about 1.5km away from my Base Station
even Mikrotik show 5km :lol:
<1 .. =1ms
kembiet
Thu Nov 03, 2011 10:45 pm
StationBox 18DBi on RB711-5Hn-MMCX + TPlink 12DBi on a RB711UA-2Hnd
midnightman
Fri Nov 04, 2011 10:25 pm
Why you are Using a lot of 1port poe?? Use POE panel.
kembiet
Sat Nov 05, 2011 11:33 pm
Please midnightman
I can't understand you
NetVicious
Mon Nov 07, 2011 9:40 am
I think he is refering to use something like this (http://www.i4wifi.eu/8-port-pasiv-poe-i ... d2063.html) instead of 8 separated POE Injectors
sytex
Trainer
Trainer
Tue Nov 08, 2011 12:19 pm
One of our APs
sytex
Trainer
Trainer
Tue Nov 08, 2011 1:57 pm
AP in suburb area. 1xJRC24 3x120 degree sector:
midnightman
Wed Nov 09, 2011 12:03 am
I dont like this indoor UTP....
midnightman
Wed Nov 09, 2011 12:08 am
one of the site
midnightman
Wed Nov 09, 2011 12:09 am
POE PANEL
sytex
Trainer
Trainer
Thu Nov 10, 2011 1:10 am
InoX
Thu Nov 10, 2011 3:08 pm
POE PANEL
this panel uses shielded ports? or plastic? I want to buy one but I didn't find a description.
midnightman
Fri Nov 18, 2011 1:06 pm
prozak
Some of our installations
Wed Nov 30, 2011 10:46 pm
Enjoy
eben
Mon Dec 05, 2011 11:32 am
One of our APs
What are the relays for in this image?
http://forum.mikrotik.com/download/file.php?id=8553
How do you control them?
sytex
Trainer
Trainer
Tue Dec 06, 2011 2:57 pm
Under the batteries, you can se a little grey box. That's a GSM pager. One of the relays is connected to Output, I can restart the whole site with one call. The other relay is connected to Input of the pager. If there is input power outage at the site, it sends an SMS to our phones.
eben
Tue Dec 06, 2011 4:03 pm
Thanks Sytex
I use this http://gsmcommander.co.za/ or this http://www.accentronix.co.za/ at my high sites and remote sites.
The GSM Commander is brilliant. It has Windows based programming software and has daughter boards. You can use it to switch AC or DC. I use them to monitor power, to monitor doors and to shut down and restart computers and routers as needed.
The Cellswitch is not as powerful. For a start, it doesn't know whether the power is on or not. You have to use one of the inputs to monitor an output on the power supply. The on board relay is also much smaller than the GSM Commander (2A vs 8A) but it's a good idea to run all power through a separate relay in any case.
The saving grace of the cellswitch is the brilliant web based programming interface. This means that a unit can be reprogrammed on site. The GSM Commander has a USB port and needs to be connected to a computer to accept changes to the instructions.
The GSM Commander has a smaller brother called the SMS Commander. Two inputs and one output only. We use a lot of them at my hotspots.
Even though the capital costs for these things may seem high. Spending six hours in low range 4x4 to get to some sites, cycling the power switch by than and then six hours back again costs a lot more in time, vehicle running costs and potential damage to the vehicle than even the most expensive GSM Commander.
Here's a panel that I'm building at the moment that has a Cellswitch 100. The Cellswitch's cellular transceiver also isn't great. I'm having to use an 11dBi gain yagi antenna to get a decent signal - in my workshop, where a GSM Commander get a strong signal with a 0 dBi gain dipole.
Here's a hotspot controller built by my young assistant showing an SMS Commander.
angboontiong
Fri Dec 30, 2011 4:46 pm
What the model of you parabolic antenna?
it look very nice and i believe the performance should very great...
thanks.
ludvik
Sat Dec 31, 2011 12:35 am
Theoretically ... http://en.jirous.com/anteny-5ghz/jrc-29ex
thanks.
angboontiong
Sat Dec 31, 2011 4:40 am
thanks.
what about the actual performance?
honzam
Sat Dec 31, 2011 9:59 am
thanks.
I think, on picture is 24dB version http://en.jirous.com/antenna-5ghz/jrc-24-extrem
29dB version have larger bracket.
Performance is good, you can use box for routerboard http://en.jirous.com/Accessories-complements/jr-200
eben
Sat Dec 31, 2011 10:57 pm
SXT linking to another tower about 400m away.
sytex
Trainer
Trainer
Mon Jan 02, 2012 12:05 pm
You are right, this is the 24dBi version. We use lot of them on backbone links. There aren't any problems with them since they are mounted on towers.
sytex
Trainer
Trainer
Mon Jan 02, 2012 12:14 pm
JRC-24-EXTREME, RB411AH, R5hN, Single Chain setup, 40Mhz, nv2, net. 98Mbps (Measured with two notebooks, with iperf).
zgi
Mon Jan 02, 2012 5:27 pm
What's the link distance?
dnyl
Mon Jan 02, 2012 10:26 pm
How do you set up a single chain connection? You just disable the second chain? What about the secondary antenna connector on minipci?
Köszi a választ (Thanks for reply)
sytex
Trainer
Trainer
Wed Jan 04, 2012 3:31 pm
The distance is 11Km.
Signal level: -55/-60
CCQ:100/95
Data Rates:150/150
And the one chain setup:
I made a mistake upper, the cards are not r5hn, they are r52hn. There are two MMCX connectors on the card, simply we plugged in only one pigtail cable, and leaved the other empty.
Nagyon szívesen! (You are welcome)
dravnieks
Fri Jan 06, 2012 3:16 pm
433ah x2
R52n x2
Transtectors
Polyphasers
What is device where pigtails are connected? looks like splitter. Are you using 1 antena for 2 cards with different freq?
eben
Sat Jan 07, 2012 3:42 pm
Electricity supply box
From left to right
Top Row
Light Switch
Vivotech 8134 Dome Camera - http://www.vivotek.com/products/model.p ... era=fd8134
Bulkhead Light
On the right are 2x15A wall sockets - the type used in South Africa.
2nd Row Down
Generator controller - inhouse design
Primary Surge Arrestor
Main Switch
Circuit Breaker - Meanwell Charger
Circuit Breaker - Lights
Circuit Breaker - Plugs
Circuit Breaker - SMS Controller
Circuit Breaker - Thermostats
RB450G
3rd Row - Top
Meanwell 24V 360W charger
Meanwell 24V DC - DC Convertor
RB450
3 x Spare 24 Circuit Breakers
24V Circuit Breaker RB450
24V Circuit Breaker RB450G
24V Circuit Breaker Coils on the relays
24V Circuit Breaker Relay on the left
DIN Rail Mount 16A relay switches "outside" 24V on or off
DIN Rail Mount 16A relay switches "outside" 12V on or off
On the right, there are two thermostats. One switches the fan on when it's hot. The other one switches the heater on when it's cold.
3rd Row - Bottom
Circuit Breaker - Main 27 - 30V feed coming in from the batteries
Circuit Breaker - Main 12V feed coming from the DC - DC convertor
Circuit Breaker - Main 24V feed coming from the DC - DC convertor
Circuit Breaker - 24V switches the DC - DC convertor for the camera
DC - DC convertor that provides clean 12V for the camera
Power supply for SMS Controller
SMS Controller - Cellswitch 100 - http://www.accentronix.co.za/Products.html
Ground Level
DIN Rail termination block for municipal electric feed.
2 x 12V Batteries
There's another DC-DC convertor (24 - 13.8V) partially hidden behind the batteries. It provides "12V" power to the "outside" equipment.
12V battery provides backup power to the SMS unit
Fan to air airflow.
This lot provides power to:
4 x RB411AH
3 x RB433AH
1 x RB493G
1 x RB600A
1 x RB SXT
1 x TPLink 10/100 switch (13.8V is run through a LM7809 for clean 9V)
2 x UBNT Nanobridge 5
2 x UBNT Rocket 5
marioclep
Trainer
Trainer
Sat Jan 07, 2012 5:16 pm
:D :D :D
@Bongo: This is where we buy the boxes: http://www.genrod.com.ar/productos.htm
I can't send you messanges (don't know why) but thanks for the karma!
If u want, my msn is marioclep@mikrotikexpert.com or Skype: marioclep
Regards
m4rk0
Fri Jan 13, 2012 3:44 pm
This is one of our installations...
blacky
Sun Feb 05, 2012 12:14 am
CCQ:100/95
Data Rates:150/150
How can you get such a good signal over that distance? Or do you don't care about the allowed TX Power?
Joshiii
24KM link with RB600 and RB450
Fri Feb 10, 2012 8:42 am
My RB600 with 4 5Ghz Antenna on top of the mountain here in the south of Namibia. it links to Skorpion Zinc mine about 24 kilometers away to provide coverage to the town. The other end is connected to a 10 Mb ADSL line with
Ubiquiti's SR-71 doing the back haul, and Mikrotiks doung the routing, hotspot etc.
kembiet
Thu Mar 15, 2012 4:10 am
One of our APs
can you please tell me the manufacturer of those Small size antennas? and they performances
sytex
Trainer
Trainer
Mon Jul 02, 2012 4:17 pm
One of our APs
Which one?
kembiet
Wed Jul 04, 2012 11:16 am
One of our APs
Which one?
The sector antenna
debiano
Mon Jul 09, 2012 1:06 pm
i want to use 2 100Ah battery (@12v) with poe patch panel and 8 routerboard 411ah.
The MeanWell AD-155 is good?
Or what ?
how can I monitor the system?
Best Regards
eben
Mon Jul 09, 2012 1:58 pm
No.
Use Meanwell PB-360N-12
Use the voltreport on the MikroTik wiki to monitor the power.
http://wiki.mikrotik.com/wiki/Monitor_i ... B333/433AH
debiano
Mon Jul 09, 2012 3:47 pm
No.
Ok, but PB-360N-12 for charging battery... and how to give power to the AC when I Mikrotik?
Sorry for drawing raw... :D
Reagards
eben
Mon Jul 09, 2012 4:13 pm
How were you planning on providing AC?
AD-155 does not provide AC.
debiano
Mon Jul 09, 2012 4:29 pm
AC Input -> DC 12V Output + Battery charger
When AC input goes down :
DC Input (From battery) -> DC Output
AD-155 have a AC input with ups function.
I want use AC power and charge battery, when the AC go down i want to switch on DC from battery and managing alert.
Sorry for my bad english.
Regards.
eben
Mon Jul 09, 2012 4:44 pm
Regards.
Power the equipment directly from the battery.
Get a SIP ATA (probably the cheapest device with an IP address).
Connect that device to one of the ethernet ports on your network (or ether3 or ether3 on the RB43x). Power it straight from AC power.
Use Dude or Nagios or OpenNMS to monitor your network.
As soon as the AC goes down, the ATA will be "dead", the network management system will pick it up and notify you.
Here is a picture of a power box at one of our sites. You can see the ATA.
debiano
Mon Jul 09, 2012 4:58 pm
I do not like this solution !
matrot2
Mon Jul 09, 2012 11:03 pm
Or what ?
AD155 provides a small charging current.
Current charge for your problems is not enough! ( 2 100Ah battery!!!)
Here it is better to PSC-60 / PSC-100, SCP-35 / SCP-50 / SCP-75.
Monitoring the battery is described here: http://tandem.ck.ua/ups_mtm-eng.php.
Some examples of solutions can be found here: http://tandem.ck.ua/hard_apps.php
Lastly.
Meanvell equipment has proved to be very good.
I have installed about 100 units.
Employing approximately 5 years.
Dead not defective out of stock.
taduikis
Tue Jul 10, 2012 12:42 am
Two batteries with 100Ah connected in parallel (you said 12v) makes a total capacity of 200Ah. That is a lot and needs quite serious charging solution. By the rule of 1/10, it'd be like 20A at least. I suggest to go for higher voltage setups. What you need 12v for anyway?
debiano
Tue Jul 10, 2012 12:30 pm
I need a lot of autonomy @12V (Minimum 5/7 days).
On this location I have
- 3 MK rb411ah
- 5 rocket m5
- 1 MK rb493G
Total consumption i think ~7Ah and 200Ah are also a few.
Regards.
sytex
Trainer
Trainer
Thu Sep 06, 2012 11:16 am
Rebuilding of a 9 year old site:
(Click to enlarge the pictures)
BEFORE:
Image Image Image
THE WORK:
Image Image Image
AFTER:
Image Image Image Image
Don't look the funny bullet! :) The story: We have absolutelly forgotten about a very old 2.4Ghz link when we planed this replacement. So we had to improvise "what we can found in the car"! We will remove it in a couple of days.
BONUS RIDDLE: What can we se on the picture??
dnyl
Fri Sep 07, 2012 2:26 pm
Tömszelence with sziloplaszt :)
sytex
Trainer
Trainer
Fri Sep 07, 2012 5:59 pm
Almost....
(Majdnem, tömszelence talált, a több nem, következő tipp?)
For english users: tömszelence= a plastic thing, with this you can bring cables in/out from a metal case waterproof
skyfx
Mon Oct 29, 2012 1:51 pm
deejayq
Wed Dec 12, 2012 8:44 pm
One of our APs
i like the guy in the second picture
i think he did somethig wrong :P
sytex
Trainer
Trainer
Thu Jan 10, 2013 10:56 am
Thats me, I had a terrible headache that day.
Ibersystems
Thu Jan 17, 2013 12:41 pm
Change Alvarion from another antena.. x)
Ibersystems
Thu Jan 17, 2013 12:46 pm
TonyJr
Wed Jan 30, 2013 10:16 pm
Lego has it's uses... As does old coving.
Lupin
Mon Feb 11, 2013 7:58 pm
Repair of a groove metal knocked down by the wind at 150Km/h (93 mph)
8)
kraker
Tue Feb 19, 2013 9:54 am
Hi Lupin,
What kind of power box did you use for midspan?I'm using midspan but when I plug 12 device to midspan with 18V 20A power box,power box is not enough to carry to 12 device..(Each device normally working with 15Watt power.)
Are suggest. some power box for midspan?
thanks...
kraker
Thu Feb 28, 2013 5:42 pm
One of my tower station..
Ibersystems
Fri Mar 01, 2013 12:20 am
Where do you buyed this boxes/enclosures/ cabinet /racks?
kraker
Fri Mar 01, 2013 9:37 am
These are designed by me and some companies produced for us.We have 8 lattice tower (50 mt,60...80mt) and they also have same structure.We sell symmetric internet to the five star and luxury hotels .(20/20,40/40,80/80.....)
Also outdoor cabinet's has got fan and temparature control unit.Power box inside included power jenarator connection and button.We have more experince about outdoor wcdma,wimax and gsm systems.. UPS system everytime report to the noc about electical issue with SNMP modul.
best regards...
kembiet
Thu Mar 28, 2013 7:43 pm
Which one?
The sector antenna
Yes The sector antenna
jackpinto
Mon Apr 08, 2013 1:26 pm
sytex
Trainer
Trainer
Mon Apr 22, 2013 12:16 pm
Sorry for the late answer:
***DELETED*** I cannot find the antenna type in our system... need more time to figure out, which antennas we used on the site.
kembiet
Mon Apr 22, 2013 12:30 pm
ok thz!
I will be waiting
dnyl
Tue Apr 23, 2013 8:14 pm
Here is the answer for the question:
http://www.wirelesslan.pl/product_info. ... 7-sa120-16
kembiet
Fri Apr 26, 2013 1:23 am
thanks dnyl!
can you please tell the manufacturer website?
sytex
Trainer
Trainer
Fri Apr 26, 2013 5:17 pm
I really cannot figure out... sorry. It must be Atlas or Wavearena.
kembiet
Fri Apr 26, 2013 8:38 pm
Thanks Bro!
tamilmaran
Sun May 05, 2013 12:39 pm
while in tripod tower,whether i use seperate 2.5 mm wire or simple join into tripod tower.
jmllh513
Fri Aug 09, 2013 7:08 pm
RB433AH bolts to the backplate with brass bolts. :D :)
derr12
Tue Sep 17, 2013 5:15 am
Boba Fett, guards my rb2011 setup with linksys Voip adapter. I have an rb751 as a wireless bridge feeding my entertainment center in my living room.
I cant take pictures of the 30 or so routerboards i administrate at work so this will have to do :p
mahnet
Long time Member
Long time Member
Tue Sep 17, 2013 6:56 am
these are incredibly cool boxes. very neat and what r u using for power management..some kind of UPS or DG power.
At our sites it gets very tough to manage diesel for gensets, so we gotta use batteries and charger panels but have not found a stable solution yet.
i have repeatedly sought it from Mikrotik. inverters/ups's have lot of charge wasteage and other electrical chargers often affect the routerboards.
i would welcome any kind of stable solutions and alert system.
michaelcarey
Sun Sep 22, 2013 4:46 am
Here is my Mikrotik RIC/522 5.8 GHz installation. Link distance is around 2.5km.
This equipment links my home network to my ham radio D-Star/IRLP/AIS/telemetry/video equipment at my comms site. Much cheaper than maintaining another ADSL connection at the remote site.
It's been installed since Mid 2010 and has been incredibly reliable, just like having an ethernet cable between the two locations! The mast at home also holds up my TV antenna.
Michael.
Port Lincoln.
Last edited by michaelcarey on Mon Sep 23, 2013 11:14 am, edited 2 times in total.
kraker
Mon Sep 23, 2013 10:23 am
@Mahnet
It's rack type 3kw online ups and we control it with netagent(http://www.megatec.com.tw/) working very well.It send's everything about power also ups.
Later I'll share our another tower pictures.
Spider24
Wed Oct 16, 2013 4:41 pm
This is one of two towers that we setup to connect a remote site to head office
eben
Wed Oct 16, 2013 4:59 pm
Nice!
That solar panel is quite flat. Obviously quite far south (or north).
Where in the world are you?
Spider24
Fri Oct 18, 2013 11:27 am
Hi Eben
in Citrusdal, Western Cape, South Africa
according to solar provider that indicated a 20 degree facing north
Gys
laithmikrotik
Thu Nov 07, 2013 5:21 pm
hi... im...there..up .. up... up
:lol: :lol:
toong
Sat Nov 09, 2013 5:29 pm
test
DiabolixZA
Sat Nov 30, 2013 9:04 pm
Core: RB750GL
POE's: 1 X 8 Port Toughswitch, 1 X 5 Port Toughswitch (If only Mikrotik had something similiar ;( )
Sectors: 3 X Mikrotik Metals
Backbone's: All running RB911G's
Extra's: Aircam
All for a NPO in Cape Town, South Africa. Site is called Saturn we like planet names ;)
Aveyer
Thu Jan 09, 2014 7:45 pm
Core: RB750GL
Extra's: Aircam
How did you attach the ToughSwitch Pro to the metal cabinet?
There are no brackets visible.
DiabolixZA
Mon Jan 20, 2014 2:00 pm
Core: RB750GL
Extra's: Aircam
Very strong double sided tape :)
mahnet
Long time Member
Long time Member
Tue Feb 11, 2014 5:45 am
we have squirrels who would bite off that blue cable every 3rd day
eben
Tue Feb 11, 2014 7:26 am
Use armoured cable.
http://www.universalnetworks.co.uk/pdfs ... 237275.pdf
erkel
Sun Apr 20, 2014 4:11 pm
2 x SXT
1 x SEXTANT
dnyl
Wed Jul 23, 2014 7:30 pm
Business customer endpoint
Business customer base station side
Base station
dnyl
Wed Jul 23, 2014 7:32 pm
Base station with 6m pole :)
Rack cabinet with 24v UPS system.
jcastellvi
Thu Aug 07, 2014 2:23 pm
Wifi service to the beaches in Catalonia
Walterrruiz
Sat Aug 16, 2014 12:37 pm
Nice work you guys done. This sample of installation will help people who wants to install it in home. This is giving a guide about installation. Good luck!
cdiedrich
Forum Veteran
Forum Veteran
Mon Sep 01, 2014 12:40 pm
Hi Eben
Gys
Hi Spider24 and Eben,
sorry for bumping this old topic - since the forum doesn't allow private messages I need to do it this way and hope you will read it :-)
Just something completely off-topic:
I'm in Somerset West (well, Cape Town, but this isn't that far away) and Citrusdal in November (just holidays) - and I'd love to drop in for a visit and see your installations and maybe have a little 19inch-chat about RB and PtP deployments...
Cheers,
-Chris (and sorry again for bothering the rest of the forum).
eben
Mon Sep 01, 2014 1:30 pm
Cheers,
Hi Chris
Pop over to our website http://cape-connect.com and use the contact us page to get in touch.
I'll take you on the grand tour, starting in Cape Town.
cdiedrich
Forum Veteran
Forum Veteran
Mon Sep 01, 2014 1:52 pm
Hi Chris
Wow, that was quick.
Thanks, I just sent you an email.
-Chris
lucim100
Thu Sep 11, 2014 9:19 pm
This is my 2x PPPOE servers and 1x PCC bonder
flynno
Fri Sep 12, 2014 2:43 pm
My two installs, can someone give me some instructions on how to make off my own pigtails with coaxial cable?
cybernetcy
Fri Sep 12, 2014 4:04 pm
Samples...
samsung172
Sun Sep 21, 2014 11:09 am
DannyRock
Mon Sep 22, 2014 2:06 pm
I want to ask my tricky question to you professionals ;)
Am I able to connect 2 routerboards in two neighboring valleys or do they need immediate "sight contact"?
As I figured by myself: I want to connect two houses with an airline of approx 4 Kilometers by MicroTik WiFi, but some friend of mine said, that this is only possible as you can see the receiver (see the house for instance) is this right?
Thanks in advance
jarda
Mon Sep 22, 2014 7:01 pm
You are asking in wrong thread. But the answer is no.
krajnalic
Thu Oct 16, 2014 8:53 pm
Feed on the second picture is not installed properly. Polarisation mark must be upwards while antenna grid is in horizontal (for vertical polarisation). If you want horizontal polarisation you must turn complete antenna with grid and feed 90 degrees clockwise or counterclokwise.
Benik3
Sat Oct 18, 2014 12:09 am
Samples...
No shielded cables and connectors into ubnt adapters? These looks like indoor cables...
BobcatGuy
Wed Dec 17, 2014 1:39 pm
Questionable - Tiny Internet Protocol Sorter, aka Q-Tips
So here is a project I was working on at 3 am. WTF!!! I didn't have a case, so I made one, for a temporary setup for this RB112. I am proud to have found a new life for the RB112, even for the short time that it will be in the Q-Tips Box.
Try not to laugh :-)
hossain2004a
Thu Jan 08, 2015 8:39 pm
This is our internet cafe's rack - as you see, we live in WIRE world :D
and our modem+AP :D
Valerio5000
Sat Jan 10, 2015 8:56 pm
This is my home network cabinet: D
From left Modem Provider (Fastweb), RB951G and RB260GS.
Values: 95 mbps Download 10 mbps Upload
Opinions? : D
hossain2004a
Mon Jan 12, 2015 11:26 am
Opinions? : D
What was the PSU voltage and ampere you used for POE, and why u used POE ??
Valerio5000
Tue Jan 13, 2015 11:31 am
Opinions? : D
Poe for 2 RB260GS , i do not have the problem of the power supplies in the rooms :D
hansv
Sat Feb 21, 2015 11:25 pm
Not wireless but hey, it's Mikrotik! :-)
InoX
Sun Feb 22, 2015 12:32 am
So many unused (and payed) sfp ports. Nice investment, someone sure did make some money with you/him/it.
hansv
Sun Feb 22, 2015 12:39 am
*Work in progress*
And zyxel switches are pretty cheap.
kraic
Fri Apr 17, 2015 1:02 pm
100+ users nv2, 20/40MHz, works well
ziegenberg
Tue Apr 21, 2015 11:24 pm
Site 3
Site 4
Others will follow.
Petzl
Sat May 09, 2015 3:38 pm
CRS125-24G-1S-RM
Petzl
Sat May 09, 2015 3:47 pm
Omnitik U5HND with POE OUT, Soldered inside omnitik
Also my special roof ladder
purana
Tue Jul 07, 2015 2:54 am
Great setup, good idea. I want to do the same as you have done here.
Josasp
Wed Sep 09, 2015 6:48 am
Too tight to get all in a single picture.
Quite happy with the installation, turned out well.
UniFi AC-APs for wireless.
ricreis394
Wed Sep 23, 2015 10:09 pm
since you mentioned that...
sfp ports are useful for home network?
could you please give me an example? I'm amateur in this area of networking
InoX
Wed Sep 23, 2015 10:13 pm
You didn't get the irony...
ricreis394
Wed Sep 23, 2015 10:20 pm
of course I didn't. I'm not a profissional in this area, I practise network only as a hobby.
So, sfp is useless for home network? or there are homes that need that, which ones?
UMarcus
Thu Sep 24, 2015 2:22 pm
I'm a home / hobby user too, but i need the SFP Port to connect my house and the neighbor's house.
Issue in germany is that according to VDE law's (electircal law's) only potential-free connections between buildings allowed, except the buildings have an common grounding bar. This make seens in risk of ligthing stroke and equalizing current.
Regards
Marcus
InoX
Thu Sep 24, 2015 5:20 pm
Most of the time is useless for home use and to expensive and complicated.
jarda
Thu Sep 24, 2015 5:39 pm
Regards
Marcus
I wonder how the electricity power is distributed to the houses if there couldn't be any conductive wiring in between....
BartoszP
Thu Sep 24, 2015 5:48 pm
Galvanic separation is the answer. Seems that each building needs it's own transformer.
UMarcus
Thu Sep 24, 2015 6:29 pm
Problem is the grounding earth of each building which would be connected together if LAN cable (CAT) is used.
http://www.iebmedia.com/index.php?id=80 ... g3k1e6adg4
http://www.cablinginstall.com/articles/ ... pment.html
Zorro
Long time Member
Long time Member
Mon Oct 19, 2015 6:59 pm
Opinions? : D
very good, imo. manageable.
but ensure that you use fans with ball-bearings in, cuz they fail otherwise too fast. (and consider wide/weak dust-filters outside it, perhaps)
as for future - you need case/door with solid/strong steel and good locks, perhaps(mechanical picked or ruined with seconds, even Abloy and japanses, so perhaps good idea to use RFID locks or combination of).
karincanet
Wed Oct 28, 2015 11:25 am
I installed this system on my roof and ROS inside the PC.
2 x Netmetal 5
1 x UBNT AM5G19-120 sector anthena
1 x UBNT AM5G20-90 sector anthena
2 x DSL modem
1 x 24 port gigabit switch
1 x poe injector
1 x HP ML110 server
Any suggestion?
shailparmar
Mon Dec 28, 2015 10:43 am
Image[emoji15]
Sent from my MI 4W using Tapatalk
flynno
Fri Mar 11, 2016 9:21 pm
Two recent installations completed
masteras
Fri Mar 11, 2016 9:22 pm
1. 850Gx2
2. CRS109-8G-1S-2HnD
3. RouterBOARD 962UiGS-5HacT2HnT
TomjNorthIdaho
Sat Dec 03, 2016 3:42 am
Today we went to go repair some Mikrotiks that died after trying to upgrade them to v6.37.3
This what our tower looked like on top of a 4,000 foot tall mountain here in North Idaho
(FYI - at this same tower a few winters ago - we have seen 10 foot deep snow -and- 3 foot long sideways icicles -and- impossible to climb the ladder in the middle because everything is packed with hard-wind-blown ice/snow totally through our 14 foot wide tower)
Have you ever had a 20 lb chunk of ice fall 100 feet and hit you on your head ?
Have you ever seen what 100 lb chunk of ice can do when it hits everything on the tower as it falls 120 feet to the bottom? It will bend and break steal beams and destroy the tower-to-building ice-bridge and all rip apart all cabling.
Not shown in this picture - we have two ice-bridges between the tower and the building. We had to add a second ice bridge above the original ice bridge. The upper ice-bridge also has sheet metal folded and welded in an upside-down V to help break apart and deflect huge chunks of falling ice. The original single ice-bridge was destroyed 3 times prior to adding the 2nd ice-bridge.
BobcatGuy
Mon Jan 27, 2020 12:05 pm
Its been 8 1/2 years.. am I late in replying to this? :-) I'm sure there is a direct message thing here on the forum, i'll have to go find it...
