Caci99
PCQ Queue for connection or for user?
Mon Oct 12, 2009 8:41 pm
How does PCQ queue create its subqueues, based on connections,
as the name suggests, or based on users?
It it is based on connection it is not actually equalizing the traffic
from different users but their connections. So if one user has started
20 connections and another 10 connections, I guess the first one
is getting more bandwidth.
Am I wrong here?
-Toni-
Don't crash the ambulance, whatever you do
Chupaka
Re: PCQ Queue for connection or for user?
Mon Oct 12, 2009 8:53 pm
yes, a bit wrong. please see 'Classifier' parameter
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Caci99
Mon Oct 12, 2009 9:06 pm
Yes, based on dst-address for example, but isn't this only for indicating
a traffic direction, or is this parameter actually grouping the connection
based on IP address?
dst-address could be for exmple 10.1.1.0/24, right? wrong again? :)
-Toni-
Chupaka
Mon Oct 12, 2009 10:59 pm
PCQ groups all packets into flows based on classifier. no classifier - one flow. 'src-address' classifier - one flow per src-address, etc. then each flow receives a queue with 'Limit' length and specified Rate
marioclep
Trainer
Trainer
Tue Oct 13, 2009 3:27 am
Remember that PCQ classifiers can be used in different ways depending on the interface that are applied.
If you apply a PCQ "dst-address" to the local interface, then you are working on clients download, and "src-address" classifier in the public interface, that's the client-upload.
In that way, PCQ is udes for USERS =)
Ing. Mario D. Clep
CTO - MKE Solutions
MikroTik Certified Trainer
Users browsing this forum: Alexa [Bot], dandare100, fenix8012, Google Adsense [Bot], jcbhltz909, JnSchl, Znevna and 60 guests
