jmlalley
Enable Routing Instead of Routing Test before upgrade to 4.x
Sun Oct 18, 2009 6:39 pm
Greetings
After upgrading a x86 box running 3.30 using routing test to 4.1, I found the routing package disabled. Fortunaley, I was able to conect to the remote box and enable th erouting package. I will be upgrading another 3.28 box runnig routng test later today and will enable routing instead of routing test before the upgrade and share the results.
Cheers
Joe
Chupaka
Re: Enable Routing Instead of Routing Test before upgrade to 4.x
Sun Oct 18, 2009 10:40 pm
upgrade from 3.30 to 4.0 wath smooth for me... did you have 'routing' package installed and disabled in v3?
