Prewest
Issue SSH probe commands
Tue Oct 20, 2009 3:40 pm
i`m just new to the dude and have a question regarding SSH probe..
on the remote side there`s a linux machine and i need some kind of script to check if an external device there is working.
if i log in the linux device with putty i can isue the following command to check the external device:
/Scripts/PipeCommand /tmp/RIP_Tableau_1037 "STATUS"
the reply from the system will be this:
response : @/tmp/RIP_Tableau_1037@STATUS 3
this means that the device is running properly when status is @ 3,
how can i make a SSH probe that will log in to the linux machine and will issue this command
and then returns the following value back to the dude which checks if the status = 3
is this possible with the dude?
lebowski
Re: Issue SSH probe commands
Wed Oct 21, 2009 5:32 pm
As far as I know The Dude doesn't support SSH. But you can verify that the port is available by creating a probe that just does a connect only on port 22.
Or you can create your own external...
Users browsing this forum: No registered users and 76 guests
