MUM Europe 2020
econst
Wireless Frequency
Sun Oct 25, 2009 5:38 pm
Hi All,
If you had the option to choose between 900 Mhz., 2.4Ghz, and 5.8 Ghz for a 13km PtP link, over vegetation, which would you select and why. Thanks.
acim
Re: Wireless Frequency
Mon Oct 26, 2009 12:34 am
If it is over vegetation, than 5GHz, but if it is through the vegetation, then 900MHz. Basically, with higher frequency it is likely you will get higher throughput, but you need absolute clearance, no obstacles. With ostacles, lower frequencies will do better.
econst
Mon Oct 26, 2009 7:18 am
Thanks for the response. I think I will try the 900Mhz radio in a RB433AH. What is the best 900MHhz radio for this board?
econst
Tue Oct 27, 2009 3:20 pm
Any recomendations on a good 900Mhz card that has been tested with a RB433AH?
acim
Tue Oct 27, 2009 3:57 pm
This frequency is not allowe in my country, so I don't really know, but Ubiquiti cards are good, so I believe 900MHz version is also good.
Users browsing this forum: No registered users and 28 guests
