davidw
Bonding of 2 ADSL connections
Wed Nov 18, 2009 1:33 pm
Hi There,
I have 2 ADSL connections (each 20MB/1MB) from two separate providers. Both providers will provide 60GB of download data each. I would like to achieve the following.
1. Redundancy / Failover - ie if one adsl connection goes down all traffic is directed to the active connection.
2. Equal usage of the of the 2 x 60GB data allowances.
I understand that I am not going to get extra speed from bonding but I will get additional bandwidth - correct ?
Are there any problems to be aware of. I have heard that some applications might not like the fact that connections are coming from 2 different ip addresses ???
Should I use balance-rr
Any heads up would be appreciated.
Cheers
Chupaka
Re: Bonding of 2 ADSL connections
Wed Nov 18, 2009 7:59 pm
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Users browsing this forum: bpwl, hgoertz, Sob and 103 guests
