Is it possible that I could use Dude or some other way to change some settings globally on our routerboards using Routerboard's script?
We have many routerboards (200+) so i would like to use a script to change the whole lot at once.
<?php
include "telnet.php";
$ips = array("10.0.0.1", "10.0.0.2");
foreach ($ips as &$ip) {
routeros_connect("$ip", "username", "password");
routeros_cmd("/whatever command you want here");
fclose($fp);
<?php
* RouterOS API
* Based on the code of SpectatorCN at http://forum.mikrotik.com/viewtopic.php?f=9&t=32957
* Modified by Ali Damji
* Free to modify, distribute, do whatever.
# Basic Functions
function routeros_connect($host, $username, $password) {
global $fp;
$header1=chr(0xFF).chr(0xFB).chr(0x1F).chr(0xFF).chr(0xFB).chr(0x20).chr(0xFF).chr(0xFB).chr(0x18).chr(0xFF).chr(0xFB).chr(0x27).chr(0xFF).chr(0xFD).chr(0x01).chr(0xFF).chr(0xFB).chr(0x03).chr(0xFF).chr(0xFD).chr(0x03).chr(0xFF).chr(0xFC).chr(0x23).chr(0xFF).chr(0xFC).chr(0x24).chr(0xFF).chr(0xFA).chr(0x1F).chr(0x00).chr(0x50).chr(0x00).chr(0x18).chr(0xFF).chr(0xF0).chr(0xFF).chr(0xFA).chr(0x20).chr(0x00).chr(0x33).chr(0x38).chr(0x34).chr(0x30).chr(0x30).chr(0x2C).chr(0x33).chr(0x38).chr(0x34).chr(0x30).chr(0x30).chr(0xFF).chr(0xF0).chr(0xFF).chr(0xFA).chr(0x27).chr(0x00).chr(0xFF).chr(0xF0).chr(0xFF).chr(0xFA).chr(0x18).chr(0x00).chr(0x41).chr(0x4E).chr(0x53).chr(0x49).chr(0xFF).chr(0xF0);
$header2=chr(0xFF).chr(0xFC).chr(0x01).chr(0xFF).chr(0xFC).chr(0x22).chr(0xFF).chr(0xFE).chr(0x05).chr(0xFF).chr(0xFC).chr(0x21);
$fp=fsockopen($host,23);
fputs($fp,$header1);
usleep(125000);
fputs($fp,$header2);
usleep(125000);
write_to_telnet($fp,$username."+ct");
write_to_telnet($fp,$password);
read_from_telnet($fp);
function routeros_cmd($command) {
global $fp;
write_to_telnet($fp,"$command");
$rez = read_from_telnet($fp);
echo $rez;
# API Related
function ros_new_hotspot_user($username,$password,$email,$limit_kb,$limit_up) {
routeros_cmd("/ip hotspot user add name=$username password=$password email=$email limit-bytes-total=$limit_kb limit-uptime=$limit_up");
function ros_edit_hotspot_user($username,$password,$email,$limit_kb,$limit_up) {
routeros_cmd("/ip hotspot user set $username password=$password email=$email limit-bytes-total=$limit_kb limit-uptime=$limit_up");
function ros_disable_hotspot_user($username) {
routeros_cmd("/ip hotspot user disable $username");
function ros_enable_hotspot_user($username) {
routeros_cmd("/ip hotspot user enable $username");
function ros_hotspot_user_detail($username="") {
if ($username) routeros_cmd("/ip hotspot user print detail where name=$username");
if (!$username) routeros_cmd("/ip hotspot user print detail");
# Telnet Related
function write_to_telnet($fp, $text){
fputs($fp,$text."\r\n");
usleep(1250);
return true;
function read_from_telnet($fp){
$output = "";
$count = 0;
do{
$char =fread($fp, 1);
$output .= $char;
if($char==">") $count++;
if($count==1) break;
} while(1==1);
$output=preg_replace("/^.*?\n(.*)\n[^\n]*$/","$1",$output);
$o=explode("\n",$output);
for($i=1;$i<=count($o)-2;$i++) $op.=$o[$i]."\n";
return $op;
